sneakthief Posted March 7, 2015 Posted March 7, 2015 (edited) I have an STM32F4 that refuses to work with both SD & ENC28J60 ethernet modules using MIDIbox NG & CV V2. Working: Ethernet and no SD When I boot it without an SD inserted, the ethernet works fine: Ethernet cable connected: yes Ethernet MAC address: 00:39:36:30:39:31 Ethernet services running: yes DHCP: enabled IP address: 192.168.0.100 Netmask: 255.255.255.0 Default Router (Gateway): 192.168.0.1 Not Working: SD and ethernet together (ethernet gets disabled) However, the moment I insert an SD card, I get various errors and the ethernet disconnects: [MIOS32_ENC28J60_PackageReceive] glitch detected - Ptr: ff09, Status: 7fb8 (max: 05ee) cd7f or [MIOS32_ENC28J60_PackageReceive] glitch detected - Ptr: ffff, Status: ffff (max: 05ee) ffff Working: SD and no ethernet If I boot with the SD card inserted, the MAC address is recognized but the plugged-in ethernet cable isn't detected (which could be due to another error): Ethernet cable connected: no Ethernet MAC address: 00:39:36:30:39:31 Ethernet services running: no DHCP: enabled IP address: not available yet Netmask: not available yet Default Router (Gateway): not available yet When this happens, my router actually recognizes the ENC28J60 and assigns it an IP address. Here's my cheap-o eBay ethernet adapter: Edited March 7, 2015 by sneakthief
Rowan Posted March 7, 2015 Posted March 7, 2015 Are you using RC2 for the select line of the ethernet module?
sneakthief Posted March 7, 2015 Author Posted March 7, 2015 (edited) Rowan: yes, I'm definitely using RC2 - as per the MBHP_ETH schematics. I triple-checked it with my multimeter. Here's an odd addition: Both ethernet & SD Card work briefly in MIDIbox Seq V4 - the previous behaviour was with MIDIbox NG & CV2, however, when I use MB SEQ V4, the ethernet cable is detected for a second: [3634559.440] network [3634559.441] Ethernet cable connected: yes [3634559.442] Ethernet MAC address: 00:39:36:30:39:31 [3634559.442] Ethernet services running: yes [3634559.442] DHCP: enabled [3634559.442] IP address: 192.168.0.100 [3634559.442] Netmask: 255.255.255.0 [3634559.442] Default Router (Gateway): 192.168.0.1 ...then a few seconds later, after a glitch (SD Card being accessed?) it isn't detected as connected when the SD card is plugged in BUT it reports that ethernet services are still running: [3634560.552] [MIOS32_ENC28J60_PackageReceive] glitch detected - Ptr: ff00, Status: 7fb8 (max: 05ee) cc7f [3634559.440] network [3634559.441] Ethernet cable connected: yes [3634559.442] Ethernet MAC address: 00:39:36:30:39:31 [3634559.442] Ethernet services running: yes [3634559.442] DHCP: enabled [3634559.442] IP address: 192.168.0.100 [3634559.442] Netmask: 255.255.255.0 [3634559.442] Default Router (Gateway): 192.168.0.1 However, running "set dhcp on" after this happens doesn't work and the IP is lost. Weird! Edited March 7, 2015 by sneakthief
TK. Posted March 8, 2015 Posted March 8, 2015 Do you have a schematic for this ethernet adapter? It could be that it has been designed for 5V based IO level, but STM32F4 is supplied at 3V Best Regards, Thorsten.
sneakthief Posted March 9, 2015 Author Posted March 9, 2015 My ENC28J60 supposedly takes in 3.3V. I've tried 5V & 3V from the core and also a bench power supply sending 3.3V. It doesn't make a difference: they all give a "glitch detected" when the SD card is connected.
ilmenator Posted March 9, 2015 Posted March 9, 2015 How do you feed power to your setup? I was trying to find out how you power your setup - USB or power supply, and if so with what ratings?
sneakthief Posted March 9, 2015 Author Posted March 9, 2015 (edited) I tried powering my STM32F4 core with both the USB micro and mini ports: - via USB from my PC. I measured the power draw to be 320mA (with only the core and the ethernet module) - via a dedicated 2A 5V USB power adapter I gave up with this ethernet adapter and ordered this one instead as it also has a 5V input: http://www.ebay.com/itm/New-ENC28J60-Ethernet-LAN-Network-Module-For-Arduino-SPI-AVR-PIC-LPC-STM32-/381090520292?ssPageName=ADME:L:OC:CA:3160 I'll report back when I get the new one. I'm just going to assume the one I have now is crap. Edited March 9, 2015 by sneakthief
