jbdiver Posted July 19, 2011 Report Share Posted July 19, 2011 I've got my seq4 running on a wall power supply today. I built an aout_ng board and would like to integrate it with the core32. My understanding is that I need to change the power supply to one that supports three voltages: +5V, +12V, and -12V. I'm looking for recommendations for a power supply which will meet the requirements. I'm based in the US. Here's one I found on Jameco: http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_88402_-1 Would this one work? Quote Link to comment Share on other sites More sharing options...
TK. Posted July 19, 2011 Report Share Posted July 19, 2011 This is a switching PSU with 5A for 5V supply (far too much), and 2.5 A for +12V (far too much as well) In addition, switching PSUs are not good for analog stuff. Unfortunately I can't give you an alternative proposal for the US (in germany we would order at "Pollin" where matching PSUs are mostly available for 5..10 EUR), but I can give you some specs: 1A for the 5V supply, only if a BLM16x16+X should be connected maybe 2A would be better. ca. 100 mA for the +/- 12V supply Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
julienvoirin Posted July 19, 2011 Report Share Posted July 19, 2011 tested and approved in Seq V4 http://www.selectronic.fr/article.asp?article_ref_entier=11.4418-9999 Quote Link to comment Share on other sites More sharing options...
TK. Posted July 19, 2011 Report Share Posted July 19, 2011 perfect specs! But: Epuisé :-/ Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
julienvoirin Posted July 19, 2011 Report Share Posted July 19, 2011 But: Epuisé :-/ yes i know. I can't find back its box, but the brand is ELGA. parisian people can maybe find some in Selectronic Nation, in their backstock (maybe 2 or 3 units left) a good trick is to cut the power plug with a dremel in order to access the 220V wires. then you fix it in the rack enclosure with screws in the 4 corners. It is molded and a pain in the ass to open Quote Link to comment Share on other sites More sharing options...
jbdiver Posted July 20, 2011 Author Report Share Posted July 20, 2011 (edited) I found a similar version of this power supply in the US -- Elpac WM113. Unfortunately it is no longer produced and doesn't seem to be available anywhere. I spent four hours searching for a suitable power supply. Unfortunately almost everything with those specs is a switching PSU which TK noted isn't good for analog. I did find a couple power supplies which look like they might work. I don't think these are switching power supplies. http://www.alliedelec.com/search/productdetail.aspx?SKU=8001801 This one is twice as expensive: http://www.newark.com/sola-hevi-duty/slt12-20404-12t/power-supply-linear-5v-10w/dp/93K6609 Edited July 20, 2011 by jbdiver Quote Link to comment Share on other sites More sharing options...
julienvoirin Posted July 20, 2011 Report Share Posted July 20, 2011 I did find a couple power supplies which look like they might work. I don't think these are switching power supplies. http://www.alliedele...spx?SKU=8001801 according to pic : switch PSU This one is twice as expensive: http://www.newark.co...-10w/dp/93K6609 linear psu, so the price I spent four hours searching for a suitable power supply. Unfortunately almost everything with those specs is a switching PSU which TK noted isn't good for analog.the best is to make your own in this case. recycling the transformer of an old VTR is a good option, maybe using the existing circuits. whatsoever : http://www.midibox.org/dokuwiki/doku.php?id=bipolar_12v_psu Quote Link to comment Share on other sites More sharing options...
jbdiver Posted July 21, 2011 Author Report Share Posted July 21, 2011 the best is to make your own in this case. recycling the transformer of an old VTR is a good option, maybe using the existing circuits. whatsoever : http://www.midibox.org/dokuwiki/doku.php?id=bipolar_12v_psu Check out this kit. It seems like it might work. It looks a little big but the price is relatively cheap: http://www.electronickitsbychaneyelectronics.com/TRIPLE-OUTPUT-DC-POWER-SUPPLY-KIT/productinfo/C6895/ Quote Link to comment Share on other sites More sharing options...
Shuriken Posted July 21, 2011 Report Share Posted July 21, 2011 (edited) Check out this kit. It seems like it might work. It looks a little big but the price is relatively cheap: http://www.electronickitsbychaneyelectronics.com/TRIPLE-OUTPUT-DC-POWER-SUPPLY-KIT/productinfo/C6895/ Are you sure? it says it's Skill Level 2. Edited July 21, 2011 by Shuriken Quote Link to comment Share on other sites More sharing options...
Altitude Posted July 21, 2011 Report Share Posted July 21, 2011 I found a similar version of this power supply in the US -- Elpac WM113. Unfortunately it is no longer produced and doesn't seem to be available anywhere. I spent four hours searching for a suitable power supply. Unfortunately almost everything with those specs is a switching PSU which TK noted isn't good for analog. I did find a couple power supplies which look like they might work. I don't think these are switching power supplies. http://www.alliedelec.com/search/productdetail.aspx?SKU=8001801 This one is twice as expensive: http://www.newark.com/sola-hevi-duty/slt12-20404-12t/power-supply-linear-5v-10w/dp/93K6609 Yeah, I use that elpac for my MBCV. Works great, hard to find though :( Quote Link to comment Share on other sites More sharing options...
tupinamba Posted August 9, 2011 Report Share Posted August 9, 2011 Hey Thorsen, Could you give a link to a working PSU at Pollin for us lucky Europeans ? ;-) Thanks! Quote Link to comment Share on other sites More sharing options...
