lajos Posted September 30, 2012 Posted September 30, 2012 (edited) Hello! I started building this structure. If anyone can possibly help it if a problem is it for me please. 25LC512 EEPROM writes to him, is a good 24Lc512?? Thank you very much! Louis. Edited September 30, 2012 by lajos
ilmenator Posted October 1, 2012 Posted October 1, 2012 Do you have the datasheets of the two devices to compare?
Antix Posted October 1, 2012 Posted October 1, 2012 (edited) I bought 25LC for a mistake when I built the sequencer 3... It did not work but I did not ask why . As I stuffed the 24LC the sequencer started to see the banksticks. Edited October 1, 2012 by Antix
lajos Posted October 5, 2012 Author Posted October 5, 2012 Hello! Finished the great work! It's just the problem. I could not even get him to speak. I do not want to sound. A vintage SysEx became our narrow passage loaded. Someone could help me? Only one sid/8580 / in it, but he also would not work? Thanks for your help! Or what you need to program the EEPROM??
lajos Posted October 6, 2012 Author Posted October 6, 2012 Finished the Twins! Have already said, only one expresses output and the other is completely silent. I do not know what could be the problem please help me me! The sid is good both because it is the same If you mix them with acsatorna. In the menu, I know the L / R channels but you can also set only one channel is about! How can I retrieve the memory of a SysEx hurt? Thank you in advance for Louis.
lajos Posted October 8, 2012 Author Posted October 8, 2012 Hi, could someone beat me to the EEPROM can be loaded / Sysex / send files? Thank you, Louis.
lajos Posted October 8, 2012 Author Posted October 8, 2012 Hello! Finished the great work! It's just the problem. I could not even get him to speak. I do not want to sound. A vintage SysEx became our narrow passage loaded. Someone could help me? Only one sid/8580 / in it, but he also would not work? Thanks for your help! Or what you need to program the EEPROM?? Problem solved!
lajos Posted October 8, 2012 Author Posted October 8, 2012 Finished the Twins! Have already said, only one expresses output and the other is completely silent. I do not know what could be the problem please help me me! The sid is good both because it is the same If you mix them with acsatorna. In the menu, I know the L / R channels but you can also set only one channel is about! How can I retrieve the memory of a SysEx hurt? Thank you in advance for Louis. Problem solved!
lajos Posted October 16, 2012 Author Posted October 16, 2012 Hi, could someone beat me to the EEPROM can be loaded / Sysex / send files? Thank you, Louis. Hello! Can anyone help? Or because I can do that. If you have someone send it to me or post your ide.Most Vintage SysEx works, I'd like to spend another one in memory. Thank you! Louis.
lajos Posted October 17, 2012 Author Posted October 17, 2012 Hello! If someone would be so kind to put up a sys file TwinSidhez food. Now the bank is the only vintage. Thank you for your kindness! Louis.
lajos Posted October 18, 2012 Author Posted October 18, 2012 (edited) Hello! Why should the Vintage sys file I can upload to memory? Several people have tried but I can not! Why do help me! Thank you! Louis. Edited October 18, 2012 by lajos
TK. Posted October 18, 2012 Posted October 18, 2012 This is not a "TwinSID", but a MIDIbox SID V2, right? You will find a lot of documentation here: http://www.ucapps.de/midibox_sid_manual.html Why should the Vintage sys file I can upload to memory? sorry, but I don't understand the question. Could you please write it in other words? You could upload the presets/v2_vintage_bank.syx file with the SysEx Librarian which is part of MIOS Studio: Best Regards, Thorsten.
lajos Posted October 18, 2012 Author Posted October 18, 2012 This is not a "TwinSID", but a MIDIbox SID V2, right? You will find a lot of documentation here: http://www.ucapps.de/midibox_sid_manual.html sorry, but I don't understand the question. Could you please write it in other words? You could upload the presets/v2_vintage_bank.syx file with the SysEx Librarian which is part of MIOS Studio: Best Regards, Thorsten. I want a different kind of SysEx memory! Which one is it? Does anyone have?
lajos Posted October 20, 2012 Author Posted October 20, 2012 I want a different kind of SysEx memory! Which one is it? Does anyone have? Only "Vintage Bank" in the memory can be uploaded. The rest I can not! Why??
smokestacksproductions Posted October 21, 2012 Posted October 21, 2012 Only "Vintage Bank" in the memory can be uploaded. The rest I can not! Why?? What is your 1st language? Maybe you can ask in the forum of your own country for good communication.
lajos Posted October 22, 2012 Author Posted October 22, 2012 What is your 1st language? Maybe you can ask in the forum of your own country for good communication. I'm Hungarian! But the Hungarian forum completely deserted. Therefore I have written here. Perhaps someone can help me. I just wish more SysEx file in the memory copy! I do not know how you can ask for help in this! Thank you. Louis.
NorthernLightX Posted October 22, 2012 Posted October 22, 2012 Hi Louis, if I understand correctly you are asking for preset sounds for MBSID. It seems you are able to load the Vintage bank. Do you have all 128 patches ("sounds") from the Vintage bank available? I'm afraid the Vintage bank is the only complete bank available for download. You can find some single patches available for download on the forum, and you could upload those patches to available free bankstick memory (or replace patches from the Vintage bank) by using the patch librarian from MIOS studio, like Thorsten pointed out earlier. If I misunderstood your question please explain what you are unsuccessful at again.
lajos Posted October 22, 2012 Author Posted October 22, 2012 Hi Louis, if I understand correctly you are asking for preset sounds for MBSID. It seems you are able to load the Vintage bank. Do you have all 128 patches ("sounds") from the Vintage bank available? I'm afraid the Vintage bank is the only complete bank available for download. You can find some single patches available for download on the forum, and you could upload those patches to available free bankstick memory (or replace patches from the Vintage bank) by using the patch librarian from MIOS studio, like Thorsten pointed out earlier. If I misunderstood your question please explain what you are unsuccessful at again. Thank you! Everything ok! Louis.
