TK.
Revised 25-pin breakout port
77 posts in this topic
since the old posting got lost, I will write a new one and give you some updates.
I've overworked the 25-pin breakout port for MBSEQ (and MBCV V2) to allow interconnections between an AOUT(_NG) module and MIDIbox over long cables (at least 2m will be possible).
In addition, the previously direct J5/J28 outputs for gates and DIN clock have been replaced by a DOUT connection, which means that level-shifting is now done via 74HC595 SRs, and more than 10 outputs are available (e.g. I'm planning to provide multiple Clock and Start/Stop outputs, but also the 64 drum trigger outputs can now be made available in a breakout box).
Picture of the prototype:
Schematic of the transmitter part: http://www.ucapps.de/mbhp/mbhp_line_driver_transmitter.pdf
Schematic of the receiver part: http://www.ucapps.de/mbhp/mbhp_line_driver_receiver.pdf
Update: today I created the layouts and ordered at OSH park.
Boards should be available for testing in ca. 3..4 weeks
Share this post
Link to post
Share on other sites
Very Cool. The max 2M length is excellent, putting the DAC close to the analog gear and keeping the digital UI in the 'work space'. Thank You
Yogi
Share this post
Link to post
Very cool! Are there plans to adapt this for MB_NG? I'm interested in building an external pedal board that will have some additional DIN/DOUT inside. Or is there a simpler way to do this if all I'm looking for is extending the SRIO?
Share this post
Link to post
It will work with any MIDIbox, which means: also with MIDIbox NG.
It's the right approach for an external pedal board - but let me prove the robustness first before I can confirm that it will really help.
Share this post
Link to post
This is fantastc Thorsten! More analog outs from the seqv4!
Share this post
Link to post
Good news on this topic: I got the PCBs and they are working!
E.g. here I connected a TPD to the line drivers, a bidirectional SRIO is working over a long cable without flickering LEDs or unstable encoder/button scans:
And I tried an AOUT_NG module which works as well:
I'm surprised by myself that it works w/o issues, because I haven't found so many references to these wonderful chips in the DIY world :)
Therefore I'm crossing fingers that I haven't overlooked something ;-)
However, I will do some additional checks this weekend and release the .brd files if I don't notice issues.
Share this post
Link to post
If someone does a bulkorder of this fine PCBs .. I'm in ...
1 person likes this
Share this post
Link to post
Me too.
Share this post
Link to post
x3
Thanks and nice work TK!
Share this post
Link to post
Thanks T.K.  This is awesome.
I will most likely be adding this to my seqv4 when i get it up and running.
Sorry if this is a dumb annoying question but....
Why not just make it a shared project on oshpark.com?
Looking at the .brd in Kicad now....nice layout!
So i had to fill the ground plane when i opened it in kicad but otherwise it seems to be in tact.
Edited by k-rAd MB6401
Share this post
Link to post
Hey
Interested in this for my build, just have some questions :)
is it possible to chain multiple line transmitter like this ?
CORE<-->line<-->DIN/DOUT/AIN/AOUT<-->line<-->DIN/DOUT/AIN/AOUT
Zam
Share this post
Link to post
In theory I think it should, although you may run into latency problems if you cascade too many chains. Are you planning to use two different cases? Can you not just run two Cores? Also AOUT is limited to 8 channels for most applications at the moment.
Share this post
Link to post
Hello
What amount of latency ? if it's in the ms range it's not a problem for me.
My built is an automated fader system for a 40 years old analog modular desk, I have some room issue in the frame, core and PSU have to be outside (maybe in a 19' rack few meter away), also interconnection/link between subframe (8 modules, channel/fader) need long wire due to mechanical restriction.
It's not really different cases but in fact I have to think like it was :happy:
Multi core is an available option
I read somewhere in the forum that someone run two chained AOUT_NG with succes
This line transmitter deserve a try in my build for sure...
Zam
Share this post
Link to post
It should work, latency shouldn't be an issue - but I never tested this by myself, and I can't exactly say how many MBHP_DRIVER modules can be used in a chain.
But with only two drivers in the chain it should work.
Share this post
Link to post
Tks for info TK
I will try! just need to fix/test other part of my build before :)
best
Zam
Share this post
Link to post
[status: order closed]
I'm ordering 10 pairs of Transmitter/Receiver boards and selling 9 pairs. I'll ship them out at the end of January and will only take payment at that time.
Update as of 01.30.2015 @ 11.00 - all boards shipped
mfk: 1 pair- shipped
borfo: 1 pair - shipped
rowan: 1 pair - shipped
CJ55: 1 pair - shipped
jojjelito: 1 pair - shipped
monokinetic: 2 pairs - shipped
Ungleichklang: 1 pair - shipped
grizz: 1 pair - shipped
(Notes: This is just a one-off run, I won't be doing any more. If anyone else needs more, I suggest simply uploading the .brd files to OSHPark.com or following this thread for other possible groupbuys)
Edited by sneakthief
Share this post
Link to post
ORDER!
2 pair. thanks!
Edited by mfk
Share this post
Link to post
Please confirm your order & quantity in a post below. First come, first serve. I'll update this thread when I've received the PCBs and open a new dedicated thread if all 9 haven't been accounted for :smile:
One pair please.
Share this post
Link to post
Oh yes! I will take one pair, too. Thank you!
Share this post
Link to post
I'd like a pair of those too please. Thanks!
Share this post
Link to post
