Posted (edited)
Hello,
I've got a question!
I was about to buy a small interface box for two of my effects. but when I saw the price I thought that there was probably not much in it and that I could have everything I needed to tinker with one.
Someone has already opened one of these boxes?
disaster_midi_box_-_1_1024x1024.jpgMidibox_-_Top_on_white_grande.jpeg?v=143
I suspect they have just put an optocoupler and distribute the logic level on the Jack outputs?
And Empress call their one, midibox :angry:
Thank you
Bruno
Edited by Antichambre
Hi Bruno,
Hm, as the four "control" output ports only have 2 pins and as it is called "midibox", they will most likely carry the unmodified MIDI signal, only two pins are needed for that (ground/signal).
I agree, that they probably have an optocoupler and maybe some buffering/inversion (e.g. with a hex inverter like for a standard midi thru box) in there.
But as long, as you do not know the exact protocol between the control box and the pedals, there could be also some other kind of stuff going on... if you assume plain midi (as do i), you could try to control one of your empress pedals with an experimental midi breakout cable, one end a 1/4 inch plug, the other end connected to MIDI GND and MIDI data and see if that works.
The more "safe" variant would be to open up a pedal and see, if it looks like a MIDI-IN circuit wired to the "guitar cable" port, i.e. if there is an optocoupler and a resistor connected, if so, you should be able to try sending MIDI without a danger to the fx box.
If that works, you can just build a basic MIDI thru box instead of buying this so-called "midibox" :-) Good luck! :)
Many greets and have a nice weekend!
Peter
Posted (edited)
Thank you Peter,
You're right, I didn't mention it, first is an empress reverb, second is a meris polymoon. their 'midibox' supports both brand.
i tried to connect directly to the MIDI pin of the Core, nothing. Tomorrow I will put an inverter between the two. But I will not search deeper, it would be stupid to burn a pedal like this for that price... If it doesn't work I will buy this interface next month from disaster area 59€. :/
But! Once I've got it I will open it and share what there's exactly inside.
Best regards
Bruno
Okay!
We were right, it works fine. Yesterday, I think I needed to sleep, I forget resistors...
Then 2 resistors are enough to replace this boxes.
This is it:
Solved and I saved 60€ :)
Thank you Peter, have a good WE!
Bruno
  • 2 months later...
On 26.1.2018 at 2:06 PM, Antichambre said:
Okay!
This is it:
Bruno
Hi Bruno,
I am having the same "problem", but I'm not so deep into the whole soldering stuff yet (basically I don't quite get your blueprint:), could you explain a little in depth or show a picture? This would be great! I want to send MIDI PC to the Polymoon via my Switcher, going into a MIDI quadra through and then to different pedals, but since the polymoon is the only pedal I have that needs MIDI via jack input, I don't want to spend 65 bucks for a midibox that has four outputs...
Would be awesome if you could help!!:)
Hello,
this diagram is to connect an fx in jack directly to the uart tx/rx of a Core, i did not test it from and to Midi connectors. There’s optocoupling between rx and midi connector. I have to make some test, unfortunately i left home this morning, i can answer to your question but you will have to wait 2 weeks before that.
is it fine for you?
best
bruno
  • 2 months later...
Posted (edited)
Hi AntiChambre, I'm also interested in this subject as I'm am looking to buy a Meris Mercury7 pedal but don't want to buy the whole control box for just one pedal. What is the "Core" you connect to in the diagram you put together?
Also, new to the forum :-). I have been tinkering with midi stuff for a while, using Arduino to add midi to old rockband-drumkits and so on... just found this, and it seems great!
EDIT - I just had a read-through of midibox, and I realize now what "Core" is.
Another question:  is the serial data transmitted on the tip and ring on the TRS connector actual MIDI-data?
Best regards,
Gustaf
Edited by GustafRG
Great! Forget your Arduino, come to our Core! This is made for that... MIDI Application!
Yes, it is... It's regular MIDI data, rate...
I think there's just no optocoupler, then it works with an UART directly connected to ;)
Best
Bruno
  • 2 months later...
Newbie here on all things MIDI - but keen to learn ..
I have a specific question to a new Strymon MIDI feature  recently made available on their Sunset / Riverside pedals - and which uses a MIDI to TRS jack connection  on their  custom cable - unavailable in UK til late October and I'd like to use facility asap  - googled and hence I'm here and looking for feedback based on your work above please - realise of course big ask from non contributor to date but any advice greatly received ..
164_zoom_1534893191.jpg Strymon bespoke cable - is it possible to replicate based on information provided below ?
info ex their site -  On our pedals equipped with a 1/4? TRS MIDI connection (Riverside and Sunset), the MIDI data is received by the pedals from the TIP of this connection.  When MIDI OUT or THROUGH is enabled on these pedals, the MIDI data is sent out of the pedal from the RING of the TRS connection.
also - recommended interface units - which I dont want to buy as its more pedalboard real estate
    • Disaster Area Designs – DPC Gen 3 Series, DMC Gen 3 Series, MIDIBox
    • Empress Effects – MIDIbox2
nb - this is a question on a youtube posting
Hey guys, could I hook up one of your drive pedals to the Meris MIDI I/O instead? Asking because I already have one of those.
Yes, Riverside and Sunset will communicate via MIDI with any TRS MIDI box that sends signals to the pedal on the TIP and receives signals from the pedal on the RING of the TRS connection.?
best regards and thanks in advance for any advice
I don't like the idea of combining MIDI in and out on one 1/4" jack. It's just another variation on the standard that will confuse. TRS 3.5mm jack with individual signals is bad enough :).
What feature do you wish to use? I.e using the MIDI in of the Strymon? Or sending the MIDI out from the Strymon?
I totally agree for me it's stupid.
But no choice, they did it, we have to deal with it.
To get it properly from a MIDI signal(not from UART directly) we must put something in the middle, I didn't work on this subject for the moment, but it's a part of a bigger project then I will do it for sure, just a question of time ;)  ....
Best
Bruno
I just want to use midi into Sunset pedal to access new patch feature - from what I can see ( novice opinion of course ) the cable is unlikely to carry active components ? would this be a simple wiring orientation ie if my reading is correct then pin 2 to trs jack sleeve ; pin 4 to tip?   pin 5 to ring ?   is there a need for resistors ?
I'm not confident I can work it out from the vague description; it's not your fault. MIDI is a current loop and the cables are passive. Normally resistors would be a good idea if you don't know what's what, but in this case they might hinder the operation by limiting the current. If you don't mind taking a risk or two, try the orientation you describe and swap it around if there's no joy. For a MIDI in, normally the 0v (ground) pin is not connected at the port. So you may wish to leave the sleeve of the TRS plug disconnected. Leave the pin two of the DIN connector connected to shield the cable.
You're free to use a male DIN or even cut an old MIDI cable apart to avoid using a female adapter plug.
Best of luck, YMMV etc.
Ok,
Try to simply do this, the point is to connect the 5V of the MIDI out to the 5V of the MIDI In to get the input optocoupler acting.
Works fine for me on a Polymoon, receive and send. And cabling example:
Fichier%2002-09-2018%2011%2026%2007.jpg?
Normally the 220ohm already present in your MIDI output acts as current limiter, no need for more resistor.
Best
Bruno
  • Like 1
I'd say as these are built for guitarists rather than MIDI nerds, it's more than likely that there's sufficient protection built in. If the signals are around the wrong way it will not work but probably will not harm the unit.
8 hours ago, jmp220478 said:
is there likely  to be any risk to either my timeline of the sunset pedals if i get the wiring incorrect ?
Do it slowly, properly and take care. If it's like Meris and Empress the same TRS 6,25 is used for expression pedal(analog), for Tap(switch) and for MIDI then this must be highly protected. More than that, as I said before the regular 220Ohm MIDI resistors will act as current limiter.
Don't put 220V in it that's all ;)
Notes: With my diagram, MIDI In will work only if the MIDI Out is connected, The 5V for MIDI in is provided by the Output. The trick is there. This must be the function of the disaster box and others, they are actives boxes(powered) they provide this 5V and they distribute and merge to and from their multiples TRS connectors.
Posted (edited)
Many thanks for feedback - the exp jack socket on the sunset ( overdrive / distortion unit ) controls volume / other parameters with an expression pedal and midi with their bespoke cable .
With your solution - you are using the out and in of another pedal ie my timeline ?  their cable is a single  MIDI to 6.35mm TRS lead  - enabling me to send midi info ex a programmable pedal board to the timeline => Sunset, otherwise all changes will have be from delay alone ( see below )   .. is there a way to do this without connecting midi out and in on the send device => Sunset ?
currently I have
Programmable Joyo pedal looper - single midi out => Strymon Timeline delay  ( used for patch changes )
my ambitiion
as above but Midi out Timeline => TRS EXP jack in Strymon Sunset ( patch changes to align with delay )
many  thanks
Edited by jmp220478
I'm not sure to understand but:
I said that on the regular MIDI gear side you need the MIDI Out to supply the MIDI In! but you don't need the MIDI In connected for a single MIDI Out !
here if I understand, first you've got the first and second gear with regular MIDI:
JOYO MIDI Out => Timeline MIDI In
to finish you need to control your sunset from the timeline(MIDI out), the full chain is
JOYO MIDI Out => [Timeline MIDI In... Timeline MIDI Out] => Sunset TRS
then no problem.
then no problem.
thanks I was confused by the use of both midi in and outs to connect to the single TRS jack - hence asking for the qualification
Posted (edited)
You're welcome!
Tell me if it works for your Sunset too, I know that Meris and Empress work fine with it, tell me for Strymon please.
Thx
Bruno
Posted (edited)
The saga continues - more information about midi implementation was released on the Sunet support page  - https://www.strymon.net/support/sunset/ so I mailed them again
 Strymon Support response  when I asked about midi pin to TRS jack wiring
We follow the same TRS MIDI scheme as Disaster Area and Empress. These do not simply wire the 5 pin DIN connections to the TRS; true MIDI data (post opto-isolator) needs to be sent into the pedal. TIP is MIDI IN, and RING is MIDI OUT.
Our cables here have an opto-isolator in line, and can let you send MIDI into the TRS jack:
https://store.strymon.net/midi-exp-cable/
Note that this cable is only one way, and won't let you get MIDI OUT.
Another way to do it would be to get some kind of MIDI box to split the signal from 5 pin DIN to TRS:
https://empresseffects.com/products/midibox2
https://www.disasterareaamps.com/shop/midibox
The Empress box is nice because one port is bi-directional and you could use MIDI OUT of the Sunset if you needed it.
Subsequently got this from another forum I raised this on ..
I emailed Strymon support about the Strymon MIDI Cable and asked them about the cable trying to find out if they adopted the MIDI DIN5 to TRS A OR B standard which basically flips the pins 2&3’s polarity on the TRS Tip and Sleeve respectively. What I got back was neither!  Strymon uses a proprietary cable. The support specialist attached this torn out drawing which is a schematic of the Strymon MIDI Cable.  So I ordered the cable. Cost more than your average MIDI cable. But I have not regretted buying it now. Here’s a link to a picture.  Sorry about what I used and the clarity:
https://imgur.com/gallery/Md24LCE?s=sms
There are 3 resistors, a diode, and a 6N138 high speed opto-coupler IC chip inside a cylindrical capsule. One might think it is a ferrite bead but it’s not. So if Strymon has gone to this length to make this cable, there must be something that is not either compatible or reliable using just a straight-thru wiring scenario. Usually this kind of circuit is used to mate different voltages or to keep down interference. So word the the wise over seas who can’t yet get this cable, order the parts and make one somehow. Maybe wire it up on an in-expensive breadboard at least. BTW - This is only for input to the pedal.
Apologies for super long post but for sake of completeness - I've added all details ; $64000 question now is how do I proceed as diagram looks like TRS back to Midi In flow ?
I also found this which may help original post - whats going on in an empress midibox 2 => full design schematic
https://empresseffects.freshdesk.com/support/solutions/articles/1000114016-i-design-build-guitar-effects-and-i-think-midi-is-rad-can-i-make-my-pedal-compatible-with-the-empres
And further info - https://support.empresseffects.com/support/solutions/articles/1000229541-i-want-to-use-midi-with-your-midi-enabled-pedals-but-i-don-t-want-to-buy-the-midibox-what-are-my-op
Heeeeeeeelllllllllpppppp    :-)
Edited by jmp220478
Shoddy work! Not only do they use a non-standard connector, they use non-standard wiring and make an external optocoupler necessary. What happens if you get the connections wrong and plug a 15V CV in there?
How did you hope to power the optocoupler? Is there +5V on the ring terminal (measure with a voltmeter/multimeter)?
I would assemble the parts on a piece of protoboard and mount in a small box. I thought the lump in the cable was an inline DIN female, meaning you could extend with a longer cable if you needed. If that's above you, you could use an IIC module PCB. I have one if you need or you could upload the brd file to OSH park. There, you could use a DIN female, the opto, diode etc. are already present, then connect jack to header J4:
5b93673301e11_TRSI2C.thumb.PNG.222583d89
