Lamouette Posted May 10, 2012 Report Posted May 10, 2012 Hello, i bought for my SEQV4 a SD Card adapter kit : MOUSER PART But i have a problem : i follow these 2 page : Mbhp_sdcard mbhp_sdcard.pdf But on this adapter i don't see VSS and VCC; so i don't know how to connect it. Do you know how it work ? i search but didn't find something about the shema of the adapter. Another question : Do i have to sold the SMD part ? (see on pictures) ? All the picture here : Thx !! Quote
Hawkeye Posted May 10, 2012 Report Posted May 10, 2012 (edited) The small SMD parts should normally not be necessary. Bye, Peter Edited May 10, 2012 by Hawkeye Quote
Lamouette Posted May 10, 2012 Author Report Posted May 10, 2012 ok, thx for your answer ! (you are so quick ^^) I read on the SDCARD PDF that : PIC based MBHP_CORE (5.0V IO) requires additional resistors (voltage dividers) and a 3.3V Voltage Regulator cause i will use 5v screens, maybe i have to had something ? Quote
Altitude Posted May 10, 2012 Report Posted May 10, 2012 ok, thx for your answer ! (you are so quick ^^) I read on the SDCARD PDF that : PIC based MBHP_CORE (5.0V IO) requires additional resistors (voltage dividers) and a 3.3V Voltage Regulator cause i will use 5v screens, maybe i have to had something ? If you are running a core32 or LPC, those will already have 3.3V via jumper selectrion (and those supply +5 to screens). Only the PIC base core that runs at 5V needs the 3.3 vReg Quote
