iZZE Posted March 6, 2017 Posted March 6, 2017 Hey guys.. After hunting for days and days and already giving up.. i got the Newhaven OLED Display to work on my MB-6582 :D I will shortly write a step by step guide when i have time tomorrow.. Just saying don't give up the hope.
Hawkeye Posted March 6, 2017 Posted March 6, 2017 Hey, well done! :-) Am really interested in your findings and what was necessary to get it running! Does it involve 4bit-mode, mods on the baseboard or modified timing code in the firmware? That's where I was with my last OLED, then it burned on me :-/, then I switched to a VFD :-). Many greets, Peter
ChinMuzik Posted March 6, 2017 Posted March 6, 2017 45 minutes ago, Hawkeye said: Hey, well done! :-) Am really interested in your findings and what was necessary to get it running! Does it involve 4bit-mode, mods on the baseboard or modified timing code in the firmware? That's where I was with my last OLED, then it burned on me :-/, then I switched to a VFD :-). Many greets, Peter How long did it take before the OLED burned up on you?
Altitude Posted March 6, 2017 Posted March 6, 2017 (edited) YES YES YES I'm like on the edge of my seat Edited March 6, 2017 by Altitude
iZZE Posted March 6, 2017 Author Posted March 6, 2017 Newhaven OLED NHD-0420DZW-AY5 on MB6582 1.) Connect your Newhaven OLED according to the following Pinout This is represented on the PCB like this: You will have to solder the 4 small SMD Jumper bridges on the bottom of the PCB Reassure that you have all the pins right and then proceed to step 2. 2.) Start MIOS Studio and connect your MB6582 to your Midi Interface Make sure that you have a stable connection - now load the device_id_00_lcd7.hex (supplied by TK from another thread). Start the upload to the MB6582. After this upload has been finished select the MB6582 Firmware application again (setup_mb6582.hex) - the attached file is version 2.045pre1 Wait till the upload is finished. 3.) Enjoy your new OLED awesomeness! device_id_00_lcd7.hex setup_mb6582.hex 1
Altitude Posted March 7, 2017 Posted March 7, 2017 is the wiring different for the LCD? what did you figure out that everyone else missed?
iZZE Posted March 7, 2017 Author Posted March 7, 2017 I don't know - the wiring is just as in the above documents - i seriously don't know why other people couldn't get it to work :) Just follow these steps and it should work. No Magic applied
Altitude Posted March 7, 2017 Posted March 7, 2017 The driver is probably why, I have not seen that before. Will give it a whirl.
iZZE Posted March 7, 2017 Author Posted March 7, 2017 Yes i think it has to do with setting the correct device id to activate the already implemented lcd driver. And the documentation about the jumpers is also not a 100% clear, but actually its very easy i was shocked when the OLED displayed something..
Hawkeye Posted March 8, 2017 Posted March 8, 2017 On 3/6/2017 at 9:50 PM, ChinMuzik said: How long did it take before the OLED burned up on you? it happened on the same evening/night i tried to get it running, i must have made some silly mistake, it was hanging in free air, might have shorted something... or it was not 5V tolerant :-). Anyways, good job, iZZE! I hope you get it working, too, Altitude, it has been a while! :-) Many greetings, Peter
iZZE Posted March 9, 2017 Author Posted March 9, 2017 Its always good to help others out - even if it is with something simple :) I also got so much support from the forum back in the days so i am glad to be useful myself once in a while haha. Greetings, Patrick
Altitude Posted March 10, 2017 Posted March 10, 2017 And it works! The green one is a Raystar btw. It's come to my attention that ALL of these 20x4 displays are in fact Raystar parts. I have "Newhaven", "Vishay", and "raystar" branded (which means a sticker on the back) and they are all identical
iZZE Posted March 10, 2017 Author Posted March 10, 2017 (edited) Congratulations.. glad you got it working :) Also nice small adapter PCB.. made it yourself ? I see you have an almost empty Base PCB running for testing ? You have one spare too ? :) Edited March 10, 2017 by iZZE
jaytee Posted March 10, 2017 Posted March 10, 2017 Lol, an entire MB-6582 board just to have a spare Core8.
jaytee Posted March 10, 2017 Posted March 10, 2017 How much thinner are the OLEDs than LCDs? I just spent $25 on my CrystalFontz MB-6582 LCD because it seemed like the nicest looking green-on-black I could find, but obviously these OLEDs are a class above. I never bothered looking into OLEDs since so many folks had had trouble with them, but now.... The only thing that concerns me is how sunken the display would be on an MB-6582 without a kludge of some sort.
Altitude Posted March 10, 2017 Posted March 10, 2017 (edited) 2 hours ago, iZZE said: .. Also nice small adapter PCB.. made it yourself ? I see you have an almost empty Base PCB running for testing ? You have one spare too ? :) Yeah, I shared the brd file for that somewhere, I can repost it here. Never have to wire up another damn MBHP display.. That is my spare board, I ordered a set to work on this issue in particular but now I dont have to :) I have a big box of VFDs I need to try with this 8 bit driver Edited March 10, 2017 by Altitude
Altitude Posted March 10, 2017 Posted March 10, 2017 1 hour ago, jaytee said: How much thinner are the OLEDs than LCDs? I just spent $25 on my CrystalFontz MB-6582 LCD because it seemed like the nicest looking green-on-black I could find, but obviously these OLEDs are a class above. I never bothered looking into OLEDs since so many folks had had trouble with them, but now.... The only thing that concerns me is how sunken the display would be on an MB-6582 without a kludge of some sort. About a third as thick. I am not a fan of those buy display parts, they are over priced and the quality is substandard. Kyocera has brought back some 4x20 parts (black on white/whit on black)
Altitude Posted March 10, 2017 Posted March 10, 2017 (edited) woo hoo! what's good for the OLED is good for the VFD! Edited March 12, 2017 by Altitude 1
Hawkeye Posted March 11, 2017 Posted March 11, 2017 Great job, everyone! ;-) Have a great weekend, Peter
jaytee Posted March 11, 2017 Posted March 11, 2017 Oh my, I might have to take you up on that VFD. Any idea how much extra current it draws? Looks fantastic.
urtzurd Posted March 12, 2017 Posted March 12, 2017 Thanks a lot for the info! It was a perfect timing for me, as I was trying to get this OLED display working: http://www.ebay.co.uk/itm/131999107925 After soldering the bridges and setting the device ID to use the 8bit driver, it works!
Altitude Posted March 13, 2017 Posted March 13, 2017 (edited) woohoo! Need to get a tinted window, those Raystars kick out Edited March 13, 2017 by Altitude
ChinMuzik Posted March 13, 2017 Posted March 13, 2017 Being so recessed does it give viewing issues from certain angles?
Altitude Posted March 13, 2017 Posted March 13, 2017 (edited) 19 hours ago, ChinMuzik said: Being so recessed does it give viewing issues from certain angles? No, that's the beauty of the OLED, outstanding viewing angles. The recess thing is what it is, there is no way around it since the OLED pcb would interfere with the tact switches above and below it. Once I get a dark window on it, it will look just fine. Edited March 13, 2017 by Altitude
