ksir Posted June 25, 2023 Author Posted June 25, 2023 (edited) The project advances Edited June 25, 2023 by ksir
gohan2a Posted June 25, 2023 Posted June 25, 2023 I am impressed, after lot of work it becomes reality. I recommend you to try to find Mackie fader cap, they are more narrow, but it depends on your lever type of course.
ksir Posted June 28, 2023 Author Posted June 28, 2023 (edited) I would need help with the power supply, I want to power at least 264 ws2812b leds, maybe more in the future, several dout modules, in the future surely 8 oled screens, and I'm sure I'm forgetting some. I wonder what power supply to buy and how to connect it.. I thought I would take 5v 10a.. https://secure.reichelt.com/fr/fr/bloc-d-alimentation-d-coupage-ferm-50-w-5-v-10-a-mw-lrs-50-5-p202960.html?&trstct=pol_4&nbc=1 I already have this usb hub: https://secure.reichelt.com/fr/fr/hub-usb-3-0-4-ports-avec-bloc-d-alimentation-en-m-tal-logilink-ua0149-p127833.html?&nbc=1 Thank you for your help Edited June 29, 2023 by ksir
Phatline Posted July 6, 2023 Posted July 6, 2023 the ssd1306 oleds i received where 5V tolerant... the ws2812b is also in a range from 3.3-5.3V, dout modules also needs 5V... so your reichelt psu should do the job, and you could power them directly from the psu... but i guess you power them with the ribbon cables from your core... i dont know what Core you will use? if you use the WCORE from midiphy, then you may ran into some problems when using a external 5V PSU, see this topic: https://forum.midiphy.com/d/151-wcore-non-usb-powerd-but-still-use-as-usb-device/5 also if you are unlucky you will get walking lines on your SSD1306 screens... then it best it would to buffer each D0 D1 Clock... Pins, which are done for example in this module:http://wiki.midibox.org/doku.php?id=displaydriver-smd a plus is then you can then use more then 8 screens! 1
ksir Posted July 6, 2023 Author Posted July 6, 2023 I use MBHP_CORE_STM32F4. http://www.ucapps.de/mbhp_core_stm32f4.html can i just connect my psu to j2 and remove jumper j17? Is there anything else to consider? Thank you again for your help
ksir Posted July 16, 2023 Author Posted July 16, 2023 (edited) Unable to operate encoder #15 he is detected by mios studio but he answers me: not event assigned, yet I seem to have configured it like the other 15 which works well... Thanks for your help #Modulbox RESET_HW # le SCS doit émuler les fonctions bouton/enc dans la page principale SCS soft1_button_emu_id=2000 \ soft2_button_emu_id=2001 \ soft3_button_emu_id=2002 \ soft4_button_emu_id=2003 \ shift_button_emu_id=2004 \ enc_emu_id=2000 # Contrôlé à partir des boutons SCS à J10 dans la page principale EVENT_BUTTON id=2000 type=Meta meta=SetBank button_mode=OnOnly range=1:1 lcd_pos=1:17:2 label="Bnk%q" EVENT_BUTTON id=2001 type=Meta meta=SetBank button_mode=OnOnly range=2:2 lcd_pos=1:17:2 label="Bnk%q" EVENT_BUTTON id=2002 type=Meta meta=SetBank button_mode=OnOnly range=3:3 lcd_pos=1:17:2 label="Bnk%q" EVENT_BUTTON id=2003 type=Meta meta=SetBank button_mode=OnOnly range=4:4 lcd_pos=1:17:2 label="Bnk%q" EVENT_BUTTON id=2004 type=Meta meta=EncFast:4 button_mode=OnOff range=2:0 # l'encodeur SCS en J10 incrémente/décrémente simplement la banque # fonction redondante - pourrait être modifiée à l'avenir EVENT_ENC id=2000 type=Meta meta=SetBank range=1:4 # le but de cet élément EVENT est d'imprimer la banque chaque fois que l'écran LCD est rafraîchi (par exemple après le démarrage ou le changement de banque) EVENT_LED id=2000 fwd_to_lcd=1 lcd_pos=1:1:2 label="Bank #%q" # ENC 1 - 8 /////////////////////////////////////////////////// # Classical Thermometer Pattern, Jaune #EVENT_ENC id= 1 hw_id = 1 bank=1 fwd_id=RGBLED:2 rgbled_pattern=1 hsv=50:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 16 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 # label="ENC #%3i %3d@(1:1:2)%B" # ENC 1 Moving Dot ,jaune EVENT_ENC id= 1 hw_id = 1 bank=1 fwd_id=RGBLED:2 rgbled_pattern=2 hsv=50:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 1 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 2 Moving Dot , Green EVENT_ENC id= 2 hw_id = 2 bank=1 fwd_id=RGBLED:18 rgbled_pattern=2 hsv=100:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 2 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 3 Moving Dot , RED EVENT_ENC id= 3 hw_id = 3 bank=1 fwd_id=RGBLED:34 rgbled_pattern=2 hsv=0:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 3 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 4 Moving Dot , Blue EVENT_ENC id= 4 hw_id = 4 bank=1 fwd_id=RGBLED:50 rgbled_pattern=2 hsv=200:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 4 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 5 Moving Dot Jaune EVENT_ENC id= 5 hw_id = 5 bank=1 fwd_id=RGBLED:66 rgbled_pattern=2 hsv=50:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 5 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 6 Moving Dot GREEN EVENT_ENC id= 6 hw_id = 6 bank=1 fwd_id=RGBLED:82 rgbled_pattern=2 hsv=100:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 6 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 7 Moving Dot RED EVENT_ENC id= 7 hw_id = 7 bank=1 fwd_id=RGBLED:98 rgbled_pattern=2 hsv=0:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 7 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 8 Moving Dot BLUE #label="Enc%3i&k@(1:4:6)%B&n@(1:19:5)%3d" EVENT_ENC id= 8 hw_id = 8 bank=1 fwd_id=RGBLED:114 rgbled_pattern=2 hsv=200:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 8 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # ENC 9-16 ///////////////////////////////////////////////////////// # Moving Dot Jaune EVENT_ENC id= 9 hw_id = 9 bank=1 fwd_id=RGBLED:146 rgbled_pattern=2 hsv=50:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 9 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # Moving Dot GREEN EVENT_ENC id= 10 hw_id = 10 bank=1 fwd_id=RGBLED:162 rgbled_pattern=2 hsv=100:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 10 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # Moving Dot RED EVENT_ENC id= 11 hw_id = 11 bank=1 fwd_id=RGBLED:178 rgbled_pattern=2 hsv=0:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 11 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # Moving Dot BLUE EVENT_ENC id= 12 hw_id = 12 bank=1 fwd_id=RGBLED:194 rgbled_pattern=2 hsv=200:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 12 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # Moving Dot Jaune EVENT_ENC id= 13 hw_id = 13 bank=1 fwd_id=RGBLED:210 rgbled_pattern=2 hsv=50:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 13 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # Moving Dot GREEN EVENT_ENC id= 14 hw_id = 14 bank=1 fwd_id=RGBLED:226 rgbled_pattern=2 hsv=100:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 14 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # Moving Dot RED EVENT_ENC id= 15 hw_id = 15 bank=1 fwd_id=RGBLED:242 rgbled_pattern=2 hsv=0:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 15 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" # Moving Dot BLUE EVENT_ENC id= 16 hw_id = 16 bank=1 fwd_id=RGBLED:258 rgbled_pattern=2 hsv=200:100:10 fwd_to_lcd=1 type=CC chn= 1 cc= 16 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_enc" #bouton poussoir encodeurs 1 EVENT_BUTTON id= 66 fwd_id=RGBLED:1 hsv=00:100:10 type=CC chn= 1 cc= 17 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 65 fwd_id=RGBLED:17 hsv=0:100:10 type=CC chn= 1 cc= 18 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 68 fwd_id=RGBLED:33 hsv=0:100:10 type=CC chn= 1 cc= 19 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 67 fwd_id=RGBLED:49 hsv=0:100:10 type=CC chn= 1 cc= 20 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 70 fwd_id=RGBLED:65 hsv=0:100:10 type=CC chn= 1 cc= 21 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 69 fwd_id=RGBLED:81 hsv=0:100:10 type=CC chn= 1 cc= 22 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 72 fwd_id=RGBLED:97 hsv=0:100:10 type=CC chn= 1 cc= 23 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 71 fwd_id=RGBLED:113 hsv=0:100:10 type=CC chn= 1 cc= 24 button_mode=Toggle label="^std_btn" #bouton poussoir encodeurs 2 EVENT_BUTTON id= 74 fwd_id=RGBLED:145 hsv=00:100:10 type=CC chn= 1 cc= 25 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 73 fwd_id=RGBLED:161 hsv=0:100:10 type=CC chn= 1 cc= 26 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 76 fwd_id=RGBLED:177 hsv=0:100:10 type=CC chn= 1 cc= 27 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 75 fwd_id=RGBLED:193 hsv=0:100:10 type=CC chn= 1 cc= 28 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 78 fwd_id=RGBLED:209 hsv=0:100:10 type=CC chn= 1 cc= 29 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 77 fwd_id=RGBLED:225 hsv=0:100:10 type=CC chn= 1 cc= 30 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 80 fwd_id=RGBLED:241 hsv=0:100:10 type=CC chn= 1 cc= 31 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 79 fwd_id=RGBLED:257 hsv=0:100:10 type=CC chn= 1 cc= 32 button_mode=Toggle label="^std_btn" #PADS EVENT_BUTTON id= 33 fwd_id=RGBLED:137 hsv=50:100:10 type=CC chn= 1 cc= 33 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 35 fwd_id=RGBLED:138 hsv=100:100:10 type=CC chn= 1 cc= 35 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 37 fwd_id=RGBLED:139 hsv=0:100:10 type=CC chn= 1 cc= 37 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 39 fwd_id=RGBLED:140 hsv=200:100:10 type=CC chn= 1 cc= 39 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 34 fwd_id=RGBLED:141 hsv=50:100:10 type=CC chn= 1 cc= 34 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 36 fwd_id=RGBLED:142 hsv=100:100:10 type=CC chn= 1 cc= 36 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 38 fwd_id=RGBLED:143 hsv=0:100:10 type=CC chn= 1 cc= 38 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 40 fwd_id=RGBLED:144 hsv=200:100:10 type=CC chn= 1 cc= 40 button_mode=Toggle label="^std_btn" #PADS EVENT_BUTTON id= 41 fwd_id=RGBLED:129 hsv=50:100:10 type=CC chn= 1 cc= 41 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 43 fwd_id=RGBLED:130 hsv=100:100:10 type=CC chn= 1 cc= 43 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 45 fwd_id=RGBLED:131 hsv=0:100:10 type=CC chn= 1 cc= 45 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 47 fwd_id=RGBLED:132 hsv=200:100:10 type=CC chn= 1 cc= 47 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 42 fwd_id=RGBLED:133 hsv=50:100:10 type=CC chn= 1 cc= 42 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 44 fwd_id=RGBLED:134 hsv=100:100:10 type=CC chn= 1 cc= 44 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 46 fwd_id=RGBLED:135 hsv=0:100:10 type=CC chn= 1 cc= 46 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 48 fwd_id=RGBLED:136 hsv=200:100:10 type=CC chn= 1 cc= 48 button_mode=Toggle label="^std_btn" #switch # SWITCH BANK 1 EVENT_BUTTON id=101 hw_id = 57 bank=1 fwd_id=LED:8 type=CC chn= 1 cc= 49 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=102 hw_id = 58 bank=1 fwd_id=LED:7 type=CC chn= 1 cc= 50 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=103 hw_id = 59 bank=1 fwd_id=LED:6 type=CC chn= 1 cc= 51 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=104 hw_id = 60 bank=1 fwd_id=LED:5 type=CC chn= 1 cc= 52 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=105 hw_id = 61 bank=1 fwd_id=LED:4 type=CC chn= 1 cc= 53 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=106 hw_id = 62 bank=1 fwd_id=LED:3 type=CC chn= 1 cc= 54 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=107 hw_id = 63 bank=1 fwd_id=LED:2 type=CC chn= 1 cc= 55 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=108 hw_id = 64 bank=1 fwd_id=LED:1 type=CC chn= 1 cc= 56 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=109 hw_id = 49 bank=1 fwd_id=LED:16 type=CC chn= 1 cc= 57 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=110 hw_id = 50 bank=1 fwd_id=LED:15 type=CC chn= 1 cc= 58 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=111 hw_id = 51 bank=1 fwd_id=LED:14 type=CC chn= 1 cc= 59 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=112 hw_id = 52 bank=1 fwd_id=LED:13 type=CC chn= 1 cc= 60 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=113 hw_id = 53 bank=1 fwd_id=LED:12 type=CC chn= 1 cc= 61 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=114 hw_id = 54 bank=1 fwd_id=LED:11 type=CC chn= 1 cc= 62 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=115 hw_id = 55 bank=1 fwd_id=LED:10 type=CC chn= 1 cc= 63 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" EVENT_BUTTON id=116 hw_id = 56 bank=1 fwd_id=LED:9 type=CC chn= 1 cc= 64 button_mode=Toggle lcd_pos=1:1:1 label="^std_btn" aINSER n= 1 enabled=1 muxed=1 cs=0 resolution=7bit aINSER n= 2 enabled=0 muxed=1 cs=1 resolution=7bit # AINSER BANK 1 EVENT_AINSER id= 125 hw_id = 1 bank=1 type=CC chn= 1 cc= 65 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 126 hw_id = 2 bank=1 type=CC chn= 1 cc= 66 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 127 hw_id = 3 bank=1 type=CC chn= 1 cc= 67 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 128 hw_id = 4 bank=1 type=CC chn= 1 cc= 68 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 129 hw_id = 5 bank=1 type=CC chn= 1 cc= 69 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 130 hw_id = 6 bank=1 type=CC chn= 1 cc= 70 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 131 hw_id = 7 bank=1 type=CC chn= 1 cc= 71 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 132 hw_id = 8 bank=1 type=CC chn= 1 cc= 72 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 133 hw_id = 9 bank=1 type=CC chn= 1 cc= 73 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 134 hw_id = 10 bank=1 type=CC chn= 1 cc= 74 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 135 hw_id = 12 bank=1 type=CC chn= 1 cc= 75 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 136 hw_id = 13 bank=1 type=CC chn= 1 cc= 76 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 137 hw_id = 14 bank=1 type=CC chn= 1 cc= 77 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 138 hw_id = 15 bank=1 type=CC chn= 1 cc= 78 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 139 hw_id = 16 bank=1 type=CC chn= 1 cc= 79 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 140 hw_id = 17 bank=1 type=CC chn= 1 cc= 80 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 141 hw_id = 18 bank=1 type=CC chn= 1 cc= 81 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 142 hw_id = 19 bank=1 type=CC chn= 1 cc= 82 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 143 hw_id = 20 bank=1 type=CC chn= 1 cc= 83 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 144 hw_id = 21 bank=1 type=CC chn= 1 cc= 84 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 145 hw_id = 22 bank=1 type=CC chn= 1 cc= 85 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 146 hw_id = 23 bank=1 type=CC chn= 1 cc= 86 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 147 hw_id = 24 bank=1 type=CC chn= 1 cc= 87 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 148 hw_id = 25 bank=1 type=CC chn= 1 cc= 88 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 149 hw_id = 26 bank=1 type=CC chn= 1 cc= 89 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 150 hw_id = 27 bank=1 type=CC chn= 1 cc= 90 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 151 hw_id = 28 bank=1 type=CC chn= 1 cc= 91 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 152 hw_id = 29 bank=1 type=CC chn= 1 cc= 92 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 153 hw_id = 30 bank=1 type=CC chn= 1 cc= 93 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 154 hw_id = 31 bank=1 type=CC chn= 1 cc= 94 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 155 hw_id = 32 bank=1 type=CC chn= 1 cc= 95 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 156 hw_id = 33 bank=1 type=CC chn= 1 cc= 96 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 157 hw_id = 34 bank=1 type=CC chn= 1 cc= 97 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 158 hw_id = 35 bank=1 type=CC chn= 1 cc= 98 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 159 hw_id = 36 bank=1 type=CC chn= 1 cc= 99 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 160 hw_id = 37 bank=1 type=CC chn= 1 cc= 100 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 161 hw_id = 38 bank=1 type=CC chn= 1 cc= 101 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 162 hw_id = 39 bank=1 type=CC chn= 1 cc= 102 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" EVENT_AINSER id= 163 hw_id = 40 bank=1 type=CC chn= 1 cc= 103 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="^std_aser" # encoder hardware configuration ENC n= 2 sr= 1 pins=1:0 type=non_detented ENC n= 1 sr= 1 pins=3:2 type=non_detented ENC n= 4 sr= 1 pins=5:4 type=non_detented ENC n= 3 sr= 1 pins=7:6 type=non_detented ENC n= 6 sr= 2 pins=1:0 type=non_detented ENC n= 5 sr= 2 pins=3:2 type=non_detented ENC n= 8 sr= 2 pins=5:4 type=non_detented ENC n= 7 sr= 2 pins=7:6 type=non_detented ENC n= 10 sr= 3 pins=1:0 type=non_detented ENC n= 9 sr= 3 pins=3:2 type=non_detented ENC n= 12 sr= 3 pins=5:4 type=non_detented ENC n= 11 sr= 3 pins=7:6 type=non_detented ENC n= 14 sr= 4 pins=1:0 type=non_detented ENC n= 13 sr= 4 pins=3:2 type=non_detented ENC n= 16 sr= 4 pins=5:4 type=non_detented ENC n= 15 sr= 4 pins=7:6 type=non_detented I take this opportunity to share with you a photo of my project Edited July 16, 2023 by ksir
Phatline Posted July 21, 2023 Posted July 21, 2023 (edited) EDIT: First try my second post (see below this one) try to not assign Encoder 16, and watch which 2 Buttons now are see-able in mios studio when turning the ENC 16 --- is it 29 30? since ENC15 is outputet as Buttons 31 32 in Mios Studio - so we can check if it is a neightbar on SR4... How ever - i guess you use a encoder pcb which you use 2 times in your setup, so ENC 7 is the same as ENC 15? and ENC7 is working as it should? try to to not assign ENC 7+8 - it should be the same pinout like ENC15+16 (but a other Shiftregister) some math: when ENC 15 is equivalent to Button 31 + 32, then ENC 7 movements should be button events = 32-16 = button 15/16, and ENC8 would be? 13/14? if so > 14+16 = 30 31 should be then Encoder 16? i checked your shematics, and there is no change to wrongly assamble the sandwitch (the button pins are always on the outside of the Header J30-J33 - so this cant be the bug... i guess u use standard DINx4 Modules to connect the boards, so a wrong pinout from this side cant be the bug too... at NG Code i am familar with assigning Encoders to shiftregisters and pins > and it seems ok to me (when it is correct that Encoders starting at ENC Nr1 and not at ENC Nr0?)... about the rest of NG i have no glue. Edited July 21, 2023 by Phatline
Phatline Posted July 21, 2023 Posted July 21, 2023 (edited) are you sure that Encoders start with Number 1? At least on Midibox-platform on the codeside (if you write a custom Midiboxproject) normally they start with Number 0, (also Buttons, AIN, Midichannels, CCs, Notes, i guess also Ledrings? ;) ;) ...)that would look there like this: const mios32_enc_config_t encoders[3] = {//(SR count-begin with 1, ENC with 0) // setup the Pinout of Encoders { .cfg.type=DETENTED1, .cfg.speed=SLOW, .cfg.speed_par=1, .cfg.sr=8, .cfg.pos=0 }, // 0 PAGE { .cfg.type=DETENTED1, .cfg.speed=SLOW, .cfg.speed_par=3, .cfg.sr=8, .cfg.pos=2 }, // 1 PAR 1 { .cfg.type=DETENTED1, .cfg.speed=SLOW, .cfg.speed_par=3, .cfg.sr=8, .cfg.pos=4 }}; // 2 PAR 2 u8 i; for(i=0; i<3; ++i) { MIOS32_ENC_ConfigSet(i, encoders); } they start with 0.... no idea if Thorsten, made it more "musican friendly" by make an offset "+1" behind the userinterface - so they start with 1 on Midibox NG? my nose says.... give it a try: ENC n= 1 sr= 1 pins=1:0 type=non_detented ENC n= 0 sr= 1 pins=3:2 type=non_detented ENC n= 3 sr= 1 pins=5:4 type=non_detented ENC n= 2 sr= 1 pins=7:6 type=non_detented ENC n= 5 sr= 2 pins=1:0 type=non_detented ENC n= 4 sr= 2 pins=3:2 type=non_detented ENC n= 7 sr= 2 pins=5:4 type=non_detented ENC n= 6 sr= 2 pins=7:6 type=non_detented ENC n= 9 sr= 3 pins=1:0 type=non_detented ENC n= 8 sr= 3 pins=3:2 type=non_detented ENC n= 11 sr= 3 pins=5:4 type=non_detented ENC n= 10 sr= 3 pins=7:6 type=non_detented ENC n= 13 sr= 4 pins=1:0 type=non_detented ENC n= 12 sr= 4 pins=3:2 type=non_detented ENC n= 15 sr= 4 pins=5:4 type=non_detented ENC n= 14 sr= 4 pins=7:6 type=non_detented Edited July 21, 2023 by Phatline
ksir Posted July 23, 2023 Author Posted July 23, 2023 Thank you again for your help I tried : # encode hardware configuration ENC n= 16 sr= 4 pins=5:4 type=non_detented ENC n= 15 sr= 4 pins=7:6 type=non_detented ENC n= 2 sr= 1 pins=1:0 type=non_detented ENC n= 1 sr= 1 pins=3:2 type=non_detented ENC n= 4 sr= 1 pins=5:4 type=non_detented ENC n= 3 sr= 1 pins=7:6 type=non_detented ENC n= 6 sr= 2 pins=1:0 type=non_detented ENC n= 5 sr= 2 pins=3:2 type=non_detented ENC n= 8 sr= 2 pins=5:4 type=non_detented ENC n= 7 sr= 2 pins=7:6 type=non_detented ENC n= 10 sr= 3 pins=1:0 type=non_detented ENC n= 9 sr= 3 pins=3:2 type=non_detented ENC n= 12 sr= 3 pins=5:4 type=non_detented ENC n= 11 sr= 3 pins=7:6 type=non_detented ENC n= 14 sr= 4 pins=1:0 type=non_detented ENC n= 13 sr= 4 pins=3:2 type=non_detented It's encoder 13 that didn't work anymore I moved the encoder hardware config code to the middle of the code, instead of putting it at the end, now it works
Phatline Posted July 23, 2023 Posted July 23, 2023 all encs are working? so its confirmed they start count with nr 1? thx 4 info.
ksir Posted July 23, 2023 Author Posted July 23, 2023 yes all encoders work, after having pushed the tests a little, I have the impression that it is the accent (é) in the comments of my code which poses a problem and erases lines at the end of my ngc file
ksir Posted July 29, 2023 Author Posted July 29, 2023 (edited) Hello, I have a rebound problem with the sparkfun pads, do you have an idea how to fix this? Hardware? Software ? Thanks The rest works fine Edited July 29, 2023 by ksir 1
Phatline Posted August 1, 2023 Posted August 1, 2023 since you dont use a Button Led Matrix on this - where the driver is already programmed to be debounced... and you on the other hand connect the buttons directly to a DIN-Module - which i didnt have done yet, on the hardware side i would take a Voltmeter, and measure on the DIN-Pins, hand look how many Volts you have when you press the button... if it is 0V then all is good, if it is hardly above that, then you may change the Pull-Hi Resistors on the DIN Board to a other (higher) Value (As expiriment) - because the Rubber button is not a perfect Electric Contact (a tactil switch is more on "perfect) it might be that it cant Pull-Lo the Pull-Hi resistors (fighting) @ software you have to debounce the buttons in software - how? i dont know the NG-script - so i cant help much here... maybe you start by posting how you defined the buttons in ng code... maybe i can see there something... It could be that there are set as toggle switches, in reality we wont some momentary switch - ... maybe there is also some timining offset to be set (a time that says that no incoming DIN signal is handeld after a trigger accoured - so we avoid false triggering for example 20ms long... aka debouncing?)
ksir Posted August 4, 2023 Author Posted August 4, 2023 Hello, I haven't studied your answer in depth yet, but here is an example of declaration of my pads in ngc file #PADS EVENT_BUTTON id= 33 fwd_id=RGBLED:137 hsv=50:100:10 type=CC chn= 1 cc= 33 button_mode=Toggle label="^std_btn" EVENT_BUTTON id= 35 fwd_id=RGBLED:138 hsv=100:100:10 type=CC chn= 1 cc= 35 button_mode=Toggle label="^std_btn"
Zam Posted August 5, 2023 Posted August 5, 2023 From NG user manual, .NGC config, SRIO section debounce_cycles=<0..65535> This command allows to enable a debouncing mechanism for digital inputs (buttons). The number specifies the dead time in SRIO cycles at which button events will be rejected. The time of a SRIO cycle depends on the num_sr configuration, typically it's around 420 uS for 32 SRs, which means that with debounce_cycles=20 the debouncing dead time is 8.4 mS.
ksir Posted August 5, 2023 Author Posted August 5, 2023 thank you for your help I tried : #PADS EVENT_BUTTON id= 65 hw_id= 33 fwd_id=RGBLED:137 type=CC chn= 1 cc= 33 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 50:100:10 debounce_cycles=65535 EVENT_BUTTON id= 66 hw_id= 35 fwd_id=RGBLED:138 type=CC chn= 1 cc= 34 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 100:100:10 debounce_cycles=65535 EVENT_BUTTON id= 67 hw_id= 37 fwd_id=RGBLED:139 type=CC chn= 1 cc= 35 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 0:100:10 debounce_cycles=65535 EVENT_BUTTON id= 68 hw_id= 39 fwd_id=RGBLED:140 type=CC chn= 1 cc= 36 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 200:100:10 debounce_cycles=65535 EVENT_BUTTON id= 69 hw_id= 34 fwd_id=RGBLED:141 type=CC chn= 1 cc= 37 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 50:100:10 debounce_cycles=65535 EVENT_BUTTON id= 70 hw_id= 36 fwd_id=RGBLED:142 type=CC chn= 1 cc= 38 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 100:100:10 debounce_cycles=65535 EVENT_BUTTON id= 71 hw_id= 38 fwd_id=RGBLED:143 type=CC chn= 1 cc= 39 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 0:100:10 debounce_cycles=65535 EVENT_BUTTON id= 72 hw_id= 40 fwd_id=RGBLED:144 type=CC chn= 1 cc= 40 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 200:100:10 debounce_cycles=65535 #PADS EVENT_BUTTON id= 73 hw_id= 41 fwd_id=RGBLED:129 type=CC chn= 1 cc= 41 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 50:100:10 debounce_cycles=65535 EVENT_BUTTON id= 74 hw_id= 43 fwd_id=RGBLED:130 type=CC chn= 1 cc= 42 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 100:100:10 debounce_cycles=65535 EVENT_BUTTON id= 75 hw_id= 45 fwd_id=RGBLED:131 type=CC chn= 1 cc= 43 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 0:100:10 debounce_cycles=65535 EVENT_BUTTON id= 76 hw_id= 47 fwd_id=RGBLED:132 type=CC chn= 1 cc= 44 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 200:100:10 debounce_cycles=65535 EVENT_BUTTON id= 77 hw_id= 42 fwd_id=RGBLED:133 type=CC chn= 1 cc= 45 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 50:100:10 debounce_cycles=65535 EVENT_BUTTON id= 78 hw_id= 44 fwd_id=RGBLED:134 type=CC chn= 1 cc= 46 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 100:100:10 debounce_cycles=65535 EVENT_BUTTON id= 79 hw_id= 46 fwd_id=RGBLED:135 type=CC chn= 1 cc= 47 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 0:100:10 debounce_cycles=65535 EVENT_BUTTON id= 80 hw_id= 48 fwd_id=RGBLED:136 type=CC chn= 1 cc= 48 button_mode= Toggle label= "^std_btn" bank= 1 hsv= 200:100:10 debounce_cycles=65535 doesn't seem to work
Phatline Posted August 5, 2023 Posted August 5, 2023 well then test like i suggested: Voltmeter black cable to a ground pin (core ore dinx4 module) Voltmeter red cable to a Dinx4 Pin that is connect to a PAD. if you dont press the PAD you should have 5V (its pulled high with the Dinx4 inbuilt pull high resistor > the 10K ones) if you then press the PAD you should have 0V (its pulled down with the button that connects now the Dinx4 Pin with Ground) if this is not 0V, and in worst case 2.5V - then the Resistance between Button and Ground is to high, so the 10K resistors which are connected to +5V overrule them... the Chips on the Dinx4 recognize 5V to 2,5V as high (cant say if this is true i think its arround 2,5V) and 0-2,5V is low my suggestion is now, take one off the 10K resistor out and replace it with a 100K resistors, measure again, and see the difference. about NG: maybe ZAM knows more... i am definitvly the wrong one for NG script ;)
Zam Posted August 6, 2023 Posted August 6, 2023 23 hours ago, ksir said: doesn't seem to work IIRC this is a global definition, not an event definition ! You have to put it only once at the beginning of your .NGC config file, it will set all SRIO to the specified value. Check to be sure but probably max value (65535) is way to much, like 30sec for 32 shift register ! that's a long time before being able to push a button again. You should be able to monitor the bouncing time of the button (via midi or debug), maybe there is more than one bounce actually, you'll see. Set the debounce time about twice that to be safe, or whatever higher possible value without feeling some requested fast push don't work.
ksir Posted December 3, 2023 Author Posted December 3, 2023 (edited) Hello, first of all thank you for your previous answers. I haven't fixed the problem with the pads yet. I'm focusing on another problem for now: with the LED rings. with 16 led ring of 16 led no problem. when I add more, the LEDs flicker. https://youtu.be/HyLkVeFtALw?si=gT09lbCxEwLRmHt8 I read here: http://midibox.org/forums/topic/21095-lre-4x1-breakable-rgb-led-ringrotary-encoder-pcb-bulk-order/?do=findComment&comment=184155 FantomXR had flickering problems, solved with a 10uf capacitor. Should I add a 10uf capacitor at the input of my LED ring cards? (as in the image below) (C129) To understand my configuration see the pdfs: LEDRING:https://drive.google.com/file/d/1XpDQBUE42IqXpXicO--B2gfIoNQDh5ga/view?usp=drive_link “power card”:https://drive.google.com/file/d/1NJ-H-QXD-tl9rU6nbYdEh2Q4jFqjWt6b/view?usp=drive_link I made a PCB that I call a “power card” that I supply with 5v 10 amps. The J2 connector of the "power card" is connected to J4b of core 32. Connector J44 of the first OLED card is connected to J3 of the “power card” Connector J45 of the first OLED card is connected to J4 of the “power card” Connector J44 of the second OLED card is connected to J5 of the “power card” Connector J45 of the second OLED card is connected to J6 of the “power card” etc.. Thank you Edited December 3, 2023 by ksir 1
ksir Posted December 16, 2023 Author Posted December 16, 2023 (edited) I tried adding a 10uf capacitor every 128 LEDs. I tried to connect dout of the last led to gnd. I tried to connect the end of the last LED to a 120 homs resistor. the last LEDs still flicker ( just for information I specify that I modified mios32\apps\controllers\midibox_ng_v1\src\mbng_rgbled.c line 116 : u32 num_leds = 15; // TODO: we could make this configurable! ) Edited December 16, 2023 by ksir
ksir Posted December 23, 2023 Author Posted December 23, 2023 (edited) J'ai approfondi mes tests. Si je ne connecte pas l'alimentation externe, je n'ai pas de problème avec le clignotement des LED. si j'ajoute de l'alimentation les LED clignotent voici comment je branche l'alimentation : (après avoir déconnecté le j17) le câblage est-il correct ? j'ai lu ici : http://www.ucapps.de/midibox_ng_manual_hw.html Citation L'entrée de données doit être connectée à J4B.SC, la masse à J4B.VS et +5 V à une alimentation externe. dois-je connecter j4.vs à une alimentation 0V ? et j4b.5v à 5v psu ? ( i use this PSU : https://secure.reichelt.com/fr/fr/bloc-d-alimentation-d-coupage-ferm-50-w-5-v-10-a-mw-lrs-50-5-p202960.html?&trstct=pol_4&nbc=1 ) Edited December 23, 2023 by ksir
Phatline Posted December 27, 2023 Posted December 27, 2023 (edited) maybe its the Ripple off the PSU about your PSU - reichelt specs is saying : "Ondulation résiduelle : 80 mVcàc" i guess this is not a 50Hz ripple but HF ripple... --- i guess some small cap (100nf, 10pF) and a big Cap (depends on the load, use for example a 100uF and a 2200uF) on the output off the PSU would reduce that "ripple"... * maybe that caps are not enough and you need some more filtering (coil, resistor, lpf...) but i would start with some caps... the connections in your 2nd picture are not necessery - i guess (dont seeing the whole picture, but i think so...) --- so picture 1 is correct. by the way - its only the last LED that flickers? maybe you have to terminate the DO line on the very last LED off the Chain with a 10K resistor to 5V or Ground. else it could be a software problem, when the software loops thru the LEDs, and when it comes to the last one it jumps to the beginning off the chain... try to programm in the ng code one more LED (which in reality not exists) - so you can be sure that this is not a software bug... - but dont ask me about ng-programming --- no glue about that. - mike. Edited December 27, 2023 by Phatline 1
