DavidBanner Posted April 5, 2006 Report Posted April 5, 2006 Hi,Firstly let me thank anyone who takes the time to read, reply and or help me with my project.I'm planning to build a mbox with the specs listed below and would like to check that I'm on the right path so far...DINs: 119 (115 buttons and 2 encoders)AINs: 64(21 faders, 41 knobs and 1 joystick)LEDs: 95I am planning to use the ain64_din128_dout128 application - it supports 64 pots, 128 buttons and 128 LEDs.Questions:Is it possible to stick 1 encoder and 30 buttons on the same DINX4 module?Does anyone know where to get "Led Diffusers" from? I want the ring shaped ones like Allen and Heath use on the xzone:3d, they are very sexy but I can't find anywhere that does them.Can someone please check the following diagram to see if I'm on the right track:thanks againD
Nu-Audio-Science Posted April 5, 2006 Report Posted April 5, 2006 I think as default it is setup to only support 64 buttons (Although it does support 128)So i'm guessing it's just a case of hacking MIOS a bit.I could be wrong though so wait till somebody else kicks in ;)
DavidBanner Posted April 5, 2006 Author Report Posted April 5, 2006 Hi Nas,Thanks for the reply - it's nice to meet you!Are only 64 buttons supported even when using the ain64_din128_dout128 application ??It says in the download section:ain64_din128_dout128_v2_0.zip - MIOS configured for 64 pots, 128 buttons, 128 LEDs - don't forget: all unused analog inputs must be clamped to ground!D
Nu-Audio-Science Posted April 5, 2006 Report Posted April 5, 2006 Yeah like i said, I'll be wrong.I got it mixed up with MB64 which is 64 only to be compatible with the old version :)Sorry bout that :(
DavidBanner Posted April 5, 2006 Author Report Posted April 5, 2006 Hey Nas,No problem, you warned me to dbl check ;)From what I gather this is the kind of place where everyone is meant to discuss and learn together right! I'm a complete newbie to this level of electronic design, I'm learning so much my head is spinning, but I'm loving every minute.D
stryd_one Posted April 6, 2006 Report Posted April 6, 2006 All looks great man :) Answers in order:YesNoYesGeez you made that easy hehehehFrom what I gather this is the kind of place where everyone is meant to discuss and learn together right!Right you are :) At least, I hope so, or I ask too many questions! I'm a complete newbie to this level of electronic design, I'm learning so much my head is spinning, but I'm loving every minute.Yep, that means you've been bitten by the bug :D Hope you have fun man, welcome to the forum!
DavidBanner Posted April 6, 2006 Author Report Posted April 6, 2006 hi stryd_one,cheers for the info and thanks for the warm welcome.>Yep, that means you've been bitten by the bug Oh no! I haven't even started soldering and already I have a bug! ;)D
illogik Posted April 6, 2006 Report Posted April 6, 2006 hey and welcome;just wanted to say that ain64_din128_dout128 application is an example application. i never built it, so i'm no expert on this, but looking at the main.asm (where the apllication is configured) this example is not as user friendly as the complete applications as for instance mb64, which is very similar (but has 64 buttons/leds max).compare the ain64_din128_dout128 main.asm to the MB64 main.asm, you'll see what i mean.also i dont know if it's easy to implement encoders in this app as in mb64 it is.not wanting to kill nice intentions, (and maybe you are just far better at this stuff as me) if you are sure you NEED 128 buttons, you could give it a try..but if i scared ya ;); take a look at mb64; you could have (if i'm correct):64 ain (pots faders joysticks)64 din (so maybe 60 buttons+2enc)64 dout (leds etc)then you could later even add another core which handles the rest of your buttons and leds (this is how the monster controllers in the galery are made)just giving you some options..good luck, marcel
stryd_one Posted April 6, 2006 Report Posted April 6, 2006 My 2c, I am never sure why anyone uses pots instead of encoders... For sliders and joysticks it makes sense of course...I must admit though, that's a whole lotta control surface you're talking about... Do you really need all that? What's the plan? I'm all curious ;)
DavidBanner Posted April 6, 2006 Author Report Posted April 6, 2006 >not wanting to kill nice intentions, (and maybe you are just far better at this stuff as me) if you are sure you NEED 128 buttons, you could give it a try..actually, I really want 134 buttons, but 128 is the max right? And yes I'm sure I need all of em.I'm building an ableton interface for Djing and live performances, I really need as much has possible at my fingertips, swapping between channels and params with a mouse just aint gonna cut it at 5am in a sweaty club with a skin full...I originally planned on building a 2 core beasty, but given that the app has been written it made more sense to go down the ain64_din128_dout128 application route.Do you think it's going to be hard getting everything up and running using the ain64_din128_dout128 route? I'd rather avoid anything that's too much of a head-fuck to configure on the first build. That's why I decided against a 2 core route, as I figured there would be lots more programming to do. I am sure I could handle the C code, but assembler scares me.>My 2c, I am never sure why anyone uses pots instead of encoders... For sliders and joysticks it makes sense of course...mmm, interesting. How would an EQ in abelton work using an encoder? The same way as a pot would?D
stryd_one Posted April 6, 2006 Report Posted April 6, 2006 mmm, interesting. How would an EQ in abelton work using an encoder? The same way as a pot would?Same way, the value of the encoder (0-126 aka 1-127) is stored in the app and the encoder increases or decreases it. There are lots of other tricks too, have a read about encoders :)
DavidBanner Posted April 6, 2006 Author Report Posted April 6, 2006 >have a read about encodersjust re-read the stuff on encoders, I had misunderstood originally. Now all is clear - ta!
stryd_one Posted April 6, 2006 Report Posted April 6, 2006 NP mate... There's a section in the Wiki, I forgot to link to it because I forgot that I wrote it already heheheh
DavidBanner Posted April 6, 2006 Author Report Posted April 6, 2006 >There's a section in the Wiki,yes, that's where I've been going to get info.I originally read that and took it to mean, that you'd map one direction to one button in the host app (ie ableton) and the other direction to another button - i.e. right turn does the up button, left turn does the down button.but on re-reading, after your comments, all is clear.I've just added a sentance to the end of your entry in the wikki explaining what you said....
stryd_one Posted April 6, 2006 Report Posted April 6, 2006 Glad it was of some help but sorry it was a bit confusing! Thanks for fixing it up man :) I was having trouble making it clear how it works, pointing out that it can emulate a pot is a good way of getting that across.
DavidBanner Posted April 6, 2006 Author Report Posted April 6, 2006 to be honest I think it was pretty good in the 1st place - can't blame my lack of knowledge on the wikki now can we ;)!I just changed it so anyone being dense in the same way I was might get there a bit quicker...
illogik Posted April 6, 2006 Report Posted April 6, 2006 Do you think it's going to be hard getting everything up and running using the ain64_din128_dout128 route? I'd rather avoid anything that's too much of a head-fuck to configure on the first build. That's why I decided against a 2 core route, as I figured there would be lots more programming to do. I am sure I could handle the C code, but assembler scares me.when i look at it, to me it looks harder to config. And i'm sure forum/wiki/people can help you with the 2 core option.(will cost you one core more though) like i said; the ain64_din128 is an example (can be used to learn and expand), the mb64 will probably have more user functions implemented and is more "ready to go"but please look in both main.asm files (especially the mb64 one) you can read em with any text editor; if you do this you know what i mean; configuring a "complete application" is kinda like a multiple choise quizhey; even i can configure it and i don't even know what coding is ;)but again, i'm not trying to make you choose mb64 over the other; just saying it would be good to compare.cheers
DavidBanner Posted April 7, 2006 Author Report Posted April 7, 2006 I'm not sure we are talking about the same app.There are 2 versions.Under Test Apps:ain64_din128_dout128_v1_3.zipand under Complete Apps:midio128_v2_1c.zipI'm talking about the latter, v2.1....D
Katch Posted April 10, 2006 Report Posted April 10, 2006 With regard the allen and heath diffusers;I love Allen and Heath, always have always will. I used to live in Cornwall in a place called Falmouth just a few minutes from A&H HQ. The staff and engineers their are more than helpful. Drop them a line via their website and request the LEDs as spares.
DavidBanner Posted April 10, 2006 Author Report Posted April 10, 2006 Hi Katch,Cheers for the tip - I might just give 'em a call.BTW: I'm talking about the diffusers not the LEDs. The diffuser is the ring shaped lens (aka Halo ring) that diffuses the light and makes it all sexy that the led goes underneath.
smashtv Posted April 15, 2006 Report Posted April 15, 2006 BTW: I'm talking about the diffusers not the LEDs. The diffuser is the ring shaped lens (aka Halo ring) that diffuses the light and makes it all sexy that the led goes underneath.Sorry to get off topic here....Any of the CAD boys want to discuss the design of some halo rings?It needs to be something I can mill from a sheet with only one flip of the workpiece. The cost of entry for injection molding is still way too high, but I have an NC mill collecting dust right now that could be converted to punch these out by the hundreds, even without an operator (small enough workpiece for a shaker feed!)Said design -might- also make it's way into the production Kombine controller, but that is not my choice to make..... ;)The perfect design in my eyes is something I could stock in the store with a 25 cent price tag. Any thoughts?BestSmash
stryd_one Posted April 15, 2006 Report Posted April 15, 2006 I know where you could find a buyer for them :) Wish I still had a good CAD app on here (and the long-lost skills to use it) ;)
drin Posted April 16, 2006 Report Posted April 16, 2006 Said design -might- also make it's way into the production Kombine controller, but that is not my choice to make..... ;)OK, hint taken. :D I've been waiting till your production duties slacked off before mailing you. I guess that's now? :)-drin
DavidBanner Posted April 18, 2006 Author Report Posted April 18, 2006 > The perfect design in my eyes is something I could stock in the store with a 25 cent price tag. yay Tim!Now you know I'll be putting in an order for some!Can't wait to get the bits I've ordered (order in process apparently) - I feel like a kid waiting for xmas! D
