jensah Posted April 10, 2007 Report Share Posted April 10, 2007 I've started to build a FM module, but i got smd tl074 and a "standard 2 pin" 14.318Mhz crystal.Have anyone made a circuitboard for thoose components?And is it possible to use wall-wharts instead to make the +-12v (or prefferably lower). Quote Link to comment Share on other sites More sharing options...
doc Posted April 14, 2007 Report Share Posted April 14, 2007 I've started to build a FM module, but i got smd tl074 and a "standard 2 pin" 14.318Mhz crystal.Have anyone made a circuitboard for thoose components?The SMD tl074 would work, but you have to make yourself a pcb for it, I think.For the crystal I am not so sure. There are some differences between the crystal-types, so I'm not sure, If yours will work.In theory you could use two (DC-) wallwarts to get +/-12V. Not a recommend solution, but it would work.greetsDoc Quote Link to comment Share on other sites More sharing options...
aeiou42 Posted April 14, 2007 Report Share Posted April 14, 2007 This page here describes how to build a +/- power supply from a AC-AC wallwart.http://electro-music.com/forum/topic-12968.htmlI think this is the kind of wallwart he recommends to use.http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=100061&pa=100061PSWould someone else like to double check this and make sure it would work? Quote Link to comment Share on other sites More sharing options...
jensah Posted April 14, 2007 Author Report Share Posted April 14, 2007 Yeah, the AC adapter solution seems to be working. And as far as i've read the crystal wont work.And my question was if someone had made a SMD tl074 PCB allready or have the brd file so it's possible to change package. Quote Link to comment Share on other sites More sharing options...
napierzaza Posted April 20, 2007 Report Share Posted April 20, 2007 Maybe you can just figure out adaptors ? Little PCBs that convert the SMD to DIP Quote Link to comment Share on other sites More sharing options...
/tilted/ Posted April 21, 2007 Report Share Posted April 21, 2007 Maybe you can just figure out adaptors ? Little PCBs that convert the SMD to DIPSuch things are available. Try google, or try here (google's first reply):http://www.advanced.com/soicstart.html Quote Link to comment Share on other sites More sharing options...
