I am building a tr-606 sound module that requires 4ms triggers, but of course I want to trigger it from my MIDIBox (V4) sequencer.
Is there some way to adjust the trigger length of the DOUT via configuration?
Or has anyone built a circuit to extend the triggers to 4ms (with CD4016 chips) that they could share?
thanks!
Andrew
Posted (edited)
I found a "pulse stretcher" circuit on the MFOS page, but I don't know what res/cap values would be correct and I don't have a scope :-(
Any suggestions on the value for those two components so a 4ms trigger would result?
Andrew
Edited by oozitron
Why does it need to use a 4016?
I don’t know what to plug into that MFOS circuit, but it seems like a 555 in monostable mode will do the trick, no?
Or a 74HC123, anyway, I don't know how, but I'm sure there's a way to set the drum triggers out of the Seq V4 to 4ms instead of 1ms.
Maybe ask here:
But first, did you already try your module with the 1ms triggers?  ;)
Best regards
Bruno
The clock pulse can be varied in ms steps, but the triggers are either gate or 1ms. Does it work to use "gates" instead? Often a trigger input will react on the rising edge. If it's the falling edge though, then a gate wouldn't help.
I had a quick look through the code, but I couldn't find an obvious solution. Clocks are different to triggers, as the timing is always consistent relative to the master tempo.
Same!
It seems the DOUT triggers can be enabled in the hardware config file by "DOUT_1MS_TRIGGER" then the variable seq_hwcfg_dout_gate_1ms is set from this text command but I don't find where this variable is used, so I can tell how this is used, even less how to change its length.
I think we have to call @TK. for that, he's the only one who can explain how and what is doable.
Best
Bruno
A different length of trigger will probably affect the sound, since it’s an analog circuit. Still might be worth trying though...
  • 3 weeks later...
Pulse widths up to 10 mS are now supported, could be nice if you could try it out:
