I'm in the process of developing a very simple pattern sequencer that supports up to 256-measure long tracks.
I was wondering if anyone here had any C examples of sequencers of any kind that they'd be willing to share? I will document this project and post the code.
My first version will simply play back pre-loaded patterns - so I don't need any pattern-programming capabilities yet.
(31cmx17cmx10cm)
Here are the specifications:
1. 2 independent sequencers, one of which can be slaved to the other.
2. Each sequencer will be able to load one "song" at a time. A song is chosen by the push-button rotary encoder.
3. 16 sections per song
4. 6 tracks per section that can be muted or unmuted with the track-mute buttons (more than 6 tracks could be implemented, but that's all I need)
5. 256 measures per track  - this is where this really differs from the Midibox Seq
4. Components:
2x Cores
2x AIN
2x DIN
2x DOUT
2x 16x2 PLED - $21 US each http://home.swipnet.se/ridax/connector.htm
1x case - 14,50 euro  http://www.reichelt.de/?SID=22Qq-CFn8AAAIAADkJaHM6632e15d52ed8ada3ec8c009a7e3b932;ACTION=3;LA=5;GROUP=C712;GROUPID=3354;ARTICLE=21189;START=0;SORT=artnr;OFFSET=16
20x knobs - $0.35 each http://futurlec.com/SwKnob.shtml
20x pots - $0.50 each http://futurlec.com/PotRot.shtml
52x buttons - 0,35 euro each from http://www.pollin.de/shop/tabelle.php?ts=0&pg=OA==&a=OTU4OTA5OTk=&w=NDk2OTk4
2x push-button encoders - 0,75 euro each from Pollin.de
The total cost is roughly 180 euro. You can save 20 euro by getting LCD's instead of PLED's.
I've already ordered everything and the hardware should be finished next month. Then comes the hard part :) I'll be posting build pics next month.
cheers,
michel
ps. Thorsten - You'll be happy to know that I changed the pot spacing so there's 3cm between each post!
Oh I forgot to mention why I'm building this:
I perform live electronic dance music for a living and want something lighter to replace my aging RM1x.
I currently use a Yamaha RM1x to sequence Kontakt 2, which is loaded with 6gb of my home-made loops and samples. The pots control various effects and scripts in Kontakt.
In the top right, you can see my tiny silver PC that weighs only 2kg. When I turn it on, it automatically loads Kontakt with all my samples - so I don't need a monitor, keyboard or mouse!
(and that lil' red box is my little Midibox Clockbox that syncs up all my sequencers :) )
I remember that I enjoyed your two live recordings months ago. Do you offer new ones for free download in the meantime? :)
A good start would be clockbox, then define some struct to hold your (timed) midi events.  I believe clockbox keeps track of bars/steps, which you could use to index your array of events.
th0mas - i agree! that's exactly what i've been doing: i built a clockbox and customized it a couple of years ago - now comes the fun part.
TK - i'll post some more "uCapps-enabled" live performances soon :)
Update:
Here's what's left to do:
- install LED's
- finsish panel wiring
- finish software *heheh*
I really wanted to paint the front panel black but I simply don't have time and I have 7 gigs coming up... plus it's really irritating to do a few coats of paints and a clear-coat and then suddenly some holes are too small for pots & buttons.
I`m sure kids would love that box. :)  Bit colourfull for my liking but still cool. I like those yellow pointer knobs. Where did you get those?
i decided the silver was too distracting so i'm going "the extra mile" and painting it black today.
re. knobs - futurlec.com (i posted a link for all my parts at the beginning ;)
re. colourful - you're the second person be pointing that out  ::)
honestly, when you're performing in a dark club, it really improves the user interface if you only have to quickly glance to see what find a button or knob. for example, i've got knobs permanently assigned to things like chorus, flanger, phaser, delay, lo-pass, hi-pass, bit crusher, etc... hence the very specific colour-coding. sorry to get a bit defensive, but i perform live for a living and this particular user-interface design is backed up by 10 years of experience 8)
Hey sneak, I already checked your links but there is no knobs I see on this picture:
Dont you worry about my comment, I am slave of colour minimalism. :P  For club useage color coding makes much more sense.
ahhh, those knobs! they're for my DIY-modular.
those are RE-AN Softtouch knobs as seen on many Euro-Rack and Frac-Rack modulars. I bought them from http://www.Rapidonline.com for 0.08p each.
This is the direct link:
http://www.rapidonline.com/productinfo.aspx?kw=soft%20touch&tier1=Tools%2c+Fasteners+%26+Production+Equipment&tier2=Fasteners+%26+Fixings&tier3=Knobs&tier4=16mm+soft+touch+knob&moduleno=64710
update - i'm thick in the middle of programming it... ugh ;)
midi clock is sending, tempo & transport controls are working, buttons respond to section changes and pots transmit midi cc's.
still have to finish implementing song loading, track mutes and reading sequences from arrays.
wish me luck!
uhhh, i think i'm going to have to drop the voltage to the blue led's or do some PWM tricks 8)
Hhehehe I think it's interesting that we've taken a completely different approach - you built hardware first, then software - I'm the other way around :)
What kind of format are the songs? Is it linear or step based or..??
In my case, it makes perfect sense to design the user-interface first because the software can easily be modified to fit my workflow.
Software Description:
Over the last decade, I've written all sorts of material (over 100 different songs, some completely finished, some very raw) on my rm1x and rs7000's in pattern-mode.
Pattern-mode consists of up to 16 sections, each having 16 tracks. This is the basic sequencing paradigm that i wanted to use.
For my live performances, I need control over groups of tracks and not each individual track. Look at the following typical example on my rs7000:
Track          Instrument
1                kick
2                snare
3                hihat
4                claps
5                rides
6                other percussion
7                vocal samples
8
9                bass
10              melody 1
11              melody 2
12              pad
13              sfx 1
14              sfx 2
15              sfx 3
16
Since it's more efficient to control instrument groups, I spent a month recording *all* of my studio synths and samplers and broke down songs into various 1-16 measure loops, so now the typical track looks like this:
Track          Instrument
1                kick
2                all other drums
3                bass
4                melodies 1+2, pads
5                vocals
6                sfx 1-3
So, this gives me the ability to improvise with song structure, as well as being able mix & match parts of various songs in order to create a spontaneous live performance, albeit with bigger building blocks than your traditional midi sequencer.
However since I also use my rs7000 live, I still have very fine control over midi notes and such with one half of my setup.
The other huge benefit of all the sampling is that I don't have to bring as much gear when I perform, and yet Kontakt's scripting language is very powerful and allows me to retain the expressiveness over how the samples are played back.
The most important aspect is being able to respond to the dancefloor, and this setup accomplishes that nicely. The hardest part is finding a balance between automation and ability to control.
This is a really interesting concept man. Sounds like musical lego made from homemade bricks ;D
I think it oughta be in the User Projects forum if you feel like documenting it on the wiki too :)
Heya bud.
Try these. I've broken that notorious switch statement down so as to make a nice clean jumptable. The app now uses five temp variables instead of 37, and doesn't flip around like it used to. 25-26 should work now :)
This is definitely the way to go with switch statements in SDCC.
Let me know :)
Edit: Does 'i' really need to be an int?
mclock.h
mclock.c
mclock.h
mclock.c
nice one! it works great - thanks :)
it's official - i ower stryd_one a beer (or a reasonable equivalent or facsimile thereof)
you're down under right? i'm trying to get an oz tour together so i'm dead serious!
Wicked  :D I'll take a mineral water at your Melbourne gig heheheh
Maybe one for after the gig, but I'd do that with your other switch statement in main.c too...
Thanks for being thrashed by this "feature" so we don't have to!
here's the fully-functional source, complete with all my song data *lol*
http://www.sneak-thief.com/sneakyseq/sneakyseq%20v1.zip
cheers to TK, stryd-one, mess, audiocommander and everyone who helped!
FYI - Timeline:
I planned a rough draft of the algorithm last year, but since then only spent a few hours here and there doing the user interface (which to me is the most important).
I only seriously decided to build it last month, then I sourced all the parts and received them a couple of weeks ago. I spent 8 days building the hardware and another 7 days to get the software to a working state.
I feel like I've been shot through a cannon!! :P
best regards to the midibox cru,
michel
ps. mineral water is fine with me too because i don't drink at gigs :)
