hi, in the schematic on how to connect a ssd1306 lcd to the lpc17 core there is stated, that the connections BS0, BS1, BS2 should be soldered to ground. i have some ssd1306 lcd with me now but i don´t know, how to connect these three points.
should i remove the bridges? or solder all three points to 0?
any help appreciated.
thanks and greets.
oh, i think i just answered my own question. i have to solder all three bridges to 0 and make it "4SPI".
can anyone please confirm this? i don´t want to destroy those nice displays. i waited long enough for them (i ordered them last year and it took them almost 7 weeks to get here).
Edited by JEFinster
thanks. i guess one can never do enough reading  :happy:. many thanks also for the datasheet. i tried so hard to find a datasheet for this particular display, it never crossed my mind to look for a general ssd1306 datasheet :whistle:.
Are your Displays also 180° turned? The label on the PCB and the Display doesn't correspond.
Did i made a mistake in the Wiring?
cant understand. because the aliexpress site showed it the way it is labeld...
post-10711-0-44089300-1359393779_thumb.j
post-10711-0-64328800-1359393947_thumb.p
i think it says on the schematic, that the display has to be flipped. http://ucapps.de/mbhp/mbhp_lcd_ssd1306_single_mios32.pdf
so i expected it to be that way. but i had no chance to try that yet. yesterday i finished changing the bridges B0-B2 to 0 but today i had to get away for business, so i will (finally) be able to test my displays when i come back, friday or saturday.
but it is nice to see, that you got this one working.
another thing i just saw on your pic. are you using illuminated encoders? if so, which brand? are they detented?
i also got some illuminated encoders for my mb seq, but unfortunatly the are not detented. the only ones which are detented, i found in the usa, and i just can´t afford the shipping costs and german customs fee.
Edited by JEFinster
ups, i just realised... i missunderstood the phrase "flipped". i guess it means to turn the display to the rear side to solder. sorry  :sweat:
but in the schematic, the pins are on the bottom of the display, so i expected it to turn it upside down.
Hmm. I already made my board. Thats bad... Should have tested it bevor trusting a chinese font... ;-)
The encoder are from bourns, i have got them from mouser and the name is PEL12T.
http://www.bourns.com/data/global/pdfs/PEL12T.pdf
They are not cheap. Some day, maybe i will make a bulk order here but until now im afraid of the lnvestment...
Best Regards
Novski
  • 1 year later...
Hi all!
I have exactly the same display but unfortunately i cant get it work on my STM32f4 core.
The screen stays black only the led gets on.
My core module should be OK because character displays are working properly.
Settings:
- all BS bridges are set to 0
- voltage jumper is set to 3V
- lcd_type is set to 0x84
- led_num_x and lcd_num_y are set to 1
- lcd_heigh and lcd_width are set to 128 respectively 64
Thats my display wiring:
I soldered 1k resistor and the 10uF capaciator directly on the core board and
added a connection from the core to the display RES pin.
What could be problem?
Best regards
Marxon
Hi novski!
Sorry my schematic was not the best choice.
It´s more to show the different pinout of the JY-MCU display
compared to the one from TK HERE.
Of course i dont use the same CS line for both displays and no second resistor/ capacitor :smile:
Nevertheless i have connected D7 instead of D0 to the display CS pin, like you said but it still does not work.
do you have STM32F4Disco core or a LPC17?
The different connection of the 2 parts seam to be correct to me...
Edited by novski
STM32F4
I only measure 2,9V on my 3,3V line...
could this be a reason?
Edited by Marxon
Hi again and sorry for my late reply!
I tried to connect the display to Port J10B of my STM32F4 core
but it still does not work. :( The led goes on but the display shows nothing.
Is there any minimum configuration (like connecting Vdd, Vss and Vo of a standard display)
to test if the display is generally working?
Best regards
Marxon
Edited by Marxon
I don't know a way to test else...
This alternative connection (J10B) is only supported by the upcomming CV2 i think and i just had a brief look to the Midibox_CV2 and didn't find a precompiled file.
Im sorry for that confusion...
What app do you use by now? And whats your Bootloader setings?
My settings:
At the moment i am using just the bootloader app.
EDIT:
I've just noticed the following:
After changing the number of displays with the bootloader app,
then MIOS studio does initialize them and reports which displays failed to initialize.
If i use character displays and connect less character displays than i have set,
MIOS studio reports the missing ones correctly.
But when i use SSD1306 displays, then MIOS studio does not recognize missing ones
regardless how much displays have been connected.
Is this a normal behavior?
Edited by Marxon
Same here! I have exactly the same problem!
When I did upload the bootloader app and restart the core, the display shows "Bootloader © T.Klose" but after that it goes black.
In NG it's also not working.
It's the normal behaviour, because there is no read-back path from the OLEDs to the core.
CLCDs have a bidirectional interface which allows to read the status.
Means: MIOS can only write to the OLED and assume that they are available due to the simplified SPI based interface.
@FantomXR: your problem is different from that, it isn't the same.
