All Activity
- Today
Here are the files. If someone could post them to the appropriate location that would be great as I do not see an upload function on the page that Smithy linked to. The front panel was created in inkscape and needs this font: https://www.1001fonts.com/bitwise-font.html The knob_base.stl works with Davies 1900H (and clones) style knobs. This is the only part I printed with a very high resolution of 0.08mm layer height. The rest can be either 0.16mm or 0.20mm layer height, or personal preference. The LED_spacer_standoff.stl's purpose is to hold a series of LEDs in place while soldering so they are the exact height for the PCB_spacer.stl and top_panel.stl. You can slice it in half for fewer LEDs or just print more for the bigger runs like on the mod matrix. I printed out quite a few since they are so tiny. For the top panel: 3D printed face down on a "carbon-fiber style" steel plate to get an interesting design on the top to shine through the vinyl sticker, so that was just personal preference. I printed the SVG 100% (no scale) on a color inkjet printer onto a vinyl adhesive/sticker (https://www.amazon.com/dp/B0BVMZMWCY), applied carefully to top_panel.stl and then just used an exacto to cut the holes out and trim the extra off the sides. Then placed it onto the unit, a small drop of super glue in each corner or thin double stick tape would work also to hold it in place. Then I used superglue to add the knob bases, then the knobs themselves. Hope this helps :) MB6582_STLs.zip
- Last week
Apologies everyone I just saw these messages. I will make a note of gathering the files tonight and uploading them to the appropriate section here (Thanks Smithy). Thanks everyone for the kind words :)
Hi bro.. I have the same problem. Can not find parts, especially front panel pcb. I am even thinking of reverse engineering it by a picture (here is a good one 2 layers perfect distinguishable) Pleae let me know if you find something
Hi! Wow, well done! Could you please share printing files here?
- Earlier
stuartm changed their profile photo
m00dawg started following Using ARM2SID with MB6582
Late to respond but thought I would offer my $0.02 based on my 6582 experience. I was using a custom PSU with it, both for real SIDs and a pair of ARMSIDs. The problem I was having was a bit of 5V droop due to the cable length and my power connector was a bit sketch. So I've since converted it over to the switching 7805 regulator method which seems to be working for both ARMSIDs and real ones. One thing I really like about real SIDs is they can offer a sort of chorus in stereo mode due to differences in each chip. I don't get that with ARMSIDs. On the MB6582 I plan to always run both. I believe you are correct, though, that the ARMSIDs only need 5V though there isn't much harm in keeping your 9/12 rails if you want to populate real SIDs at a later date. The switching PSU method does require changing things around a bit. It can be reverted but not easily, although it can be made to work with 6581 or 8580/6582 SIDs (and ARMSID) which might be worth a look if you're not already running this option. I do find being able to choose between them is really nice. The real SIDs, sure they're noisy, but the filter sounds better and you can mitigate the noise with a gate. When I'm doing a lot of filter stuff or just want that chorus/phasey kinda sound, I'll reach for them. Otherwise the ARMSIDs are less fickle. I do wish we'd see an update to the MBSID firmware to support some of the enhanced ARMSID options but I've been quite happy with them and plan on picking up more (once retrocomp.cz is able to ship to the US again). I recently busted out my sammichSID again while the band is considering live shows so my current ARMSIDs are stuffed in that guy.
[FS] Core8, SID, DIN, DOUT, Ultracore, I2C DIY stuff
forestcaver replied to rosch's topic in Fleamarket
If you still have the i2c quad midi board I’d be interested please. -
-- Display MIOS32_MIDI_SendDebugMessage() messages and transmit data/trigger functions -- this prints to the Touchosc Log window, as well as to a text element called "text" local MIOS_MSG = root.children.text -- <- this text element must be in root, or simply change this adress function log(msg) print(msg) text = msg.. "\n" .. text --text = text .. "\n" .. msg local count = 0 MIOS_msg_lines = {} for line in text:gmatch("([^\n]*)\n?") do if line == "" then break end table.insert(MIOS_msg_lines, line) count = count + 1 if count >= maxLines then break end end text = table.concat(MIOS_msg_lines, "\n") MIOS_MSG.values.text = text end -- messages in the form of "Start .. ID .. list of numbers seperated by spaces .. End" can be used to transmit data to TouchOSC and call functions local MIOS_SYSEX_COMMAND_FUNCTIONS = { -- numbers from mios are 0 based! MyFunction = function(numbers) print(#numbers) end } function Do_MIOS_Sysex_Command(ID, numbers) local fn = MIOS_SYSEX_COMMAND_FUNCTIONS[ID] if fn then fn(numbers) end end -- sysex message handling local sysex_buffer = {} local last_sysex_time = 0 local sysex_timeout = 200 -- ms (adjust if needed) function flush_sysex_buffer() if #sysex_buffer > 0 then local msg = table.concat(sysex_buffer) sysex_buffer = {} log("MIOS32 (timeout flush): " .. msg) Log("[TIMEOUT] " .. msg) end end function onReceiveMIDI(sysExMessage) local now = os.clock() * 1000 -- ms resolution -- if too much time passed since last byte -> flush old buffer if now - last_sysex_time > sysex_timeout then flush_sysex_buffer() end last_sysex_time = now local headerLen = 8 for i = headerLen + 1, #sysExMessage do local b = sysExMessage[i] if b == 0xF7 then -- end of SysEx, flush buffer as a complete message local msg = table.concat(sysex_buffer) sysex_buffer = {} local ID = msg:match("^Start%s+(%a+).-%d+.-End$") if ID then local numbers = {} for num in msg:gmatch("(%d+)") do table.insert(numbers, tonumber(num)) end Do_MIOS_Sysex_Command(ID, numbers) else log("MIOS32: " .. msg) end else if b ~= 0 then table.insert(sysex_buffer, string.char(b)) end end end end
hey, 2 years later again... i'll have a look, next week i got some holidays. should still have some of that stuff somewhere. sorry, i haven't had a functional diy space since the covid times, moving etc, got to dig through my boxes next week
Simultaneous bank and program change messages to several cores
jjonas replied to jjonas's topic in MIDIbox SID
I have the same problem with Rosegarden (and midi files generated by it) sending simultaneous Bank and Patch Change commands to multiple cores on the MB6582. Right now the solution is that I send Bank and Patch changes only to cores 2-4, and only a Patch change command to core 1. That way the sounds to be played seem to be selected correctly, and if core 1 needs a bank change, I will have to remember to do that manually. If I add the Bank Change command to core 1 as well, the patches get messed up as described above. If there can be a solution to this problem, I'm willing to test different combinations, attach midi files which replicate this etc. -
Hi, seems ok to me... you have to go through all the voltage checks before inserting SID modules (look in the mb6582 wiki). Then test 1khz tone check and you may load the troubleshooting apps in the MIOS8 download section.
I have a function that does some heavy floating point math (calibrating solenoids to a nice midi velocity response). It works, but is slow. The STM32 does seem to have an FPU. Is it enabled in MIOS32? If not, how can i enable it in my application and make the compiler use it? Thanks!
Drakon started following First build of MB6582
Hello everyone. I'm new to the forum and I'm currently building an MB6582 for the first time. I have almost all the components in place, but I have a question for more experienced users: could you take a look and see if everything is OK before I connect the power supply and start testing? I decided to use the power supply option "E" from this thread: So, the changes are: - no B1 rectifier installed - no C14 and C13 installed - C3 is 10uF instead of 2200uF (and here I don't know what the voltage of this 10uF capacitor should be) - V4 is a Recom R78B5.0-1.5 - V1 is a 7809 - as I understand from the documentation, if I only use the 6582, I don't need to put a 9V switching regulator here (Recom R-78C9.0-1.0?) - pin 2 and pin 3 of J71 are connected by a jumper - pin 2 and pin 3 of J72 are connected by a jumper - pin 1 and pin 2 of J73 and pin 2 of J74 are connected by a cable under the board - jumpers installed at J1_SIDx and J2_SIDx in the 9V position Am I good to go further? Don't worry about the dirty board; this is before cleaning. Many thanks in advance!
Hello Midibox-Forum, a long time ago in a galaxy not so far away I built a unit of the Midibox SEQ based on my own design for the user interface. It was the year 2005. A few years later the microchip was upgraded and replaced by the LPC17-based core module, thats why the backside of the housing was adapted but unfortunately I never finished the housing. The bottom side just has a plexiglass cover, so you can actually have a look inside the DIY electronics and all the boards and solderings :-) Now, as I own a "new" Midibox SEQ from Midiphy, it is time to give away the "old" Midibox SEQ to someone who wants to play around with it. The price is simply depending on your bid. It is currently fully working, just the behaviour of the encoders is not perfect, sometimes a encoder skipps a few steps and also some of the buttons need to be pressed with a bit more force. As already mentioned the case was never finished, so if you wand you can rework the case. The design was originally done by a company called Schaeffer, the company still exists today and so the housing "system" can be ordered if you like, here´s the link: https://www.schaeffer-ag.de/frontplatten-designer# You can find the Midibox on the Kleinanzeigen website - the text is in German but I will also ship the box in Europe if necessary. https://www.kleinanzeigen.de/s-anzeige/midibox-seq-v4-midi-step-sequencer-diy-fuer-einsteiger/3158249168-74-6800 If you have any questions just send me a message on Kleinanzeigen, as I will check this regularly.
Glad you got it sorted! You even coaxed @nILS back to the forum! Welcome back!
Thank you very much, Ronald! That was exactly the reason why the LED wasn't lighting up. Now it works!
After some digging/debugging, it turns out we need to set the following variable to '1' to have this 5th LED working: DEFAULT_MB6582_CS I found this out by this table in src/cs_menu_leds.inc where the fifth bit (reading from right to left) is only set in the first 'if' routine: CS_MENU_LED_LFO_Wav_Pattern andlw 0x0f ; 16 entries JUMPTABLE_2BYTES_UNSECURE retlw b'00000001' ; Sine retlw b'00000010' ; Triangle retlw b'00000100' ; Saw retlw b'00001000' ; Pulse retlw b'00010000' ; Random #if DEFAULT_MB6582_CS retlw b'00100001' ; Positive Sine retlw b'00100010' ; Positive Triangle retlw b'00100100' ; Positive Saw retlw b'00101000' ; Positive Pulse #else retlw b'00010001' ; Positive Sine retlw b'00010010' ; Positive Triangle retlw b'00010100' ; Positive Saw retlw b'00011000' ; Positive Pulse #endif retlw b'00011111' ; reserved retlw b'00011111' ; reserved retlw b'00011111' ; reserved retlw b'00011111' ; reserved retlw b'00011111' ; reserved retlw b'00011111' ; reserved retlw b'00011111' ; reserved
I have still exactly the same 'issue'... From another place in the manual ( LFO section ) http://ucapps.de/midibox_sid_manual_l.html Wav (Waveform): selects the shape of the LFO. Following waveforms are provided: Sine, Triangle, Pulse, Ramp (Sawtooth), Random (Sample&Hold), and positive Sine/Triangle/Pulse/Ramp So I would indeed expect the 'positive' LED to be lit (new style?), in stead of the multiple leds (old style?) when selecting the other waveforms in the active/selected LFO... Will be doing some more investigations in the ASM configuration file, as it seems to be another setting :-)
I looked at exactly the same thing and thought the same thing. But since the firmware is relatively old and I couldn't find anyone else whose LED wasn't lighting up during my search, I thought it couldn't be the firmware. That's what I'm thinking too, but where do you turn this feature on? For me, for example, Sine+Random light up at the same time when I have a positive Sine LFO waveform. That's how it's explained in the manual. You should be able to turn off this display feature and turn on the separate LFO positive LED, right? It is installed in many MB 6582 models. (Picture attached) But when I compare the ASM files, I can't find any differences. And in this video, you can see at the beginning how the preset is changed and then LFO 1 has a positive triangle waveform. So there, the LFO positive LED lights up instead of the random LED. https://www.youtube.com/watch?v=FA0i5-bAfUQ
From what I gather from the manual and changelog, this LED indicates whether you have selected a „positive values only“ waveform for the LFO (instead of applying the default workaround by showing waveform LED + Random LED). It does not indicate that the value of the LFO is currently positive.
Is there a clock signal for a LED in the MBHP core
acfnews replied to acfnews's topic in MIDIbox SID
Hi @TK. A great alternative for this would be to have the active SID led 'flash/dim' whenever there is midi activity like this is done in the FM v1. (instrument 1/4 led flash/dim) Would that be a feasible option (both programming wise, as resource PIC wise)? -
my problem was a bad driver chip on the bhp_seq interface board....
