Posted (edited)
The encoder does not play nicely... Sometimes it works nearly fine, sometimes it just does not do anything, or jumps randomly around.
So it seems the encoder is a 24 steps rotary encoder, should any brand work, if I'll change it?
One local shop has 20 step pulse-encoders, does this sound close enough? I guess it would just work a little slower?
Sorry I'm one of those evil second hand users, who bough an unit somebody else made, and my electronics skills are quite weak.
Edited by Taika-Kim
Seems kinda strange. So are you saying some sessions it's 100% fine and others not? Or does it work fine, then during a session go all wacko?
  • 1 month later...
Sometimes it works better, most of the time barely at all. And, please, I know my inertia when I see it, this is just plain random behaviour. Good idea about the soldering, maybe the uni took a hit in the mail.
I had the same problem and in my case it was the firmware that was too old I did the update V2_043 and it works great, I hope it will help you solve your problem.
Best regards, damien
  • 1 month later...
Posted (edited)
OK, I was using 2_040 before, and finally now have some time, I quit my job and moved to the countryside to a small cabin :D So today I finally plugged everything in again and took a look at this.
I just uploaded 043 and it seems that the encoder works fine, no inertia though, it always scans at a predefined speed. But better than jumping around :smile:
Great, I'm off to write some tracks!
Edited by Taika-Kim
