banneduser Posted June 23, 2004 Posted June 23, 2004 I really like the use of the casing of the C16...this is really neat....Nice work....ErikBTW...D2K where did you get this nice big encoder cap?
d2k Posted June 23, 2004 Posted June 23, 2004 where did you get this nice big encoder cap?http://www.okw.co.uk/
arumblack Posted June 24, 2004 Posted June 24, 2004 Awesome!I had painted my c64 case black also, and a flourescent blue frontpanel, but the frontpanel looks really crappy so it sits unfinnished....I think I like this one even better than your MBSEQ! Truly great work!Did You Drill the panel yourself?
banneduser Posted June 24, 2004 Posted June 24, 2004 Awesome!I had painted my c64 case black also, and a flourescent blue frontpanel...Sorry, going off topic.. but a flourescent blue frontpanel. How did you do that?!Bye, Moebius
brettsinclair Posted June 25, 2004 Posted June 25, 2004 Congratulation :)where did you get the mini-joystick ? with encoder or potentiometer ?thanks
d2k Posted June 25, 2004 Posted June 25, 2004 where did you get the mini-joystick ? with encoder or potentiometer ?from alltronics.com...http://www.alltronics.com/images/22P010.jpg
arumblack Posted June 25, 2004 Posted June 25, 2004 @Mobius: Why with flourescent blue spraypaint of course......And If I'd have had schaeffer do the drilling it would have been useable.....oh well back to the drawing board.....
banneduser Posted June 25, 2004 Posted June 25, 2004 Why with flourescent blue spraypaint of course......Bloody HELL!! Deep in my mind I KNEW that it exists. Haven't found any in spraycan. Even transparent blue laquer I can only get in tiny cans intended for plastic models.As Monty Python sang:"Repeat: Finland, Finland, Finland.The country where I quite want to be......Finland has it all."Bye, Moebius
ganchan Posted July 2, 2004 Posted July 2, 2004 you're a grate artist!what do you have connected to the joystick? ::)
titan Posted July 28, 2004 Posted July 28, 2004 If you take a look on the data sheet of the 6581 you will see that on PIN 23 and pin 24 you can connect potentiometers. On the sid module these PIN'S[POTX/POTY] are left free. I don't know exactly which parameter you can change with that.
d2k Posted July 28, 2004 Posted July 28, 2004 The joystick can control any 2 params (tis just 2x 10k pots afterall) - atm I have it handlin cutoff/resonance....
subatomic Posted December 15, 2005 Posted December 15, 2005 I like it, do you have a higher res front view of the panel so we can see what everything does and how they work?Is the joystick reconfigurable, or always on cutoff/res?On the knobs that have three functions below them (white, yellow, orange colors), how do you switch functions? Is it a knob with button built in?The three lights above one of the knobs, I think it's the osc lights, how do you change those?So this is a c64 case painted black?Where did you get the knobs? Same as the big encoder knob?
illogik Posted December 15, 2005 Posted December 15, 2005 hi; Is the joystick reconfigurable, or always on cutoff/res?this has been answered 3 posts up?! it's reconfigurableOn the knobs that have three functions below them (white, yellow, orange colors), how do you switch functions? Is it a knob with button built in?The three lights above one of the knobs, I think it's the osc lights, how do you change those?these are normal functions of the control surface; read up on the MidiBoxSID pages. you could use encoders with switch for this but most people just put in a separate switch for these functions
subatomic Posted December 15, 2005 Posted December 15, 2005 The joystick can control any 2 params (tis just 2x 10k pots afterall) - atm I have it handlin cutoff/resonance....so I was wondering is it user configurable, or do you have to hack the hardware again to configure it?i.e. what's the mechanism to configure it....I'm starting to suspect I should read elsewhere on the forums about using a joystick to get ideas, maybe it's a standard thing... ;)these are normal functions of the control surface; read up on the MidiBoxSID pages. you could use encoders with switch for this but most people just put in a separate switch for these functionsok, i figured that. but I wanted to know specifically about this synth's configuration. how he has the buttons, in the knobs or separate? I didn't see separate...The pictures are tiny and grainy. sorry :(
