It's working. :-)
I only have the first 4311 wired in yet, but today I was able to power it up and control the levels from a remote
MIDI console.
Sound quality is excellent.
Since I'm hand-wiring everything but the core, it's going
a bit slow, but it is going well.
I should have it far enough along to photograph and document it within a few weeks.
MIOS Rocks.
LyleHaze
  • Replies 232
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Congrats Lyle.  Looking forward to seeing the photos and docs on this one.
On a related note I found this page about a PIC controlled mixed using LM1973 chipos which are three channel digital pots.  They are using op-amps for output buffering.  The interesting part is the way the LM1973 could be daisy chained so one basic pcb could be designed and then any number of these pcb's could be connected to create the desired number of channels
http://www.andrewkilpatrick.org/mind/ir_mixer/
Looks good.
The PGA chips have the same connections. There's an enable
and clock that go to all, and data that goes from each chip
out to the next in.
I've been too tired to build boards this weekend, but I did some more work on the MIOS code. I've got two pairs built and working, and they are controlled by CC#7(Volume) and CC#8(balance) right now. The front panel encoder can also adjust them, and it sends out the same CCs to keep the controls updated. The channels are named, so when I tweak channel one it displays as "CD Player", channel two is my computer, etc.. Now I'm working on using the bottom line of the display as a stereo VU meter. I'm halfway through the display code for that.
I thought about putting the project up on the WIKI, but I'm afraid I'll screw up the webpage or something.
The board has been powered up and working 24/7 for over a week now. So far it's working solid and sounding sweet.
Time to go to work..
Lyle
hallo
i am very interested on this project, i use an external audio mixer while i spin with a pal (turntables vs. laptop figthing, that s the way we call it) and i d love to change the mixer for a digital mixer to control directly from my MB.Now does anybody of you thought about eq kill switch or eq pots? would that be possible to implement some filters and digital switches to be controlled via MIDI?
simone
Cimo,
I'm sure it could be done. My design is just a "line mixer" with nothing but volume and balance or pan (it follows both balance and pan controls). I'm thinking that a basic EQ is just a couple low and/or high-pass filters, each with it's own level control. That shouldn't be too tough. I tried to write the controls in a way that's easy to change around.
The PGA4311 does four channels, that could easily be Bass, Mid, Treble, and Main Level for a single channel. It'll take a lot more chips to get the job done though.
I need to get this thing posted to the Wiki so others can play with it a bit. I finished the meter code, all I have left is a way to adjust the balance from the front panel. I'm beginning to wonder if I'm putting too much stuff on a single encoder with pushbutton. :-)
I also need to finish building the boards. The first two pairs are working great, but I have parts, space, and the need for six more pairs. I guess I can post the project anyway, I'm sure it's working.
I'll try to get some more documents written at work tomorrow. The text is easy, but the schematics take more time to do. I could lay out Eagle boards too, but the more I try to get done, the longer it will take. Maybe I should post what I have already and go from there.
Time to sleep,
LyleHaze
hi lylehaze
when you will release the infos i could take over the whole (or part of it) eq stuff, i became quite familiar with eagle and i will have free time to toy around with it during the summer.
simone
Hi Lyle,
All that is really excellent news. Excellent.
I've just received the PGAs last week  ;D. I think I'll try to finalize my SEQ first, too much distraction now will make it shift further away again. But then sure I'll give that a try. I think of using such a stage as a mixer output for my quad SID to come and spare on inputs of my mixer console which is already too much crowded.
Best regards,
Lall
I've been busy with the software in the mixer.
Channels are now named. Local and remote (MIDI)
controls are working great. There's a cool
horizonital bargraph to show level and balance
settings for each channel, but I doubt it will
work with all displays. I need to put Pilos
Db display back in as an option.
Last night I changed the response from linear to
LOG. MUCH nicer feel to the controls now.
Oh, and I wrote a little app for my computer that
let's me create and send SysEx files to display
text on the Core display, just for fun.
I have built all the remaining audio buffers, and
I've started on the rest of the PGA4311 boards.
Now if I can just finish the boards, I'll be ready
to take pictures and post everything.
If anyone is waiting for the code release, just ask
for it. It's definetly far enough along to share if
anyone else wants to build an audio mixer.
all the while listening to "Back Against the Wall"
sounds great. ;-) MIOS Rocks!
LyleHaze
Great stuff :)
If anyone is waiting for the code release, just ask for it.
OK. Gimme! ;D I've been watching this and the PGA is on my bench waiting :)
@stryd_one
Check your hotmail.
And please, remember that I'm new here.
If you have any suggestions, I would LOVE to hear them.
Thanks,
LyleHaze
  • 3 weeks later...
In case anyone is interested,
http://www.midibox.org/dokuwiki/doku.php?do=show&id=midiboxmixer
The project is now online (with a little help from my friends);-)
The documents are not static, I'll be editing things around a bit to make it as easy as possible.
I welcome any suggestions on how to present the information better.
Also, there are some pictures in the end of the hardware section.
LyleHaze
Thank you, Lyle! Thats a great and especially very good documented project! :)
I will be propably one of the first users, as I already own the chips, mounted on a PCB and ready for use (@doc: thanks again! :)) - I'm planning to use MBMixer to mix the audio outputs of my MIDIbox SID, MIDIbox FM and the 4 CEM3378 filters with total recall capabilities.
The project is now also listed in the navigation bar of ucapps.de
  • 9 months later...
Hi all.
The midiboxmixer looks damn interesting!  :)
Iam thinking about how to use it with my analog console and remove the faders and replace them with motorfaders and replace the 10k pot of the fader
with 1/2 PGA2311.
Can I use 12 of the stereo PGA2311 to get 24 channels and control each channel seprately over midi volume control?
This could make a 24 channel flying fader automation together with 3x MotorFader Modules!?
I could use the volume automation of the cubase sequencer to record the fader positions...
Is it then possible to use the motofaders with touch sensors to record the fader moves into cubase while the midiboxmixer
will control the analog volume of every of the 24 channels of the console? (ok, i have to add a PSU and input buffers to
all channels of course)
Any ideas?
Thanks,
Frank.
ah... i don't think its a good idea to use one of these attenuators as a replacement for faders because of the zero detection...
I have a normal vca automation somewhere... i think i could use it. (controlled by the MotorFader modules).
Or use the AOUT Module to control a vca.
Would be much better, or am I wrong?
Thanks,
Roelli.
The purpose is:
If I use the digital potentiometer in audio volume control, will I experience zipper noise?
There is a noticeable zipper noise. However, we have developed an external zero-crossing detector that effectively reduces the zipper noise. Please refer to AD5290 datasheet Audio Volume Control section
for synth usage I would definately forget about it.
Here is how you make CV controlled VCA (definately employed in mixers , look at patent filled by Sony itself, think of the Oxford mixer fame  )
http://tinyurl.com/36vrq7
http://www.thatcorp.com/datashts/an102.pdf
judging by the popularity of this topic , "analog saturation" isnt the magic word around here LOL!!! You ppl should definately look at what comes out of the back of an analog mixer, its full of added harmonics. With these PGA specs in mind , you might as well sum in digital realm , 1+1 = 2 !!!!! sorry im drunk
I'm glad the mixer looks interesting.
It's been in use daily since it was first released here.
You asked about using Motorfaders AND PGA chips.
Yes, I suppose you can, but usually (if I understand you right) you would use one or the other.. Motorfaders alone can do volume control without PGA chips.
The reason I went with the PGA chips is that there are no moving parts, and no pots or switches to get dirty over time. So the performance should be just as quiet in ten years as it is today.
As far as sequencing a mix, yes, absolutely! The current
software provides for up to sixteen stereo pairs, handling volume and pan for each pair. Of course you can change this, but I wanted it to match the sixteen channels of MIDI, so I went with the more obvious route. I can currently mix from a board of encoders and from my sequencer and use presets from a script file, all active at all times. It's really handy to type "mute" into a command shell and have all the audio drop out instantly.
Zipper noise? Yes, I've heard it under some extreme conditions, but it's not a big problem unless your final amp gain is set way too high. (which may be normal for some people ;-) )
The PGA chips have a zero-crossing option built in.
Anyway, yes, the board still works, and sounds pretty darn good, too. If I can be any help, just ask.
LyleHaze
yeah, pretty much. The choice is yours. You want to employ the zero crossing trickery , or you want to employ the voltage out DAC for CV. First is transparent, second is conventional and can we say, universal. Take your pick!
I keep coming back to this project as being a great centerpiece for my rig... Great work guys!  ;)
Just thinking aloud.... Not being a hard core programmer type, how hard would it be to address the individual PGA channels separately? My needs for a submixer aren't vast for my live rig, so probably 8x stereo channels would do the job. What would be nice, however, is to wire another 16x mono channels as mono effects sends (send 1 and 2 per channel - or perhaps one single stereo send?).... How difficult a job would this be?
This might also be helpful for those who may want to save some PGAs as they have mono gear, as some PGA channels can be configured as mono inputs....
Also, I recall TK talking about this awhile back.... does the software currently have facility for storing scenes?
Gav.
Yes. mono controls would be a simple change.
Right now the table of stereo settings (volume and
balance) are read and converted to a table of 32
monophonic levels. These are then changed from
linear to log and then they get sent out.
You could simply maintain the 32 levels directly
and everything would work, with or without the
log conversion.
For scenes, Pilo has written a single frame
snapshot routine that could easily be extended.
I'm not using it but the code is included.
For panning a mono signal into a stereo pair, it
would be easiest to feed the signal into the stereo
design and just use the balance/pan control for
position.
LyleHaze
Wow, Looks great!
I have been trying to get around to doing a board layout
in Eagle, but there's never enough time.
If I can make a few suggestions:
There should be pull-down resistors between each SDO
and SDI pin.. and there should be about four capacitors
for each PGA chip. I can send the datasheet with that
stuff shown if you want it.
If you are having boards made, PLEASE let me know.
I'd love to have a couple made for me too, if I can afford them.
Yes, you can add this board to the WIKI if you want.
Maybe we should wait until we have one built and working.
Thank You,
LyleHaze
Yes, I'll make these changes in the layout these days. I hope that I will find some time soon to etch a test pcb. I already have some 4311 lying around :D .
I'll pm you my email address so you can send my the datasheet. And of course you will be the first who gets the pcb ;) .
greetz
