Allo ! :rofl:
I have a problem with my AOUT_NG, impossible to have voltage on the CV outs, i have read alot, checked everything but can't find the problem :no:
I tested with single ground, double ground, but impossible to have something else than 0V
My SEV4 is powered from an external power supply, everything else work but the AOUT_NG
I have 12V at IC3, and IC4, led is up, the mid IC don't fell too hot, i have also modified the Firmware, and set it to 3.
What i can check to be sure i donmt have others problem ?
Thanks for your help. Bye !
post-9818-0-67352400-1396488581_thumb.jp
Edited by Lamouette
Did you correctly change the sequencer output to AOUT1-8? The default will be USB, MIDI, IIC etc.
Failing that you could try the TEST AOUT PIN program from the Core, it should be somewhere on ucapps.de
Bonne chance,
Andy
Shame on me :rolleyes: ! Here is a SEQV4 totally working, with an axternal PSU, AOUT_NG, QUAD ICC !
I'm working on a tilted metal case, to fit everything inside ! I'M so happy guyz ! I already played a lot with it, it's just so good, A really good job, and i think lot of work for you ! Cheers TK, and Thanks for all the midibox community, which is just for me the best community in DIY (Shared with MI :smile: )
Here is an happy guy ! :purple:
