  • 11 months later...
I want to send cv clock at Midibox seq because some modular seq don't work perfectly when they receive clock and reset (slave), for live perf, it's important.
Tanks for fast reply.
  • JCI port not used here (it's planned to use these lines for DIN Sync Clock and Start/Stop input in future)
Correct. Clocks and start/stop (i.e. "DIN sync") are sent over the DOUT shift registers. JCI is not used.
Check in the CV config:
Quote
  • Clk: selects 1 of 8 clock outputs (available at a dedicated DOUT shift registered which has been configured with the CLK_SR parameter in the MBSEQ_HW.V4 file). Each clock has an individual clock divider, or can optionally be used to output a Start/Stop signal
  • 3 years later...
Hello!
I got back to the synth hoby after a decade long hietous. Building a modular now and want to adapt my MB_SEQ 4 to able to control the modular via CV, so I need a transmitter and a receiver board. Anybodu have boards for sale? @latigid on?
Best regards!
Wow! I missed all that new stuff! I build 5U with 15V (yusynth) so I miss out on all the nice euro-stuff. Now I will order those pcb!
Thank you!
Welcome! The midiphy PCBs also have a standard IDC, so that means you can mount the PCB anywhere and use a ribbon cable to a breakout DB-25 anywhere on the case, if that suits better.
