dietmar Posted November 9, 2006 Posted November 9, 2006 Hi all,I'm working on a midibox LC. My problem is the Core module.I've loaded the Mackie emulation program to the PIC with a picprogrammer but I can't get the 10Mhz Oscilator working.All voltages at the PIC are correct. What can I do?regards Dietmar
moxi Posted November 9, 2006 Posted November 9, 2006 hi,are you sure that the problem come from the crystal?you say:I've loaded the Mackie emulation program to the PIC with a picprogrammerbut you don't have to use a pic programmer to upload the MIOS and the app, you only need a pic programmer to burn the "bootstrap loader", then you can upload first the MIOS thru a standard MIDI interface, and one time the MIOS is correctly uploaded ,you have to upload the MIDIbox LC application via MIDI too..
dietmar Posted November 9, 2006 Author Posted November 9, 2006 I've burned the LC emulation for mackie control and nothing else.Do I need the bootstrap loader? I thought that the LC emulation is a complete softwarepackage and it don't need anything else.I'm testing the core module in a Lab, but I don't have a PC with midi interface here, so I burned the software via PIC programmer.
moxi Posted November 9, 2006 Posted November 9, 2006 do you use a pre-burned PIC from Smash-tv shop or Mike's SHOP?you can't burn the app with a burner, only thru MIDI.So, the steps are:1. if you use a blank new PIC, download the bootstrap loader on Ucapps.Burn it with your pic programmer.if you use a pre-burned Pic, go to step 22.one time the bootstrap is burned , upload the MIOS via MIDI3. now you can upload the app, via MIDI too.but maybe, if you are using a pre-burned PIC, the bootstrap loader have been overwritten when you burn the app with your burner, check if you get the right request in your MIDI monitor...
HL-SDK Posted November 9, 2006 Posted November 9, 2006 You build your own board, or using a kit/someone's design?
DavidBanner Posted November 9, 2006 Posted November 9, 2006 sounds like you need to go back and do some reading!
doc Posted November 9, 2006 Posted November 9, 2006 I thought that the LC emulationis a complete softwarepackage and it don't need anything else.You're right. The LC emulation is a complete application for MIOS ... not for the PIC.In other words: First load the operationg system (MIOS), then the application (LC)greetsDoc
doc Posted November 9, 2006 Posted November 9, 2006 man, you're double posting ....see your other thread for the answer.greetsDoc
smashtv Posted November 9, 2006 Posted November 9, 2006 man, you're double posting ....see your other thread for the answer.greetsDocDouble posting=bad....I merged the two threads here. ;)
