puddingbrumsel Posted April 18, 2012 Report Posted April 18, 2012 Hi, finished soldering my sammichSID. Voltage test was ok. Mios up and running, also uploading application sammich .hex v2.40 was no problem. Went step for step through build guide. Sids not placed yet. Last step was to install the shift registers. Now my problem. My 4 menue buttons and the encoder doesn't function. Made a check of all nessesary soldering points and also again a voltage test on ic2 but did not find a mistake. The other buttons work fine. Am i overseeing something? Is there any hint to get the error. Also tried another register ic but problem is still there. I dont get it ... :unsure: Hope you can help me. Searched the forum already but the solutions and problems didn't match mine. My board is revision 2 if that matters. Hoping for sammich, Christian
puddingbrumsel Posted April 19, 2012 Author Report Posted April 19, 2012 Hi, problem is still there. Resoldered all points including ic2, resistor bulk, switches, encoder. Made another voltage check, which was ok. Also checked voltage with inserted ic. Everything seems fine voltages are there where they have to be. Changed ic1 with ic2 both works in socket ic1. But no response from the menue buttons or the encoder. Q: Is it right that the bulk resistors face all the same direction? Maybe a software problem? I'm at work so i can't have a look at it. Any advice for a application for testing the functions? Please help. If anyone is living in Nürnberg and could give assistance i would be glad (today or next week, i stay at NB over the week). Also assistance over google/hangout/skype/chat even twitter would be ok after work.
nILS Posted April 19, 2012 Report Posted April 19, 2012 Got a decent-res pic of the CS board? Also, there's a chat link in the menu roughly 23cm above this post. This is where you'll pretty much always find some midiboxers who might be able to help.
puddingbrumsel Posted April 19, 2012 Author Report Posted April 19, 2012 As i said, after work i'll be in the chat. did not take any pics yet but i'll do so ;-)
strophlex Posted April 19, 2012 Report Posted April 19, 2012 Double check that no resistor network is flipped around. I got a similar problem when mounting every second resistor network in the opoisite direction.
puddingbrumsel Posted April 19, 2012 Author Report Posted April 19, 2012 Hi, here the pictures. Handy cam. The network resistors soldered all in the same direction. Dots face the display so the dots align to the dots on the pcb.
Janis1279 Posted April 19, 2012 Report Posted April 19, 2012 Hi, Are you could to measure 5 volt on the resistors network marked pins for the RN2 and RN4 parts? http://www.midibox.o...hSID_CS_PCB.pdf Regards, Janis
puddingbrumsel Posted April 23, 2012 Author Report Posted April 23, 2012 Hi Janis, measured again all points. The IC have all their 5v. Measured with and without ic's plugged. I just dont get it. Is there anyone who can provide me an older firmware for uploading? Other ideas?
puddingbrumsel Posted April 23, 2012 Author Report Posted April 23, 2012 okay just found this app. Will give it a try when home.
puddingbrumsel Posted April 23, 2012 Author Report Posted April 23, 2012 Here we go, uploaded the app with the result that ic2 does not work. Just pulled the ic's again and measured for shorts between the pins of the RNs. And tada ... :shocked: ... short between first and last pin of RN1. See the picture. I think it makes sense now. As it is the pin IC2 is linked to. But where is the bridge? The solder points are looking fine IMO. Any suggestions?
puddingbrumsel Posted April 23, 2012 Author Report Posted April 23, 2012 I think its the network. Maybe wrong part number. But i cant get it off the pcb. Any advice for desoldering the RN?
Hawkeye Posted April 23, 2012 Report Posted April 23, 2012 (edited) I think its the network. Maybe wrong part number. But i cant get it off the pcb. Any advice for desoldering the RN? Cut all pins directly above the frontside of the pcb with a wire cutter - use a desoldering pump from the front - heat from the back with your soldering iron - when heated, suck away pin remainders and solder remainders one by one. This will leave you with clean holes for resoldering the part. Greets, Peter Edited April 23, 2012 by Hawkeye
puddingbrumsel Posted April 24, 2012 Author Report Posted April 24, 2012 ... damn ... cut the pins as you said hawkeye. Measured - short between the pins on the pcb still there - now at ic socket. Where is this f***ing error??
