Hi all!
I've been scouring the forums and site looking to see if a C version of the matrix led source code exists...My goal is to use it for metering....
Has anyone come across it, or is this even feasible in C on the pic?
Thanks!
Posted (edited)
I don't realy understand. Are you just looking for the Code to adapt it to a selfmade project or are you looking to for a solution to get meters generaly?
Edit: All code is availabe in a SVN Repository: svn://svnmios.midibox.org/mios32 http://svnmios.midibox.org
Edited by novski
Nice !
I'm also very interested in creating a LED matrix with a PIC18F in C !
I'll try to digest the code, and propose a stripped down version when i find some time.
Also i'm curious to know if a 16x16 leds is doable, and what would be the best hardware approach to do so ?
Any ideas are very welcome :)
Yes, 16x16 matrices can be handled in C w/o problems, especially because the actual DOUT transfers are handled by MIOS8 in background with an optimized assembly based routine.
The mechanism is always the same: SR_Service_Prepare() will be called before the SRIO scan (each mS)
In this function, increment a counter variable on each cycle, reset to 0 once it reaches 16
Transfer the new pattern (which corresponds to the counter and is ideally stored in an array) via MIOS_DOUT_SRSet
Please note: a 16x16 LED matrix means that the 16 LED rows will only be visible for 6.25% of the time - the brightness won't be optimal!
It's better to implement two 8x16 matrices instead (counter from 0..7)
  • 2 months later...
well anyone had done this up to now?
i am starting programming today a 8x8 LED-Matrix (like SID-Matrix, but sid is ASM) , there are some usefull links here!
but have anyobody stripped down it already?
