Potentiometer Thru Hole round Shaft PCB mount?
Phatline
for the MB-606-RE Project we need some Pots
1K lin
5K lin
10K lin
50K log
50K lin
100K lin
1M lin
2M lin
with 6mm Metal Shaft (D-Shaft or better Round-Shaft)
we found the Alps RK09L series witch have Metal shafts, but its difficult to get values like 1K, 5K, 1M, 2M... and we need one Stereo Pot for Resonance (100K Stereo)
The Pot should be PCB Mounted, (normally horizontal, not vertical), it will not get screwed with a nut to frontpanel (thruhole)
0,8 - ~ 2€Class
Any idea?
Edited by Phatline
Tayda 16mm pots? Not sure if they have 2M.
http://www.taydaelectronics.com/potentiometer-variable-resistors/rotary-potentiometer.html
You can get 9mm horizontal, they call the other one (vertical) right angle.
http://smallbear-electronics.mybigcommerce.com/alpha-single-gang-9mm-pc-mount/
For most robustness and ergonomics, take larger pots with ~20-30mm spacing between. Just because you can stack a lot of knobs/jacks together doesn't mean you should (harder to tweak).
