The making of LX's MidiBox
Hi mikeb
No, only modules on the pictures and LTC module. My next board are same (on principle) but bigger, intricacy and I combine DIN, DOUT, AIN to one board.
B.R. LX
  • 3 weeks later...
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
omg.. that baby is beautiful.. :o :o. I think I would trade my g/f for that...
(If I had one  :P)
Midibox of the year 2007?
(btw. what was the MB of the year 2006?)
matthias
This is by far the most professional MIDIbox design I've seen! Congratulations! This fit's into my understanding of professional work.
Cheers,
Skunk
  • 4 weeks later...
  • 2 months later...
Wilba, I must say that Multimec switches looks great but they are pretty much stiff and have loud click. Overall feeling is not so nice, or to be honest, I was pretty much disappointed when I received some samples from Multimec. Anyway, quality is very good. I wanted to buy just caps and glue them on the other buttons that I like. The black ones that Ladislav uses for triggering the Live`s clips have really nice feeling.
I like them for like "left/right-arrow"-functions... for stepping through a menu (e.g. Navimec... which are actually only the caps. - The switches used for Navimec are Multimec). Using them for Channel functions I made exactly the same experience like Sasha. - Not nice.
Greets, Roger
  • 3 months later...
  • 6 months later...
I forgetting this topic for long time  :-\ but my time is the reason  ;)
So, there is some news and my possible construction solution...
I finished all my BUTTONS modules
I finished all my ENC modules
Some additional boards
I prepare bottom metalplate box
And Im still modifying front panel for next control solution before final cutting plate
And my last idea is this...
To this idea takes me Sasa. Thanks! I saw your design development of front panel where was Idea with LEDbars near his faders. He explain it like pointers of pot value (instead of motorfader). I use only 2 LEDs for indicating direction of difference between virtual and real position of fader. The LED which indicating direction will be flash different speed acording to value of difference from virtual position. >> value 128 - still light, 96 - most slow flash, ....., 01 - most quickly flash. Than I know how quickly I must turn pot to right position = difference is 0 -> start sending event and indication LED switch off.
This indication function I can control by one button >> switch on(show differences)/switch off (disable function)
I can have 16 tracks instead 8 => 2 groups by 8 faders.
I will be less cry becouse I havent motorfader  ;)
Same principle I want to use for knobs. left/right direction
There I hide SMD LEDs under knobs cups, becouse meny visible leds aroud knobs is make layout more blind. Light will be shine through gap between cap and frontpanel. I test it and it looks like very decently.
I havent still user program for it but I know aroud way how to do it. Now I must more study TKs asembler technique  :)
Best regards
LX
Amazing!!! So much fine work, and took so much time to do it. It is pure pleasure just to look at it! :)
Can`t wait to see it finished. Seams not much left to do.
I`m glad I inspired you for those LEDs ;)
"2 LEDs for indicating direction of difference between virtual and real position of fader. "
That's a great idea! Boards look pretty as heck too, nice work man!
Very nice work and beautiful boards!
But I can't suppress the comment, that i find "LEDs for indicating direction of difference between virtual and real position of fader. " a little bit stone age. I remember the time almost 20 years ago, when I had to work on VCA controlled desks which all had this "direction thingy" and it was a pain in the a.. to work with it.
But again: Great work... and everybody has his own taste in intuitive features.
Greets, Roger
Yes you are right  :-\
I was start my project 4 years ago and I didnt knew if I finish all my plan. therefore I didnt pay a lot of money for motorfader. Now when I would be start project again I use motorfaders definetely. So I try to modificate my box to motorfader for two month but I dont find any Panasonic MF it is good for my box dimensions. I get only ALPS but these are too big and I would be make again my FADER boards. I plan anyway use faders for punch in-out tracks and for it is LED indication suffice. So, anyway I regred it  :'(
BR
LX
  • 4 weeks later...
Hi all
So, I still thought about my faders and switching groups (track 1-8 and 9-16). Well, OK I go to the motorfaders!
It means more time, money, more screws in frontpanel, next core, different power supply and wasted finished FDR boards, but result will be more fine ;)
I can make better boards, because my experience is at higher level since the time when I design FDR boards.
I change buttons near the faders too. MEC buttons looks good but the functionality is worse (hard press, strong click). OMG, so much money I must pay for them :-[ I hold only caps but buttons will be different (my favourite button, which I use for starting clips). Sasa told me this solution any years ago and he is right.
So, watch the progress at http://lx.vanuatuss.org/index.php?pg=news&lang=en
LX
  • 2 months later...
