FantomXR Posted November 8, 2018 Posted November 8, 2018 Hey people, I don't have a question but I want to share this code. I searched for a way to get a blinking LED within NG. Here is what it looks like: EVENT_BUTTON id=1 type=meta meta=runsection:2 button_mode=Toggle EVENT_LED id=1 dimmed=1 EVENT_LED id=2000 And this is the NGR-part: if ^section == 2 if BUTTON:1 == 127 set LED:2000 127 endif if BUTTON:1 == 0 set LED:2000 0 endif if LED:2000 == 127 set LED:1 64 delay_ms 150 set LED:1 20 delay_ms 150 exec_meta RunSection:2 endif if LED:2000 == 0 set LED:1 20 endif endif What it does is: It checks the status of the button 1. Please note that the button is set to "toggle"-mode. If it's 127, LED:2000 which just acts as a value-storage is set to 127 and if that LED is 127, the loop is started. At the beginning of that loop the button-status is checked and as soon as it's 0, the loop stops. Best, Chris
FantomXR Posted November 8, 2018 Author Posted November 8, 2018 You could also do a "fade": if ^section == 2 if BUTTON:1 == 127 set LED:2000 127 endif if BUTTON:1 == 0 set LED:2000 0 endif if LED:2000 == 127 set LED:1 20 set LED:1 20 delay_ms 20 set LED:1 25 delay_ms 20 set LED:1 30 delay_ms 20 set LED:1 35 delay_ms 20 set LED:1 40 delay_ms 20 set LED:1 45 delay_ms 20 set LED:1 50 delay_ms 20 set LED:1 55 delay_ms 20 set LED:1 60 delay_ms 20 set LED:1 64 delay_ms 20 set LED:1 60 delay_ms 20 set LED:1 55 delay_ms 20 set LED:1 50 delay_ms 20 set LED:1 45 delay_ms 20 set LED:1 40 delay_ms 20 set LED:1 35 delay_ms 20 set LED:1 30 delay_ms 20 set LED:1 25 delay_ms 20 set LED:1 20 delay_ms 20 exec_meta RunSection:2 endif if LED:2000 == 0 set LED:1 20 endif endif
Zam Posted November 8, 2018 Posted November 8, 2018 Hello Chris That's a nice way to have blinking LED, I use this kind of strategy in my NG The drawback is that you can't run another script and keep the blinking. I start a topic/request long time ago to have a blinking mode at lower code level in mios, like a dynamic dimmed= mode Hopefully one day Best Zam
FantomXR Posted November 8, 2018 Author Posted November 8, 2018 Hm, good point! I tried to implement such thing via RTOS... but this seems to be above my skills.
Antichambre Posted November 9, 2018 Posted November 9, 2018 If you need help writing a new RTOS task(or something else, there's some others ways to add a non-blocking delay), this is not a problem but in regular code only, and I really don't know how to link it with the NG scripting syntax. But maybe one of you knows?
FantomXR Posted November 9, 2018 Author Posted November 9, 2018 Hm... I know how to create a meta-command. But I don't know how to refer to a timer within a meta-command. Maybe you could explain how to set up a simple timer and I'll see if I can implement that? Thanks, Chris
Antichambre Posted November 9, 2018 Posted November 9, 2018 In your App.c #define RESOLUTION 1000 // in uS #define TIMER_NUM 1 // TIM3 #define TIMER_PRIO MIOS32_IRQ_PRIO_MID static void TIMER_TIck(void); ///////////////////////////////////////////////////////////////////////////// // This hook is called after startup to initialize the application ///////////////////////////////////////////////////////////////////////////// void APP_Init(void) { MIOS32_TIMER_Init(TIMER_NUM, RESOLUTION, TIMER_TIck, TIMER_PRIO); } // This function will be called every ms static void TIMER_TIck(void) { // Your function here } This is MIOS32 ready to use Timer function. 1
Zam Posted November 9, 2018 Posted November 9, 2018 following with interest... can be merged with this: best Zam
