  • entries
    13
  • comments
    11
  • views
    16,289
MB64e control surface
Today I etched a few more PCBs. Now the control surface is complete. Or that is - I haven't yet soldered on most of the cables on the new boards, but components are soldered, backlight on the menu encoder is tested, ok (looks good as expected hehe) and I laid it out on the workbench to see how I want the frontpanel to be. I think I'm gonna use this setup here, unless I get any bright ideas or any bright tips :).
It has 8 general purpose encoders, 8 general purpose buttons, encoder for left/right navigation, it got the enter button (besides the menu encoder, and it got the snapshot button by itself - on the same pcb as the enter button :).
The buttons is just the same as in the mb6582. I have looked around the net (especially on ALBS) and found many very cool tactile switches that I could easily used for this box, but the reason why I used these buttons is that I had them in my drawer NOW, and I had a lot of em, so I figured - simple and fast - no waiting for parts etc etc. so that's why the buttons are rather boring - but I suspect they'll do the job anyway hehe.
In addition - its gonna have 4 analog inputs on the back (via mini-xlr) - for expression pedals mmmmmmmmmmmmmmm. Since I have only one pedal now, I have to have a way to ground the unsused input easily without opening the case - so I have ordered in a bunch of dip-switches. I have thought and thought, and I think this is a cool solution - dips available from the back panel. Makes it easy to "program" when I need it, and hard to accidentally operate :).
It got the 16x2 LED - wich has green letters on black background, and green backlight for knobs.
Any day now, the Core8, AIN, DIN and a bunch of other goodies are dropping in my mailbox from smashTV, and once I get those, I can wire everything up and actually test it. If everything works in a satisfying way, I'm building the case next - I'm doing it simple - just bending some alu plates and put together. Give it a coat and 10 of cool paint, and we're there. If I come across a case I can use, I'll do that instead of making my own - wich takes long time even if it's simple design.
Well, enough talking, lets see the picture :). - yes there is only one today :P.
blogentry-8299-0-44657900-1337030977_thu
0 Comments
