All Activity
This stream auto-updates
  1. Past hour
  2. I now have to manage to turn off and on the rgbled under the switches. I tried things like this: (Without success so far) #NGC #Section 1 #switch EVENT_BUTTON id= 141 hw_id= 25 fwd_id=RGBLED:257 type=CC chn= 1 cc= 21 button_mode= Toggle hsv= 300:100:10 EVENT_BUTTON id= 142 hw_id= 26 fwd_id=RGBLED:258 type=CC chn= 1 cc= 22 button_mode= Toggle hsv= 300:100:10 EVENT_BUTTON id= 143 hw_id= 27 fwd_id=RGBLED:259 type=CC chn= 1 cc= 23 button_mode= Toggle hsv= 332:100:10 EVENT_BUTTON id= 144 hw_id= 28 fwd_id=RGBLED:260 type=CC chn= 1 cc= 24 button_mode= Toggle hsv= 334:100:10 # LED will change brightness (v) based on value (hue statically defined) EVENT_RGBLED id=257 hw_id= 257 hsv=300:100:10 dimmed=1 range=0:10 EVENT_RGBLED id=258 hw_id= 258 hsv=300:100:10 dimmed=1 range=0:10 EVENT_RGBLED id=259 hw_id= 259 hsv=300:100:10 dimmed=1 range=0:10 EVENT_RGBLED id=260 hw_id= 260 hsv=300:100:10 dimmed=1 range=0:10 #NGR if ^section == 1 log "Section is 1" set_active (id)RGBLED:257 1 set_active (id)RGBLED:258 1 set_active (id)RGBLED:259 1 set_active (id)RGBLED:260 1 set_active (id)RGBLED:357 0 set_active (id)RGBLED:358 0 set_active (id)RGBLED:359 0 set_active (id)RGBLED:360 0 if ^section == 2 log "Section is 2" set_active (id)RGBLED:257 0 set_active (id)RGBLED:258 0 set_active (id)RGBLED:259 0 set_active (id)RGBLED:260 0 set_active (id)RGBLED:357 1 set_active (id)RGBLED:358 1 set_active (id)RGBLED:359 1 set_active (id)RGBLED:360 1
  3. Yesterday
  4. I understood I have to use set_active . I managed to make it work on encoder and push button set_active (id)ENC:10 1 set_active (id)BUTTON:117 1 I didn't succeed on Ainser, I tried: set_active (id)AINSER:133 1 #EDIT: There were errors in my code. It works now. The code below works #NGC # EVENT id= 0 hw_id= 0 fwd_id=LED:0 type=CC chn= 0 cc= 0 button_mode= Toggle range= 0:127 fwd_to_lcd=1 rgbled_pattern= 0 hsv= 359:100:10 # Ju_Box RESET_HW # LCD message after load #LCD "%C@(11:2:2)READY." #Appel des BANKS EVENT_BUTTON id= 1001 hw_id= 29 type=Meta button_mode= OnOnly meta=RunSection:1 EVENT_BUTTON id= 1002 hw_id= 30 type=Meta button_mode= OnOnly meta=RunSection:2 EVENT_BUTTON id= 1003 hw_id= 31 type=Meta button_mode= OnOnly meta=RunSection:3 EVENT_BUTTON id= 1004 hw_id= 32 type=Meta button_mode= OnOnly meta=RunSection:4 EVENT_BUTTON id= 1005 hw_id= 61 type=Meta button_mode= OnOnly meta=RunSection:5 EVENT_BUTTON id= 1006 hw_id= 62 type=Meta button_mode= OnOnly meta=RunSection:6 EVENT_BUTTON id= 1007 hw_id= 63 type=Meta button_mode= OnOnly meta=RunSection:7 EVENT_BUTTON id= 1008 hw_id= 64 type=Meta button_mode= OnOnly meta=RunSection:8 #encoder_hardware_configuration ENC n= 1 sr= 1 pins=1:0 type=non_detented ENC n= 2 sr= 1 pins=3:2 type=non_detented ENC n= 3 sr= 1 pins=5:4 type=non_detented ENC n= 4 sr= 1 pins=7:6 type=non_detented ENC n= 5 sr= 2 pins=1:0 type=non_detented ENC n= 6 sr= 2 pins=3:2 type=non_detented ENC n= 7 sr= 2 pins=5:4 type=non_detented ENC n= 8 sr= 2 pins=7:6 type=non_detented ENC n= 9 sr= 5 pins=1:0 type=non_detented ENC n= 10 sr= 5 pins=3:2 type=non_detented ENC n= 11 sr= 5 pins=5:4 type=non_detented ENC n= 12 sr= 5 pins=7:6 type=non_detented ENC n= 13 sr= 6 pins=1:0 type=non_detented ENC n= 14 sr= 6 pins=3:2 type=non_detented ENC n= 15 sr= 6 pins=5:4 type=non_detented ENC n= 16 sr= 6 pins=7:6 type=non_detented #ainser hardware configuration aINSER n= 1 enabled=1 muxed=1 cs=0 resolution=7bit aINSER n= 2 enabled=0 muxed=1 cs=1 resolution=7bit #Section 1 1 #Encoders EVENT_ENC id= 101 hw_id= 1 fwd_id=RGBLED:2 type=CC chn= 1 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 328:100:10 EVENT_ENC id= 102 hw_id= 2 fwd_id=RGBLED:18 type=CC chn= 1 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 330:100:10 EVENT_ENC id= 103 hw_id= 3 fwd_id=RGBLED:34 type=CC chn= 1 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 332:100:10 EVENT_ENC id= 104 hw_id= 4 fwd_id=RGBLED:50 type=CC chn= 1 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 334:100:10 EVENT_ENC id= 105 hw_id= 5 fwd_id=RGBLED:66 type=CC chn= 1 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 336:100:10 EVENT_ENC id= 106 hw_id= 6 fwd_id=RGBLED:82 type=CC chn= 1 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 338:100:10 EVENT_ENC id= 107 hw_id= 7 fwd_id=RGBLED:98 type=CC chn= 1 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 340:100:10 EVENT_ENC id= 108 hw_id= 8 fwd_id=RGBLED:114 type=CC chn= 1 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 342:100:10 #Encoders #Section5 EVENT_ENC id= 109 hw_id= 9 fwd_id=RGBLED:130 type=CC chn= 1 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 344:100:10 EVENT_ENC id= 110 hw_id= 10 fwd_id=RGBLED:146 type=CC chn= 1 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 346:100:10 EVENT_ENC id= 111 hw_id= 11 fwd_id=RGBLED:162 type=CC chn= 1 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 348:100:10 EVENT_ENC id= 112 hw_id= 12 fwd_id=RGBLED:178 type=CC chn= 1 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 350:100:10 EVENT_ENC id= 113 hw_id= 13 fwd_id=RGBLED:194 type=CC chn= 1 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 352:100:10 EVENT_ENC id= 114 hw_id= 14 fwd_id=RGBLED:210 type=CC chn= 1 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 354:100:10 EVENT_ENC id= 115 hw_id= 15 fwd_id=RGBLED:226 type=CC chn= 1 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 356:100:10 EVENT_ENC id= 116 hw_id= 16 fwd_id=RGBLED:242 type=CC chn= 1 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 358:100:10 # BP encodeurs T1 #Section 1 EVENT_BUTTON id= 117 hw_id= 17 fwd_id=RGBLED:1 type=CC chn= 1 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 118 hw_id= 18 fwd_id=RGBLED:17 type=CC chn= 1 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 119 hw_id= 19 fwd_id=RGBLED:33 type=CC chn= 1 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 120 hw_id= 20 fwd_id=RGBLED:49 type=CC chn= 1 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 121 hw_id= 21 fwd_id=RGBLED:65 type=CC chn= 1 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 122 hw_id= 22 fwd_id=RGBLED:81 type=CC chn= 1 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 123 hw_id= 23 fwd_id=RGBLED:97 type=CC chn= 1 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 124 hw_id= 24 fwd_id=RGBLED:113 type=CC chn= 1 cc= 16 button_mode= Toggle hsv= 0:100:10 # BP encodeurs T2 #Section5 EVENT_BUTTON id= 125 hw_id= 49 fwd_id=RGBLED:129 type=CC chn= 1 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 126 hw_id= 50 fwd_id=RGBLED:145 type=CC chn= 1 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 127 hw_id= 51 fwd_id=RGBLED:161 type=CC chn= 1 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 128 hw_id= 52 fwd_id=RGBLED:177 type=CC chn= 1 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 129 hw_id= 53 fwd_id=RGBLED:193 type=CC chn= 1 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 130 hw_id= 54 fwd_id=RGBLED:209 type=CC chn= 1 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 131 hw_id= 55 fwd_id=RGBLED:225 type=CC chn= 1 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 132 hw_id= 56 fwd_id=RGBLED:241 type=CC chn= 1 cc= 16 button_mode= Toggle hsv= 0:100:10 #---------------- MIXER------------- #FADER #Section 1 EVENT_AINSER id= 133 hw_id= 1 type=CC chn= 1 cc= 17 range= 0:127 EVENT_AINSER id= 134 hw_id= 2 type=CC chn= 1 cc= 18 range= 0:127 EVENT_AINSER id= 135 hw_id= 3 type=CC chn= 1 cc= 19 range= 0:127 EVENT_AINSER id= 136 hw_id= 4 type=CC chn= 1 cc= 20 range= 0:127 #FADER #Section5 EVENT_AINSER id= 137 hw_id= 5 type=CC chn= 1 cc= 17 range= 0:127 EVENT_AINSER id= 138 hw_id= 6 type=CC chn= 1 cc= 18 range= 0:127 EVENT_AINSER id= 139 hw_id= 7 type=CC chn= 1 cc= 19 range= 0:127 EVENT_AINSER id= 140 hw_id= 8 type=CC chn= 1 cc= 20 range= 0:127 #switch #Section 1 EVENT_BUTTON id= 141 hw_id= 25 fwd_id=RGBLED:257 type=CC chn= 1 cc= 21 button_mode= Toggle hsv= 328:100:10 EVENT_BUTTON id= 142 hw_id= 26 fwd_id=RGBLED:258 type=CC chn= 1 cc= 22 button_mode= Toggle hsv= 330:100:10 EVENT_BUTTON id= 143 hw_id= 27 fwd_id=RGBLED:259 type=CC chn= 1 cc= 23 button_mode= Toggle hsv= 332:100:10 EVENT_BUTTON id= 144 hw_id= 28 fwd_id=RGBLED:260 type=CC chn= 1 cc= 24 button_mode= Toggle hsv= 334:100:10 #switch #Section5 EVENT_BUTTON id= 153 hw_id= 57 fwd_id=RGBLED:265 type=CC chn= 1 cc= 21 button_mode= Toggle hsv= 328:100:10 EVENT_BUTTON id= 154 hw_id= 58 fwd_id=RGBLED:266 type=CC chn= 1 cc= 22 button_mode= Toggle hsv= 330:100:10 EVENT_BUTTON id= 155 hw_id= 59 fwd_id=RGBLED:267 type=CC chn= 1 cc= 23 button_mode= Toggle hsv= 332:100:10 EVENT_BUTTON id= 156 hw_id= 60 fwd_id=RGBLED:268 type=CC chn= 1 cc= 24 button_mode= Toggle hsv= 334:100:10 #POTARD T1 #Section 1 EVENT_AINSER id= 157 hw_id= 9 type=CC chn= 1 cc= 25 range= 0:127 EVENT_AINSER id= 158 hw_id= 10 type=CC chn= 1 cc= 26 range= 0:127 EVENT_AINSER id= 159 hw_id= 11 type=CC chn= 1 cc= 27 range= 0:127 EVENT_AINSER id= 160 hw_id= 12 type=CC chn= 1 cc= 28 range= 0:127 EVENT_AINSER id= 161 hw_id= 13 type=CC chn= 1 cc= 29 range= 0:127 EVENT_AINSER id= 162 hw_id= 14 type=CC chn= 1 cc= 30 range= 0:127 EVENT_AINSER id= 163 hw_id= 15 type=CC chn= 1 cc= 31 range= 0:127 EVENT_AINSER id= 164 hw_id= 16 type=CC chn= 1 cc= 32 range= 0:127 #POTARD T2 #Section5 EVENT_AINSER id= 165 hw_id= 17 type=CC chn= 1 cc= 25 range= 0:127 EVENT_AINSER id= 166 hw_id= 18 type=CC chn= 1 cc= 26 range= 0:127 EVENT_AINSER id= 167 hw_id= 19 type=CC chn= 1 cc= 27 range= 0:127 EVENT_AINSER id= 168 hw_id= 20 type=CC chn= 1 cc= 28 range= 0:127 EVENT_AINSER id= 169 hw_id= 21 type=CC chn= 1 cc= 29 range= 0:127 EVENT_AINSER id= 170 hw_id= 22 type=CC chn= 1 cc= 30 range= 0:127 EVENT_AINSER id= 171 hw_id= 23 type=CC chn= 1 cc= 31 range= 0:127 EVENT_AINSER id= 172 hw_id= 24 type=CC chn= 1 cc= 32 range= 0:127 # SECTION 2 2 #Encoders # SECTION 2 EVENT_ENC id= 201 hw_id= 1 fwd_id=RGBLED:2 type=CC chn= 2 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 160:100:10 EVENT_ENC id= 202 hw_id= 2 fwd_id=RGBLED:18 type=CC chn= 2 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 170:100:10 EVENT_ENC id= 203 hw_id= 3 fwd_id=RGBLED:34 type=CC chn= 2 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 180:100:10 EVENT_ENC id= 204 hw_id= 4 fwd_id=RGBLED:50 type=CC chn= 2 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 190:100:10 EVENT_ENC id= 205 hw_id= 5 fwd_id=RGBLED:66 type=CC chn= 2 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 200:100:10 EVENT_ENC id= 206 hw_id= 6 fwd_id=RGBLED:82 type=CC chn= 2 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 210:100:10 EVENT_ENC id= 207 hw_id= 7 fwd_id=RGBLED:98 type=CC chn= 2 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 220:100:10 EVENT_ENC id= 208 hw_id= 8 fwd_id=RGBLED:114 type=CC chn= 2 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 230:100:10 # SECTION 6 EVENT_ENC id= 209 hw_id= 9 fwd_id=RGBLED:130 type=CC chn= 2 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 160:100:10 EVENT_ENC id= 210 hw_id= 10 fwd_id=RGBLED:146 type=CC chn= 2 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 170:100:10 EVENT_ENC id= 211 hw_id= 11 fwd_id=RGBLED:162 type=CC chn= 2 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 180:100:10 EVENT_ENC id= 212 hw_id= 12 fwd_id=RGBLED:178 type=CC chn= 2 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 190:100:10 EVENT_ENC id= 213 hw_id= 13 fwd_id=RGBLED:194 type=CC chn= 2 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 200:100:10 EVENT_ENC id= 214 hw_id= 14 fwd_id=RGBLED:210 type=CC chn= 2 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 210:100:10 EVENT_ENC id= 215 hw_id= 15 fwd_id=RGBLED:226 type=CC chn= 2 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 220:100:10 EVENT_ENC id= 216 hw_id= 16 fwd_id=RGBLED:242 type=CC chn= 2 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 230:100:10 #bouton_poussoir_encodeurs_1 # SECTION 2 EVENT_BUTTON id= 217 hw_id= 17 fwd_id=RGBLED:1 type=CC chn= 2 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 218 hw_id= 18 fwd_id=RGBLED:17 type=CC chn= 2 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 219 hw_id= 19 fwd_id=RGBLED:33 type=CC chn= 2 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 220 hw_id= 20 fwd_id=RGBLED:49 type=CC chn= 2 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 221 hw_id= 21 fwd_id=RGBLED:65 type=CC chn= 2 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 222 hw_id= 22 fwd_id=RGBLED:81 type=CC chn= 2 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 223 hw_id= 23 fwd_id=RGBLED:97 type=CC chn= 2 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 224 hw_id= 24 fwd_id=RGBLED:113 type=CC chn= 2 cc= 16 button_mode= Toggle hsv= 0:100:10 #bouton_poussoir_encodeurs_2 # SECTION 6 EVENT_BUTTON id= 225 hw_id= 49 fwd_id=RGBLED:129 type=CC chn= 2 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 226 hw_id= 50 fwd_id=RGBLED:145 type=CC chn= 2 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 227 hw_id= 51 fwd_id=RGBLED:161 type=CC chn= 2 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 228 hw_id= 52 fwd_id=RGBLED:177 type=CC chn= 2 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 229 hw_id= 53 fwd_id=RGBLED:193 type=CC chn= 2 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 230 hw_id= 54 fwd_id=RGBLED:209 type=CC chn= 2 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 231 hw_id= 55 fwd_id=RGBLED:225 type=CC chn= 2 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 232 hw_id= 56 fwd_id=RGBLED:241 type=CC chn= 2 cc= 16 button_mode= Toggle hsv= 0:100:10 #---------------- MIXER------------- #FADER # SECTION 2 EVENT_AINSER id= 233 hw_id= 1 type=CC chn= 2 cc= 17 range= 0:127 EVENT_AINSER id= 234 hw_id= 2 type=CC chn= 2 cc= 18 range= 0:127 EVENT_AINSER id= 235 hw_id= 3 type=CC chn= 2 cc= 19 range= 0:127 EVENT_AINSER id= 236 hw_id= 4 type=CC chn= 2 cc= 20 range= 0:127 # SECTION 6 EVENT_AINSER id= 237 hw_id= 5 type=CC chn= 2 cc= 17 range= 0:127 EVENT_AINSER id= 238 hw_id= 6 type=CC chn= 2 cc= 18 range= 0:127 EVENT_AINSER id= 239 hw_id= 7 type=CC chn= 2 cc= 19 range= 0:127 EVENT_AINSER id= 240 hw_id= 8 type=CC chn= 2 cc= 20 range= 0:127 #switch # SECTION 2 EVENT_BUTTON id= 241 hw_id= 25 fwd_id=RGBLED:257 type=CC chn= 2 cc= 21 button_mode= Toggle hsv= 220:100:10 EVENT_BUTTON id= 242 hw_id= 26 fwd_id=RGBLED:258 type=CC chn= 2 cc= 22 button_mode= Toggle hsv= 220:100:10 EVENT_BUTTON id= 243 hw_id= 27 fwd_id=RGBLED:259 type=CC chn= 2 cc= 23 button_mode= Toggle hsv= 220:100:10 EVENT_BUTTON id= 244 hw_id= 28 fwd_id=RGBLED:260 type=CC chn= 2 cc= 24 button_mode= Toggle hsv= 220:100:10 #switch # SECTION 6 EVENT_BUTTON id= 253 hw_id= 57 fwd_id=RGBLED:265 type=CC chn= 2 cc= 21 button_mode= Toggle hsv= 220:100:10 EVENT_BUTTON id= 254 hw_id= 58 fwd_id=RGBLED:266 type=CC chn= 2 cc= 22 button_mode= Toggle hsv= 220:100:10 EVENT_BUTTON id= 255 hw_id= 59 fwd_id=RGBLED:267 type=CC chn= 2 cc= 23 button_mode= Toggle hsv= 220:100:10 EVENT_BUTTON id= 256 hw_id= 60 fwd_id=RGBLED:268 type=CC chn= 2 cc= 24 button_mode= Toggle hsv= 220:100:10 #POTARD # SECTION 2 EVENT_AINSER id= 257 hw_id= 9 type=CC chn= 2 cc= 25 range= 0:127 EVENT_AINSER id= 258 hw_id= 10 type=CC chn= 2 cc= 26 range= 0:127 EVENT_AINSER id= 259 hw_id= 11 type=CC chn= 2 cc= 27 range= 0:127 EVENT_AINSER id= 260 hw_id= 12 type=CC chn= 2 cc= 28 range= 0:127 EVENT_AINSER id= 261 hw_id= 13 type=CC chn= 2 cc= 29 range= 0:127 EVENT_AINSER id= 262 hw_id= 14 type=CC chn= 2 cc= 30 range= 0:127 EVENT_AINSER id= 263 hw_id= 15 type=CC chn= 2 cc= 31 range= 0:127 EVENT_AINSER id= 264 hw_id= 16 type=CC chn= 2 cc= 32 range= 0:127 #POTARD # SECTION 6 EVENT_AINSER id= 265 hw_id= 17 type=CC chn= 2 cc= 25 range= 0:127 EVENT_AINSER id= 266 hw_id= 18 type=CC chn= 2 cc= 26 range= 0:127 EVENT_AINSER id= 267 hw_id= 19 type=CC chn= 2 cc= 27 range= 0:127 EVENT_AINSER id= 268 hw_id= 20 type=CC chn= 2 cc= 28 range= 0:127 EVENT_AINSER id= 269 hw_id= 21 type=CC chn= 2 cc= 29 range= 0:127 EVENT_AINSER id= 270 hw_id= 22 type=CC chn= 2 cc= 30 range= 0:127 EVENT_AINSER id= 271 hw_id= 23 type=CC chn= 2 cc= 31 range= 0:127 EVENT_AINSER id= 272 hw_id= 24 type=CC chn= 2 cc= 32 range= 0:127 #Section 3 3 #Encoders EVENT_ENC id= 301 hw_id= 1 fwd_id=RGBLED:2 type=CC chn= 3 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 302 hw_id= 2 fwd_id=RGBLED:18 type=CC chn= 3 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 303 hw_id= 3 fwd_id=RGBLED:34 type=CC chn= 3 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 304 hw_id= 4 fwd_id=RGBLED:50 type=CC chn= 3 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 305 hw_id= 5 fwd_id=RGBLED:66 type=CC chn= 3 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 306 hw_id= 6 fwd_id=RGBLED:82 type=CC chn= 3 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 307 hw_id= 7 fwd_id=RGBLED:98 type=CC chn= 3 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 308 hw_id= 8 fwd_id=RGBLED:114 type=CC chn= 3 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 #Encoders #Section 7 EVENT_ENC id= 309 hw_id= 9 fwd_id=RGBLED:130 type=CC chn= 3 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 310 hw_id= 10 fwd_id=RGBLED:146 type=CC chn= 3 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 311 hw_id= 11 fwd_id=RGBLED:162 type=CC chn= 3 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 312 hw_id= 12 fwd_id=RGBLED:178 type=CC chn= 3 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 313 hw_id= 13 fwd_id=RGBLED:194 type=CC chn= 3 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 314 hw_id= 14 fwd_id=RGBLED:210 type=CC chn= 3 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 315 hw_id= 15 fwd_id=RGBLED:226 type=CC chn= 3 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 EVENT_ENC id= 316 hw_id= 16 fwd_id=RGBLED:242 type=CC chn= 3 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 100:100:10 # BP encodeurs T1 #Section 3 EVENT_BUTTON id= 317 hw_id= 17 fwd_id=RGBLED:1 type=CC chn= 3 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 318 hw_id= 18 fwd_id=RGBLED:17 type=CC chn= 3 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 319 hw_id= 19 fwd_id=RGBLED:33 type=CC chn= 3 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 320 hw_id= 20 fwd_id=RGBLED:49 type=CC chn= 3 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 321 hw_id= 21 fwd_id=RGBLED:65 type=CC chn= 3 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 322 hw_id= 22 fwd_id=RGBLED:81 type=CC chn= 3 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 323 hw_id= 23 fwd_id=RGBLED:97 type=CC chn= 3 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 324 hw_id= 24 fwd_id=RGBLED:113 type=CC chn= 3 cc= 16 button_mode= Toggle hsv= 0:100:10 # BP encodeurs T2 #Section 7 EVENT_BUTTON id= 325 hw_id= 49 fwd_id=RGBLED:129 type=CC chn= 3 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 326 hw_id= 50 fwd_id=RGBLED:145 type=CC chn= 3 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 327 hw_id= 51 fwd_id=RGBLED:161 type=CC chn= 3 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 328 hw_id= 52 fwd_id=RGBLED:177 type=CC chn= 3 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 329 hw_id= 53 fwd_id=RGBLED:193 type=CC chn= 3 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 330 hw_id= 54 fwd_id=RGBLED:209 type=CC chn= 3 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 331 hw_id= 55 fwd_id=RGBLED:225 type=CC chn= 3 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 332 hw_id= 56 fwd_id=RGBLED:241 type=CC chn= 3 cc= 16 button_mode= Toggle hsv= 0:100:10 #---------------- MIXER------------- #FADER #Section 3 EVENT_AINSER id= 333 hw_id= 1 type=CC chn= 3 cc= 17 range= 0:127 EVENT_AINSER id= 334 hw_id= 2 type=CC chn= 3 cc= 18 range= 0:127 EVENT_AINSER id= 335 hw_id= 3 type=CC chn= 3 cc= 19 range= 0:127 EVENT_AINSER id= 336 hw_id= 4 type=CC chn= 3 cc= 20 range= 0:127 #FADER #Section 7 EVENT_AINSER id= 337 hw_id= 5 type=CC chn= 3 cc= 17 range= 0:127 EVENT_AINSER id= 338 hw_id= 6 type=CC chn= 3 cc= 18 range= 0:127 EVENT_AINSER id= 339 hw_id= 7 type=CC chn= 3 cc= 19 range= 0:127 EVENT_AINSER id= 340 hw_id= 8 type=CC chn= 3 cc= 20 range= 0:127 #switch #Section 3 EVENT_BUTTON id= 341 hw_id= 25 fwd_id=RGBLED:257 type=CC chn= 3 cc= 21 button_mode= Toggle hsv= 100:100:10 EVENT_BUTTON id= 342 hw_id= 26 fwd_id=RGBLED:258 type=CC chn= 3 cc= 22 button_mode= Toggle hsv= 100:100:10 EVENT_BUTTON id= 343 hw_id= 27 fwd_id=RGBLED:259 type=CC chn= 3 cc= 23 button_mode= Toggle hsv= 100:100:10 EVENT_BUTTON id= 344 hw_id= 28 fwd_id=RGBLED:260 type=CC chn= 3 cc= 24 button_mode= Toggle hsv= 100:100:10 #switch #Section 7 EVENT_BUTTON id= 353 hw_id= 57 fwd_id=RGBLED:265 type=CC chn= 3 cc= 21 button_mode= Toggle hsv= 100:100:10 EVENT_BUTTON id= 354 hw_id= 58 fwd_id=RGBLED:266 type=CC chn= 3 cc= 22 button_mode= Toggle hsv= 100:100:10 EVENT_BUTTON id= 355 hw_id= 59 fwd_id=RGBLED:267 type=CC chn= 3 cc= 23 button_mode= Toggle hsv= 100:100:10 EVENT_BUTTON id= 356 hw_id= 60 fwd_id=RGBLED:268 type=CC chn= 3 cc= 24 button_mode= Toggle hsv= 100:100:10 #POTARD T1 #Section 3 EVENT_AINSER id= 357 hw_id= 9 type=CC chn= 3 cc= 25 range= 0:127 EVENT_AINSER id= 358 hw_id= 10 type=CC chn= 3 cc= 26 range= 0:127 EVENT_AINSER id= 359 hw_id= 11 type=CC chn= 3 cc= 27 range= 0:127 EVENT_AINSER id= 360 hw_id= 12 type=CC chn= 3 cc= 28 range= 0:127 EVENT_AINSER id= 361 hw_id= 13 type=CC chn= 3 cc= 29 range= 0:127 EVENT_AINSER id= 362 hw_id= 14 type=CC chn= 3 cc= 30 range= 0:127 EVENT_AINSER id= 363 hw_id= 15 type=CC chn= 3 cc= 31 range= 0:127 EVENT_AINSER id= 364 hw_id= 16 type=CC chn= 3 cc= 32 range= 0:127 #POTARD T2 #Section 7 EVENT_AINSER id= 365 hw_id= 17 type=CC chn= 3 cc= 25 range= 0:127 EVENT_AINSER id= 366 hw_id= 18 type=CC chn= 3 cc= 26 range= 0:127 EVENT_AINSER id= 367 hw_id= 19 type=CC chn= 3 cc= 27 range= 0:127 EVENT_AINSER id= 368 hw_id= 20 type=CC chn= 3 cc= 28 range= 0:127 EVENT_AINSER id= 369 hw_id= 21 type=CC chn= 3 cc= 29 range= 0:127 EVENT_AINSER id= 370 hw_id= 22 type=CC chn= 3 cc= 30 range= 0:127 EVENT_AINSER id= 371 hw_id= 23 type=CC chn= 3 cc= 31 range= 0:127 EVENT_AINSER id= 372 hw_id= 24 type=CC chn= 3 cc= 32 range= 0:127 # SECTION 4 4 #Encoders # SECTION 4 EVENT_ENC id= 401 hw_id= 1 fwd_id=RGBLED:2 type=CC chn= 4 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 402 hw_id= 2 fwd_id=RGBLED:18 type=CC chn= 4 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 403 hw_id= 3 fwd_id=RGBLED:34 type=CC chn= 4 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 404 hw_id= 4 fwd_id=RGBLED:50 type=CC chn= 4 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 405 hw_id= 5 fwd_id=RGBLED:66 type=CC chn= 4 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 406 hw_id= 6 fwd_id=RGBLED:82 type=CC chn= 4 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 407 hw_id= 7 fwd_id=RGBLED:98 type=CC chn= 4 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 408 hw_id= 8 fwd_id=RGBLED:114 type=CC chn= 4 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 # SECTION 8 EVENT_ENC id= 409 hw_id= 9 fwd_id=RGBLED:130 type=CC chn= 4 cc= 1 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 410 hw_id= 10 fwd_id=RGBLED:146 type=CC chn= 4 cc= 2 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 411 hw_id= 11 fwd_id=RGBLED:162 type=CC chn= 4 cc= 3 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 412 hw_id= 12 fwd_id=RGBLED:178 type=CC chn= 4 cc= 4 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 413 hw_id= 13 fwd_id=RGBLED:194 type=CC chn= 4 cc= 5 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 414 hw_id= 14 fwd_id=RGBLED:210 type=CC chn= 4 cc= 6 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 415 hw_id= 15 fwd_id=RGBLED:226 type=CC chn= 4 cc= 7 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 EVENT_ENC id= 416 hw_id= 16 fwd_id=RGBLED:242 type=CC chn= 4 cc= 8 range= 0:127 rgbled_pattern= 1 hsv= 50:100:10 #bouton_poussoir_encodeurs_1 # SECTION 4 EVENT_BUTTON id= 417 hw_id= 17 fwd_id=RGBLED:1 type=CC chn= 4 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 418 hw_id= 18 fwd_id=RGBLED:17 type=CC chn= 4 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 419 hw_id= 19 fwd_id=RGBLED:33 type=CC chn= 4 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 420 hw_id= 20 fwd_id=RGBLED:49 type=CC chn= 4 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 421 hw_id= 21 fwd_id=RGBLED:65 type=CC chn= 4 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 422 hw_id= 22 fwd_id=RGBLED:81 type=CC chn= 4 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 423 hw_id= 23 fwd_id=RGBLED:97 type=CC chn= 4 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 424 hw_id= 24 fwd_id=RGBLED:113 type=CC chn= 4 cc= 16 button_mode= Toggle hsv= 0:100:10 #bouton_poussoir_encodeurs_2 # SECTION 8 EVENT_BUTTON id= 425 hw_id= 49 fwd_id=RGBLED:129 type=CC chn= 4 cc= 9 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 426 hw_id= 50 fwd_id=RGBLED:145 type=CC chn= 4 cc= 10 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 427 hw_id= 51 fwd_id=RGBLED:161 type=CC chn= 4 cc= 11 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 428 hw_id= 52 fwd_id=RGBLED:177 type=CC chn= 4 cc= 12 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 429 hw_id= 53 fwd_id=RGBLED:193 type=CC chn= 4 cc= 13 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 430 hw_id= 54 fwd_id=RGBLED:209 type=CC chn= 4 cc= 14 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 431 hw_id= 55 fwd_id=RGBLED:225 type=CC chn= 4 cc= 15 button_mode= Toggle hsv= 0:100:10 EVENT_BUTTON id= 432 hw_id= 56 fwd_id=RGBLED:241 type=CC chn= 4 cc= 16 button_mode= Toggle hsv= 0:100:10 #---------------- MIXER------------- #FADER # SECTION 4 EVENT_AINSER id= 433 hw_id= 1 type=CC chn= 4 cc= 17 range= 0:127 EVENT_AINSER id= 434 hw_id= 2 type=CC chn= 4 cc= 18 range= 0:127 EVENT_AINSER id= 435 hw_id= 3 type=CC chn= 4 cc= 19 range= 0:127 EVENT_AINSER id= 436 hw_id= 4 type=CC chn= 4 cc= 20 range= 0:127 # SECTION 8 EVENT_AINSER id= 437 hw_id= 5 type=CC chn= 4 cc= 17 range= 0:127 EVENT_AINSER id= 438 hw_id= 6 type=CC chn= 4 cc= 18 range= 0:127 EVENT_AINSER id= 439 hw_id= 7 type=CC chn= 4 cc= 19 range= 0:127 EVENT_AINSER id= 440 hw_id= 8 type=CC chn= 4 cc= 20 range= 0:127 #switch # SECTION 4 EVENT_BUTTON id= 441 hw_id= 25 fwd_id=RGBLED:257 type=CC chn= 4 cc= 21 button_mode= Toggle hsv= 50:100:10 EVENT_BUTTON id= 442 hw_id= 26 fwd_id=RGBLED:258 type=CC chn= 4 cc= 22 button_mode= Toggle hsv= 50:100:10 EVENT_BUTTON id= 443 hw_id= 27 fwd_id=RGBLED:259 type=CC chn= 4 cc= 23 button_mode= Toggle hsv= 50:100:10 EVENT_BUTTON id= 444 hw_id= 28 fwd_id=RGBLED:260 type=CC chn= 4 cc= 24 button_mode= Toggle hsv= 50:100:10 #switch # SECTION 8 EVENT_BUTTON id= 453 hw_id= 57 fwd_id=RGBLED:265 type=CC chn= 4 cc= 21 button_mode= Toggle hsv= 50:100:10 EVENT_BUTTON id= 454 hw_id= 58 fwd_id=RGBLED:266 type=CC chn= 4 cc= 22 button_mode= Toggle hsv= 50:100:10 EVENT_BUTTON id= 455 hw_id= 59 fwd_id=RGBLED:267 type=CC chn= 4 cc= 23 button_mode= Toggle hsv= 50:100:10 EVENT_BUTTON id= 456 hw_id= 60 fwd_id=RGBLED:268 type=CC chn= 4 cc= 24 button_mode= Toggle hsv= 50:100:10 #POTARD # SECTION 4 EVENT_AINSER id= 457 hw_id= 9 type=CC chn= 4 cc= 25 range= 0:127 EVENT_AINSER id= 458 hw_id= 10 type=CC chn= 4 cc= 26 range= 0:127 EVENT_AINSER id= 459 hw_id= 11 type=CC chn= 4 cc= 27 range= 0:127 EVENT_AINSER id= 460 hw_id= 12 type=CC chn= 4 cc= 28 range= 0:127 EVENT_AINSER id= 461 hw_id= 13 type=CC chn= 4 cc= 29 range= 0:127 EVENT_AINSER id= 462 hw_id= 14 type=CC chn= 4 cc= 30 range= 0:127 EVENT_AINSER id= 463 hw_id= 15 type=CC chn= 4 cc= 31 range= 0:127 EVENT_AINSER id= 464 hw_id= 16 type=CC chn= 4 cc= 32 range= 0:127 #POTARD # SECTION 8 EVENT_AINSER id= 465 hw_id= 17 type=CC chn= 4 cc= 25 range= 0:127 EVENT_AINSER id= 466 hw_id= 18 type=CC chn= 4 cc= 26 range= 0:127 EVENT_AINSER id= 467 hw_id= 19 type=CC chn= 4 cc= 27 range= 0:127 EVENT_AINSER id= 468 hw_id= 20 type=CC chn= 4 cc= 28 range= 0:127 EVENT_AINSER id= 469 hw_id= 21 type=CC chn= 4 cc= 29 range= 0:127 EVENT_AINSER id= 470 hw_id= 22 type=CC chn= 4 cc= 30 range= 0:127 EVENT_AINSER id= 471 hw_id= 23 type=CC chn= 4 cc= 31 range= 0:127 EVENT_AINSER id= 472 hw_id= 24 type=CC chn= 4 cc= 32 range= 0:127 # NGR if ^section == 0 log "Hello World!" # exec_meta RgbLedRainbow:5:10 delay_ms 2000 exit endif ################################################################################# if ^section == 1 log "Section is 1" set_hsv RGBLED:261 300:100:10 set_hsv RGBLED:262 200:100:1 set_hsv RGBLED:263 100:100:1 set_hsv RGBLED:264 50:100:1 # Active # Encoders set_active (id)ENC:101 1 set_active (id)ENC:102 1 set_active (id)ENC:103 1 set_active (id)ENC:104 1 set_active (id)ENC:105 1 set_active (id)ENC:106 1 set_active (id)ENC:107 1 set_active (id)ENC:108 1 # BP ENC set_active (id)BUTTON:117 1 set_active (id)BUTTON:118 1 set_active (id)BUTTON:119 1 set_active (id)BUTTON:120 1 set_active (id)BUTTON:121 1 set_active (id)BUTTON:122 1 set_active (id)BUTTON:123 1 set_active (id)BUTTON:124 1 #FADERS set_active (id)AINSER:133 1 set_active (id)AINSER:134 1 set_active (id)AINSER:135 1 set_active (id)AINSER:136 1 #SWICTH MIXER set_active (id)BUTTON:141 1 set_active (id)BUTTON:142 1 set_active (id)BUTTON:143 1 set_active (id)BUTTON:144 1 #POTARDS set_active (id)AINSER:157 1 set_active (id)AINSER:158 1 set_active (id)AINSER:159 1 set_active (id)AINSER:160 1 set_active (id)AINSER:161 1 set_active (id)AINSER:162 1 set_active (id)AINSER:163 1 set_active (id)AINSER:164 1 # Desative #ENC set_active (id)ENC:201 0 set_active (id)ENC:202 0 set_active (id)ENC:203 0 set_active (id)ENC:204 0 set_active (id)ENC:205 0 set_active (id)ENC:206 0 set_active (id)ENC:207 0 set_active (id)ENC:208 0 # BP ENC set_active (id)BUTTON:217 0 set_active (id)BUTTON:218 0 set_active (id)BUTTON:219 0 set_active (id)BUTTON:220 0 set_active (id)BUTTON:221 0 set_active (id)BUTTON:222 0 set_active (id)BUTTON:223 0 set_active (id)BUTTON:224 0 #FADERS set_active (id)AINSER:233 0 set_active (id)AINSER:234 0 set_active (id)AINSER:235 0 set_active (id)AINSER:236 0 #SWICTH MIXER set_active (id)BUTTON:241 0 set_active (id)BUTTON:242 0 set_active (id)BUTTON:243 0 set_active (id)BUTTON:244 0 #POTARDS set_active (id)AINSER:257 0 set_active (id)AINSER:258 0 set_active (id)AINSER:259 0 set_active (id)AINSER:260 0 set_active (id)AINSER:261 0 set_active (id)AINSER:262 0 set_active (id)AINSER:263 0 set_active (id)AINSER:264 0 #ENC set_active (id)ENC:301 0 set_active (id)ENC:302 0 set_active (id)ENC:303 0 set_active (id)ENC:304 0 set_active (id)ENC:305 0 set_active (id)ENC:306 0 set_active (id)ENC:307 0 set_active (id)ENC:308 0 # BP ENC set_active (id)BUTTON:317 0 set_active (id)BUTTON:318 0 set_active (id)BUTTON:319 0 set_active (id)BUTTON:320 0 set_active (id)BUTTON:321 0 set_active (id)BUTTON:322 0 set_active (id)BUTTON:323 0 set_active (id)BUTTON:324 0 #FADERS set_active (id)AINSER:333 0 set_active (id)AINSER:334 0 set_active (id)AINSER:335 0 set_active (id)AINSER:336 0 #SWICTH MIXER set_active (id)BUTTON:341 0 set_active (id)BUTTON:342 0 set_active (id)BUTTON:343 0 set_active (id)BUTTON:344 0 #POTARDS set_active (id)AINSER:357 0 set_active (id)AINSER:358 0 set_active (id)AINSER:359 0 set_active (id)AINSER:360 0 set_active (id)AINSER:361 0 set_active (id)AINSER:362 0 set_active (id)AINSER:363 0 set_active (id)AINSER:364 0 #ENC set_active (id)ENC:401 0 set_active (id)ENC:402 0 set_active (id)ENC:403 0 set_active (id)ENC:404 0 set_active (id)ENC:405 0 set_active (id)ENC:406 0 set_active (id)ENC:407 0 set_active (id)ENC:408 0 # BP ENC set_active (id)BUTTON:417 0 set_active (id)BUTTON:418 0 set_active (id)BUTTON:419 0 set_active (id)BUTTON:420 0 set_active (id)BUTTON:421 0 set_active (id)BUTTON:422 0 set_active (id)BUTTON:423 0 set_active (id)BUTTON:424 0 #FADERS set_active (id)AINSER:433 0 set_active (id)AINSER:434 0 set_active (id)AINSER:435 0 set_active (id)AINSER:436 0 #SWICTH MIXER set_active (id)BUTTON:441 0 set_active (id)BUTTON:442 0 set_active (id)BUTTON:443 0 set_active (id)BUTTON:444 0 #POTARDS set_active (id)AINSER:457 0 set_active (id)AINSER:458 0 set_active (id)AINSER:459 0 set_active (id)AINSER:460 0 set_active (id)AINSER:461 0 set_active (id)AINSER:462 0 set_active (id)AINSER:463 0 set_active (id)AINSER:464 0 exit endif if ^section == 2 log "Section is 2 " set_hsv RGBLED:261 300:100:1 set_hsv RGBLED:262 200:100:10 set_hsv RGBLED:263 100:100:1 set_hsv RGBLED:264 50:100:1 # Active # Encoders set_active (id)ENC:101 0 set_active (id)ENC:102 0 set_active (id)ENC:103 0 set_active (id)ENC:104 0 set_active (id)ENC:105 0 set_active (id)ENC:106 0 set_active (id)ENC:107 0 set_active (id)ENC:108 0 # BP ENC set_active (id)BUTTON:117 0 set_active (id)BUTTON:118 0 set_active (id)BUTTON:119 0 set_active (id)BUTTON:120 0 set_active (id)BUTTON:121 0 set_active (id)BUTTON:122 0 set_active (id)BUTTON:123 0 set_active (id)BUTTON:124 0 #FADERS set_active (id)AINSER:133 0 set_active (id)AINSER:134 0 set_active (id)AINSER:135 0 set_active (id)AINSER:136 0 #SWICTH MIXER set_active (id)BUTTON:141 0 set_active (id)BUTTON:142 0 set_active (id)BUTTON:143 0 set_active (id)BUTTON:144 0 #POTARDS 0 set_active (id)AINSER:157 0 set_active (id)AINSER:158 0 set_active (id)AINSER:159 0 set_active (id)AINSER:160 0 set_active (id)AINSER:161 0 set_active (id)AINSER:162 0 set_active (id)AINSER:163 0 set_active (id)AINSER:164 0 # Desative #ENC set_active (id)ENC:201 1 set_active (id)ENC:202 1 set_active (id)ENC:203 1 set_active (id)ENC:204 1 set_active (id)ENC:205 1 set_active (id)ENC:206 1 set_active (id)ENC:207 1 set_active (id)ENC:208 1 # BP ENC set_active (id)BUTTON:217 1 set_active (id)BUTTON:218 1 set_active (id)BUTTON:219 1 set_active (id)BUTTON:220 1 set_active (id)BUTTON:221 1 set_active (id)BUTTON:222 1 set_active (id)BUTTON:223 1 set_active (id)BUTTON:224 1 #FADERS set_active (id)AINSER:233 1 set_active (id)AINSER:234 1 set_active (id)AINSER:235 1 set_active (id)AINSER:236 1 #SWICTH MIXER set_active (id)BUTTON:241 1 set_active (id)BUTTON:242 1 set_active (id)BUTTON:243 1 set_active (id)BUTTON:244 1 #POTARDS set_active (id)AINSER:257 1 set_active (id)AINSER:258 1 set_active (id)AINSER:259 1 set_active (id)AINSER:260 1 set_active (id)AINSER:261 1 set_active (id)AINSER:262 1 set_active (id)AINSER:263 1 set_active (id)AINSER:264 1 #ENC set_active (id)ENC:301 0 set_active (id)ENC:302 0 set_active (id)ENC:303 0 set_active (id)ENC:304 0 set_active (id)ENC:305 0 set_active (id)ENC:306 0 set_active (id)ENC:307 0 set_active (id)ENC:308 0 # BP ENC set_active (id)BUTTON:317 0 set_active (id)BUTTON:318 0 set_active (id)BUTTON:319 0 set_active (id)BUTTON:320 0 set_active (id)BUTTON:321 0 set_active (id)BUTTON:322 0 set_active (id)BUTTON:323 0 set_active (id)BUTTON:324 0 #FADERS set_active (id)AINSER:333 0 set_active (id)AINSER:334 0 set_active (id)AINSER:335 0 set_active (id)AINSER:336 0 #SWICTH MIXER set_active (id)BUTTON:341 0 set_active (id)BUTTON:342 0 set_active (id)BUTTON:343 0 set_active (id)BUTTON:344 0 #POTARDS set_active (id)AINSER:357 0 set_active (id)AINSER:358 0 set_active (id)AINSER:359 0 set_active (id)AINSER:360 0 set_active (id)AINSER:361 0 set_active (id)AINSER:362 0 set_active (id)AINSER:363 0 set_active (id)AINSER:364 0 #ENC set_active (id)ENC:401 0 set_active (id)ENC:402 0 set_active (id)ENC:403 0 set_active (id)ENC:404 0 set_active (id)ENC:405 0 set_active (id)ENC:406 0 set_active (id)ENC:407 0 set_active (id)ENC:408 0 # BP ENC set_active (id)BUTTON:417 0 set_active (id)BUTTON:418 0 set_active (id)BUTTON:419 0 set_active (id)BUTTON:420 0 set_active (id)BUTTON:421 0 set_active (id)BUTTON:422 0 set_active (id)BUTTON:423 0 set_active (id)BUTTON:424 0 #FADERS set_active (id)AINSER:433 0 set_active (id)AINSER:434 0 set_active (id)AINSER:435 0 set_active (id)AINSER:436 0 #SWICTH MIXER set_active (id)BUTTON:441 0 set_active (id)BUTTON:442 0 set_active (id)BUTTON:443 0 set_active (id)BUTTON:444 0 #POTARDS set_active (id)AINSER:457 0 set_active (id)AINSER:458 0 set_active (id)AINSER:459 0 set_active (id)AINSER:460 0 set_active (id)AINSER:461 0 set_active (id)AINSER:462 0 set_active (id)AINSER:463 0 set_active (id)AINSER:464 0 exit endif if ^section == 3 log "Section is 3 " set_hsv RGBLED:261 300:100:1 set_hsv RGBLED:262 200:100:1 set_hsv RGBLED:263 100:100:10 set_hsv RGBLED:264 50:100:1 # Active # Encoders set_active (id)ENC:101 0 set_active (id)ENC:102 0 set_active (id)ENC:103 0 set_active (id)ENC:104 0 set_active (id)ENC:105 0 set_active (id)ENC:106 0 set_active (id)ENC:107 0 set_active (id)ENC:108 0 # BP ENC set_active (id)BUTTON:117 0 set_active (id)BUTTON:118 0 set_active (id)BUTTON:119 0 set_active (id)BUTTON:120 0 set_active (id)BUTTON:121 0 set_active (id)BUTTON:122 0 set_active (id)BUTTON:123 0 set_active (id)BUTTON:124 0 #FADERS set_active (id)AINSER:133 0 set_active (id)AINSER:134 0 set_active (id)AINSER:135 0 set_active (id)AINSER:136 0 #SWICTH MIXER set_active (id)BUTTON:141 0 set_active (id)BUTTON:142 0 set_active (id)BUTTON:143 0 set_active (id)BUTTON:144 0 #POTARDS set_active (id)AINSER:157 0 set_active (id)AINSER:158 0 set_active (id)AINSER:159 0 set_active (id)AINSER:160 0 set_active (id)AINSER:161 0 set_active (id)AINSER:162 0 set_active (id)AINSER:163 0 set_active (id)AINSER:164 0 # Desative #ENC set_active (id)ENC:201 0 set_active (id)ENC:202 0 set_active (id)ENC:203 0 set_active (id)ENC:204 0 set_active (id)ENC:205 0 set_active (id)ENC:206 0 set_active (id)ENC:207 0 set_active (id)ENC:208 0 # BP ENC set_active (id)BUTTON:217 0 set_active (id)BUTTON:218 0 set_active (id)BUTTON:219 0 set_active (id)BUTTON:220 0 set_active (id)BUTTON:221 0 set_active (id)BUTTON:222 0 set_active (id)BUTTON:223 0 set_active (id)BUTTON:224 0 #FADERS set_active (id)AINSER:233 0 set_active (id)AINSER:234 0 set_active (id)AINSER:235 0 set_active (id)AINSER:236 0 #SWICTH MIXER set_active (id)BUTTON:241 0 set_active (id)BUTTON:242 0 set_active (id)BUTTON:243 0 set_active (id)BUTTON:244 0 #POTARDS set_active (id)AINSER:257 0 set_active (id)AINSER:258 0 set_active (id)AINSER:259 0 set_active (id)AINSER:260 0 set_active (id)AINSER:261 0 set_active (id)AINSER:262 0 set_active (id)AINSER:263 0 set_active (id)AINSER:264 0 #ENC set_active (id)ENC:301 1 set_active (id)ENC:302 1 set_active (id)ENC:303 1 set_active (id)ENC:304 1 set_active (id)ENC:305 1 set_active (id)ENC:306 1 set_active (id)ENC:307 1 set_active (id)ENC:308 1 # BP ENC set_active (id)BUTTON:317 1 set_active (id)BUTTON:318 1 set_active (id)BUTTON:319 1 set_active (id)BUTTON:320 1 set_active (id)BUTTON:321 1 set_active (id)BUTTON:322 1 set_active (id)BUTTON:323 1 set_active (id)BUTTON:324 1 #FADERS set_active (id)AINSER:333 1 set_active (id)AINSER:334 1 set_active (id)AINSER:335 1 set_active (id)AINSER:336 1 #SWICTH MIXER set_active (id)BUTTON:341 1 set_active (id)BUTTON:342 1 set_active (id)BUTTON:343 1 set_active (id)BUTTON:344 1 #POTARDS set_active (id)AINSER:357 1 set_active (id)AINSER:358 1 set_active (id)AINSER:359 1 set_active (id)AINSER:360 1 set_active (id)AINSER:361 1 set_active (id)AINSER:362 1 set_active (id)AINSER:363 1 set_active (id)AINSER:364 1 #ENC set_active (id)ENC:401 0 set_active (id)ENC:402 0 set_active (id)ENC:403 0 set_active (id)ENC:404 0 set_active (id)ENC:405 0 set_active (id)ENC:406 0 set_active (id)ENC:407 0 set_active (id)ENC:408 0 # BP ENC set_active (id)BUTTON:417 0 set_active (id)BUTTON:418 0 set_active (id)BUTTON:419 0 set_active (id)BUTTON:420 0 set_active (id)BUTTON:421 0 set_active (id)BUTTON:422 0 set_active (id)BUTTON:423 0 set_active (id)BUTTON:424 0 #FADERS set_active (id)AINSER:433 0 set_active (id)AINSER:434 0 set_active (id)AINSER:435 0 set_active (id)AINSER:436 0 #SWICTH MIXER set_active (id)BUTTON:441 0 set_active (id)BUTTON:442 0 set_active (id)BUTTON:443 0 set_active (id)BUTTON:444 0 #POTARDS set_active (id)AINSER:457 0 set_active (id)AINSER:458 0 set_active (id)AINSER:459 0 set_active (id)AINSER:460 0 set_active (id)AINSER:461 0 set_active (id)AINSER:462 0 set_active (id)AINSER:463 0 set_active (id)AINSER:464 0 exit endif if ^section == 4 log "Section is 4 " set_hsv RGBLED:261 300:100:1 set_hsv RGBLED:262 200:100:1 set_hsv RGBLED:263 100:100:1 set_hsv RGBLED:264 50:100:10 # Active # Encoders set_active (id)ENC:101 0 set_active (id)ENC:102 0 set_active (id)ENC:103 0 set_active (id)ENC:104 0 set_active (id)ENC:105 0 set_active (id)ENC:106 0 set_active (id)ENC:107 0 set_active (id)ENC:108 0 # BP ENC set_active (id)BUTTON:117 0 set_active (id)BUTTON:118 0 set_active (id)BUTTON:119 0 set_active (id)BUTTON:120 0 set_active (id)BUTTON:121 0 set_active (id)BUTTON:122 0 set_active (id)BUTTON:123 0 set_active (id)BUTTON:124 0 #FADERS set_active (id)AINSER:133 0 set_active (id)AINSER:134 0 set_active (id)AINSER:135 0 set_active (id)AINSER:136 0 #SWICTH MIXER set_active (id)BUTTON:141 0 set_active (id)BUTTON:142 0 set_active (id)BUTTON:143 0 set_active (id)BUTTON:144 0 #POTARDS 0 set_active (id)AINSER:157 0 set_active (id)AINSER:158 0 set_active (id)AINSER:159 0 set_active (id)AINSER:160 0 set_active (id)AINSER:161 0 set_active (id)AINSER:162 0 set_active (id)AINSER:163 0 set_active (id)AINSER:164 0 # Desative #ENC set_active (id)ENC:201 0 set_active (id)ENC:202 0 set_active (id)ENC:203 0 set_active (id)ENC:204 0 set_active (id)ENC:205 0 set_active (id)ENC:206 0 set_active (id)ENC:207 0 set_active (id)ENC:208 0 # BP ENC set_active (id)BUTTON:217 0 set_active (id)BUTTON:218 0 set_active (id)BUTTON:219 0 set_active (id)BUTTON:220 0 set_active (id)BUTTON:221 0 set_active (id)BUTTON:222 0 set_active (id)BUTTON:223 0 set_active (id)BUTTON:224 0 #FADERS set_active (id)AINSER:233 0 set_active (id)AINSER:234 0 set_active (id)AINSER:235 0 set_active (id)AINSER:236 0 #SWICTH MIXER set_active (id)BUTTON:241 0 set_active (id)BUTTON:242 0 set_active (id)BUTTON:243 0 set_active (id)BUTTON:244 0 #POTARDS set_active (id)AINSER:257 0 set_active (id)AINSER:258 0 set_active (id)AINSER:259 0 set_active (id)AINSER:260 0 set_active (id)AINSER:261 0 set_active (id)AINSER:262 0 set_active (id)AINSER:263 0 set_active (id)AINSER:264 0 #ENC set_active (id)ENC:301 0 set_active (id)ENC:302 0 set_active (id)ENC:303 0 set_active (id)ENC:304 0 set_active (id)ENC:305 0 set_active (id)ENC:306 0 set_active (id)ENC:307 0 set_active (id)ENC:308 0 # BP ENC set_active (id)BUTTON:317 0 set_active (id)BUTTON:318 0 set_active (id)BUTTON:319 0 set_active (id)BUTTON:320 0 set_active (id)BUTTON:321 0 set_active (id)BUTTON:322 0 set_active (id)BUTTON:323 0 set_active (id)BUTTON:324 0 #FADERS set_active (id)AINSER:333 0 set_active (id)AINSER:334 0 set_active (id)AINSER:335 0 set_active (id)AINSER:336 0 #SWICTH MIXER set_active (id)BUTTON:341 0 set_active (id)BUTTON:342 0 set_active (id)BUTTON:343 0 set_active (id)BUTTON:344 0 #POTARDS set_active (id)AINSER:357 0 set_active (id)AINSER:358 0 set_active (id)AINSER:359 0 set_active (id)AINSER:360 0 set_active (id)AINSER:361 0 set_active (id)AINSER:362 0 set_active (id)AINSER:363 0 set_active (id)AINSER:364 0 #ENC set_active (id)ENC:401 1 set_active (id)ENC:402 1 set_active (id)ENC:403 1 set_active (id)ENC:404 1 set_active (id)ENC:405 1 set_active (id)ENC:406 1 set_active (id)ENC:407 1 set_active (id)ENC:408 1 # BP ENC set_active (id)BUTTON:417 1 set_active (id)BUTTON:418 1 set_active (id)BUTTON:419 1 set_active (id)BUTTON:420 1 set_active (id)BUTTON:421 1 set_active (id)BUTTON:422 1 set_active (id)BUTTON:423 1 set_active (id)BUTTON:424 1 #FADERS set_active (id)AINSER:433 1 set_active (id)AINSER:434 1 set_active (id)AINSER:435 1 set_active (id)AINSER:436 1 #SWICTH MIXER set_active (id)BUTTON:441 1 set_active (id)BUTTON:442 1 set_active (id)BUTTON:443 1 set_active (id)BUTTON:444 1 #POTARDS set_active (id)AINSER:457 1 set_active (id)AINSER:458 1 set_active (id)AINSER:459 1 set_active (id)AINSER:460 1 set_active (id)AINSER:461 1 set_active (id)AINSER:462 1 set_active (id)AINSER:463 1 set_active (id)AINSER:464 1 exit endif if ^section == 5 log "Section is 5 " set_hsv RGBLED:269 300:100:10 set_hsv RGBLED:270 200:100:1 set_hsv RGBLED:271 100:100:1 set_hsv RGBLED:272 50:100:1 # Active # Encoders set_active (id)ENC:109 1 set_active (id)ENC:110 1 set_active (id)ENC:111 1 set_active (id)ENC:112 1 set_active (id)ENC:113 1 set_active (id)ENC:114 1 set_active (id)ENC:115 1 set_active (id)ENC:116 1 # BP ENC set_active (id)BUTTON:125 1 set_active (id)BUTTON:126 1 set_active (id)BUTTON:127 1 set_active (id)BUTTON:128 1 set_active (id)BUTTON:129 1 set_active (id)BUTTON:130 1 set_active (id)BUTTON:131 1 set_active (id)BUTTON:132 1 #FADERS set_active (id)AINSER:137 1 set_active (id)AINSER:138 1 set_active (id)AINSER:139 1 set_active (id)AINSER:140 1 #SWICTH MIXER set_active (id)BUTTON:153 1 set_active (id)BUTTON:154 1 set_active (id)BUTTON:155 1 set_active (id)BUTTON:156 1 #POTARDS set_active (id)AINSER:165 1 set_active (id)AINSER:166 1 set_active (id)AINSER:167 1 set_active (id)AINSER:168 1 set_active (id)AINSER:169 1 set_active (id)AINSER:170 1 set_active (id)AINSER:171 1 set_active (id)AINSER:172 1 # Desative #ENC set_active (id)ENC:209 0 set_active (id)ENC:210 0 set_active (id)ENC:211 0 set_active (id)ENC:212 0 set_active (id)ENC:213 0 set_active (id)ENC:214 0 set_active (id)ENC:215 0 set_active (id)ENC:216 0 # BP ENC set_active (id)BUTTON:225 0 set_active (id)BUTTON:226 0 set_active (id)BUTTON:227 0 set_active (id)BUTTON:228 0 set_active (id)BUTTON:229 0 set_active (id)BUTTON:230 0 set_active (id)BUTTON:231 0 set_active (id)BUTTON:232 0 #FADERS set_active (id)AINSER:237 0 set_active (id)AINSER:238 0 set_active (id)AINSER:239 0 set_active (id)AINSER:240 0 #SWICTH MIXER set_active (id)BUTTON:253 0 set_active (id)BUTTON:254 0 set_active (id)BUTTON:255 0 set_active (id)BUTTON:256 0 #POTARDS set_active (id)AINSER:265 0 set_active (id)AINSER:266 0 set_active (id)AINSER:267 0 set_active (id)AINSER:268 0 set_active (id)AINSER:269 0 set_active (id)AINSER:270 0 set_active (id)AINSER:271 0 set_active (id)AINSER:272 0 #ENC set_active (id)ENC:309 0 set_active (id)ENC:310 0 set_active (id)ENC:311 0 set_active (id)ENC:312 0 set_active (id)ENC:313 0 set_active (id)ENC:314 0 set_active (id)ENC:315 0 set_active (id)ENC:316 0 # BP ENC set_active (id)BUTTON:325 0 set_active (id)BUTTON:326 0 set_active (id)BUTTON:327 0 set_active (id)BUTTON:328 0 set_active (id)BUTTON:329 0 set_active (id)BUTTON:330 0 set_active (id)BUTTON:331 0 set_active (id)BUTTON:332 0 #FADERS set_active (id)AINSER:337 0 set_active (id)AINSER:338 0 set_active (id)AINSER:339 0 set_active (id)AINSER:340 0 #SWICTH MIXER set_active (id)BUTTON:353 0 set_active (id)BUTTON:354 0 set_active (id)BUTTON:355 0 set_active (id)BUTTON:356 0 #POTARDS set_active (id)AINSER:365 0 set_active (id)AINSER:366 0 set_active (id)AINSER:367 0 set_active (id)AINSER:368 0 set_active (id)AINSER:369 0 set_active (id)AINSER:370 0 set_active (id)AINSER:371 0 set_active (id)AINSER:372 0 #ENC set_active (id)ENC:409 0 set_active (id)ENC:410 0 set_active (id)ENC:411 0 set_active (id)ENC:412 0 set_active (id)ENC:413 0 set_active (id)ENC:414 0 set_active (id)ENC:415 0 set_active (id)ENC:416 0 # BP ENC set_active (id)BUTTON:425 0 set_active (id)BUTTON:426 0 set_active (id)BUTTON:427 0 set_active (id)BUTTON:428 0 set_active (id)BUTTON:429 0 set_active (id)BUTTON:430 0 set_active (id)BUTTON:431 0 set_active (id)BUTTON:432 0 #FADERS set_active (id)AINSER:437 0 set_active (id)AINSER:438 0 set_active (id)AINSER:439 0 set_active (id)AINSER:440 0 #SWICTH MIXER set_active (id)BUTTON:453 0 set_active (id)BUTTON:454 0 set_active (id)BUTTON:455 0 set_active (id)BUTTON:456 0 #POTARDS set_active (id)AINSER:465 0 set_active (id)AINSER:466 0 set_active (id)AINSER:467 0 set_active (id)AINSER:468 0 set_active (id)AINSER:469 0 set_active (id)AINSER:470 0 set_active (id)AINSER:471 0 set_active (id)AINSER:472 0 exit endif if ^section == 6 log "Section is 6 " set_hsv RGBLED:269 300:100:1 set_hsv RGBLED:270 200:100:10 set_hsv RGBLED:271 100:100:1 set_hsv RGBLED:272 50:100:1 # Active # Encoders set_active (id)ENC:109 0 set_active (id)ENC:110 0 set_active (id)ENC:111 0 set_active (id)ENC:112 0 set_active (id)ENC:113 0 set_active (id)ENC:114 0 set_active (id)ENC:115 0 set_active (id)ENC:116 0 # BP ENC set_active (id)BUTTON:125 0 set_active (id)BUTTON:126 0 set_active (id)BUTTON:127 0 set_active (id)BUTTON:128 0 set_active (id)BUTTON:129 0 set_active (id)BUTTON:130 0 set_active (id)BUTTON:131 0 set_active (id)BUTTON:132 0 #FADERS set_active (id)AINSER:137 0 set_active (id)AINSER:138 0 set_active (id)AINSER:139 0 set_active (id)AINSER:140 0 #SWICTH MIXER set_active (id)BUTTON:153 0 set_active (id)BUTTON:154 0 set_active (id)BUTTON:155 0 set_active (id)BUTTON:156 0 #POTARDS set_active (id)AINSER:165 0 set_active (id)AINSER:166 0 set_active (id)AINSER:167 0 set_active (id)AINSER:168 0 set_active (id)AINSER:169 0 set_active (id)AINSER:170 0 set_active (id)AINSER:171 0 set_active (id)AINSER:172 0 # Desative #ENC set_active (id)ENC:209 1 set_active (id)ENC:210 1 set_active (id)ENC:211 1 set_active (id)ENC:212 1 set_active (id)ENC:213 1 set_active (id)ENC:214 1 set_active (id)ENC:215 1 set_active (id)ENC:216 1 # BP ENC set_active (id)BUTTON:225 1 set_active (id)BUTTON:226 1 set_active (id)BUTTON:227 1 set_active (id)BUTTON:228 1 set_active (id)BUTTON:229 1 set_active (id)BUTTON:230 1 set_active (id)BUTTON:231 1 set_active (id)BUTTON:232 1 #FADERS set_active (id)AINSER:237 1 set_active (id)AINSER:238 1 set_active (id)AINSER:239 1 set_active (id)AINSER:240 1 #SWICTH MIXER set_active (id)BUTTON:253 1 set_active (id)BUTTON:254 1 set_active (id)BUTTON:255 1 set_active (id)BUTTON:256 1 #POTARDS set_active (id)AINSER:265 1 set_active (id)AINSER:266 1 set_active (id)AINSER:267 1 set_active (id)AINSER:268 1 set_active (id)AINSER:269 1 set_active (id)AINSER:270 1 set_active (id)AINSER:271 1 set_active (id)AINSER:272 1 #ENC set_active (id)ENC:309 0 set_active (id)ENC:310 0 set_active (id)ENC:311 0 set_active (id)ENC:312 0 set_active (id)ENC:313 0 set_active (id)ENC:314 0 set_active (id)ENC:315 0 set_active (id)ENC:316 0 # BP ENC set_active (id)BUTTON:325 0 set_active (id)BUTTON:326 0 set_active (id)BUTTON:327 0 set_active (id)BUTTON:328 0 set_active (id)BUTTON:329 0 set_active (id)BUTTON:330 0 set_active (id)BUTTON:331 0 set_active (id)BUTTON:332 0 #FADERS set_active (id)AINSER:337 0 set_active (id)AINSER:338 0 set_active (id)AINSER:339 0 set_active (id)AINSER:340 0 #SWICTH MIXER set_active (id)BUTTON:353 0 set_active (id)BUTTON:354 0 set_active (id)BUTTON:355 0 set_active (id)BUTTON:356 0 #POTARDS set_active (id)AINSER:365 0 set_active (id)AINSER:366 0 set_active (id)AINSER:367 0 set_active (id)AINSER:368 0 set_active (id)AINSER:369 0 set_active (id)AINSER:370 0 set_active (id)AINSER:371 0 set_active (id)AINSER:372 0 #ENC set_active (id)ENC:409 0 set_active (id)ENC:410 0 set_active (id)ENC:411 0 set_active (id)ENC:412 0 set_active (id)ENC:413 0 set_active (id)ENC:414 0 set_active (id)ENC:415 0 set_active (id)ENC:416 0 # BP ENC set_active (id)BUTTON:425 0 set_active (id)BUTTON:426 0 set_active (id)BUTTON:427 0 set_active (id)BUTTON:428 0 set_active (id)BUTTON:429 0 set_active (id)BUTTON:430 0 set_active (id)BUTTON:431 0 set_active (id)BUTTON:432 0 #FADERS set_active (id)AINSER:437 0 set_active (id)AINSER:438 0 set_active (id)AINSER:439 0 set_active (id)AINSER:440 0 #SWICTH MIXER set_active (id)BUTTON:453 0 set_active (id)BUTTON:454 0 set_active (id)BUTTON:455 0 set_active (id)BUTTON:456 0 #POTARDS set_active (id)AINSER:465 0 set_active (id)AINSER:466 0 set_active (id)AINSER:467 0 set_active (id)AINSER:468 0 set_active (id)AINSER:469 0 set_active (id)AINSER:470 0 set_active (id)AINSER:471 0 set_active (id)AINSER:472 0 exit endif if ^section == 7 log "Section is 7 " set_hsv RGBLED:269 300:100:1 set_hsv RGBLED:270 200:100:1 set_hsv RGBLED:271 100:100:10 set_hsv RGBLED:272 50:100:1 # Active # Encoders set_active (id)ENC:109 0 set_active (id)ENC:110 0 set_active (id)ENC:111 0 set_active (id)ENC:112 0 set_active (id)ENC:113 0 set_active (id)ENC:114 0 set_active (id)ENC:115 0 set_active (id)ENC:116 0 # BP ENC set_active (id)BUTTON:125 0 set_active (id)BUTTON:126 0 set_active (id)BUTTON:127 0 set_active (id)BUTTON:128 0 set_active (id)BUTTON:129 0 set_active (id)BUTTON:130 0 set_active (id)BUTTON:131 0 set_active (id)BUTTON:132 0 #FADERS set_active (id)AINSER:137 0 set_active (id)AINSER:138 0 set_active (id)AINSER:139 0 set_active (id)AINSER:140 0 #SWICTH MIXER set_active (id)BUTTON:153 0 set_active (id)BUTTON:154 0 set_active (id)BUTTON:155 0 set_active (id)BUTTON:156 0 #POTARDS set_active (id)AINSER:165 0 set_active (id)AINSER:166 0 set_active (id)AINSER:167 0 set_active (id)AINSER:168 0 set_active (id)AINSER:169 0 set_active (id)AINSER:170 0 set_active (id)AINSER:171 0 set_active (id)AINSER:172 0 # Desative #ENC set_active (id)ENC:209 0 set_active (id)ENC:210 0 set_active (id)ENC:211 0 set_active (id)ENC:212 0 set_active (id)ENC:213 0 set_active (id)ENC:214 0 set_active (id)ENC:215 0 set_active (id)ENC:216 0 # BP ENC set_active (id)BUTTON:225 0 set_active (id)BUTTON:226 0 set_active (id)BUTTON:227 0 set_active (id)BUTTON:228 0 set_active (id)BUTTON:229 0 set_active (id)BUTTON:230 0 set_active (id)BUTTON:231 0 set_active (id)BUTTON:232 0 #FADERS set_active (id)AINSER:237 0 set_active (id)AINSER:238 0 set_active (id)AINSER:239 0 set_active (id)AINSER:240 0 #SWICTH MIXER set_active (id)BUTTON:253 0 set_active (id)BUTTON:254 0 set_active (id)BUTTON:255 0 set_active (id)BUTTON:256 0 #POTARDS set_active (id)AINSER:265 0 set_active (id)AINSER:266 0 set_active (id)AINSER:267 0 set_active (id)AINSER:268 0 set_active (id)AINSER:269 0 set_active (id)AINSER:270 0 set_active (id)AINSER:271 0 set_active (id)AINSER:272 0 #ENC set_active (id)ENC:309 1 set_active (id)ENC:310 1 set_active (id)ENC:311 1 set_active (id)ENC:312 1 set_active (id)ENC:313 1 set_active (id)ENC:314 1 set_active (id)ENC:315 1 set_active (id)ENC:316 1 # BP ENC set_active (id)BUTTON:325 1 set_active (id)BUTTON:326 1 set_active (id)BUTTON:327 1 set_active (id)BUTTON:328 1 set_active (id)BUTTON:329 1 set_active (id)BUTTON:330 1 set_active (id)BUTTON:331 1 set_active (id)BUTTON:332 1 #FADERS set_active (id)AINSER:337 1 set_active (id)AINSER:338 1 set_active (id)AINSER:339 1 set_active (id)AINSER:340 1 #SWICTH MIXER set_active (id)BUTTON:353 1 set_active (id)BUTTON:354 1 set_active (id)BUTTON:355 1 set_active (id)BUTTON:356 1 #POTARDS set_active (id)AINSER:365 1 set_active (id)AINSER:366 1 set_active (id)AINSER:367 1 set_active (id)AINSER:368 1 set_active (id)AINSER:369 1 set_active (id)AINSER:370 1 set_active (id)AINSER:371 1 set_active (id)AINSER:372 1 #ENC set_active (id)ENC:409 0 set_active (id)ENC:410 0 set_active (id)ENC:411 0 set_active (id)ENC:412 0 set_active (id)ENC:413 0 set_active (id)ENC:414 0 set_active (id)ENC:415 0 set_active (id)ENC:416 0 # BP ENC set_active (id)BUTTON:425 0 set_active (id)BUTTON:426 0 set_active (id)BUTTON:427 0 set_active (id)BUTTON:428 0 set_active (id)BUTTON:429 0 set_active (id)BUTTON:430 0 set_active (id)BUTTON:431 0 set_active (id)BUTTON:432 0 #FADERS set_active (id)AINSER:437 0 set_active (id)AINSER:438 0 set_active (id)AINSER:439 0 set_active (id)AINSER:440 0 #SWICTH MIXER set_active (id)BUTTON:453 0 set_active (id)BUTTON:454 0 set_active (id)BUTTON:455 0 set_active (id)BUTTON:456 0 #POTARDS set_active (id)AINSER:465 0 set_active (id)AINSER:466 0 set_active (id)AINSER:467 0 set_active (id)AINSER:468 0 set_active (id)AINSER:469 0 set_active (id)AINSER:470 0 set_active (id)AINSER:471 0 set_active (id)AINSER:472 0 exit endif if ^section == 8 log "Section is 8 " set_hsv RGBLED:269 300:100:1 set_hsv RGBLED:270 200:100:1 set_hsv RGBLED:271 100:100:1 set_hsv RGBLED:272 50:100:10 # Active # Encoders set_active (id)ENC:109 0 set_active (id)ENC:110 0 set_active (id)ENC:111 0 set_active (id)ENC:112 0 set_active (id)ENC:113 0 set_active (id)ENC:114 0 set_active (id)ENC:115 0 set_active (id)ENC:116 0 # BP ENC set_active (id)BUTTON:125 0 set_active (id)BUTTON:126 0 set_active (id)BUTTON:127 0 set_active (id)BUTTON:128 0 set_active (id)BUTTON:129 0 set_active (id)BUTTON:130 0 set_active (id)BUTTON:131 0 set_active (id)BUTTON:132 0 #FADERS set_active (id)AINSER:137 0 set_active (id)AINSER:138 0 set_active (id)AINSER:139 0 set_active (id)AINSER:140 0 #SWICTH MIXER set_active (id)BUTTON:153 0 set_active (id)BUTTON:154 0 set_active (id)BUTTON:155 0 set_active (id)BUTTON:156 0 #POTARDS set_active (id)AINSER:165 0 set_active (id)AINSER:166 0 set_active (id)AINSER:167 0 set_active (id)AINSER:168 0 set_active (id)AINSER:169 0 set_active (id)AINSER:170 0 set_active (id)AINSER:171 0 set_active (id)AINSER:172 0 # Desative #ENC set_active (id)ENC:209 0 set_active (id)ENC:210 0 set_active (id)ENC:211 0 set_active (id)ENC:212 0 set_active (id)ENC:213 0 set_active (id)ENC:214 0 set_active (id)ENC:215 0 set_active (id)ENC:216 0 # BP ENC set_active (id)BUTTON:225 0 set_active (id)BUTTON:226 0 set_active (id)BUTTON:227 0 set_active (id)BUTTON:228 0 set_active (id)BUTTON:229 0 set_active (id)BUTTON:230 0 set_active (id)BUTTON:231 0 set_active (id)BUTTON:232 0 #FADERS set_active (id)AINSER:237 0 set_active (id)AINSER:238 0 set_active (id)AINSER:239 0 set_active (id)AINSER:240 0 #SWICTH MIXER set_active (id)BUTTON:253 0 set_active (id)BUTTON:254 0 set_active (id)BUTTON:255 0 set_active (id)BUTTON:256 0 #POTARDS set_active (id)AINSER:265 0 set_active (id)AINSER:266 0 set_active (id)AINSER:267 0 set_active (id)AINSER:268 0 set_active (id)AINSER:269 0 set_active (id)AINSER:270 0 set_active (id)AINSER:271 0 set_active (id)AINSER:272 0 #ENC set_active (id)ENC:309 0 set_active (id)ENC:310 0 set_active (id)ENC:311 0 set_active (id)ENC:312 0 set_active (id)ENC:313 0 set_active (id)ENC:314 0 set_active (id)ENC:315 0 set_active (id)ENC:316 0 # BP ENC set_active (id)BUTTON:325 0 set_active (id)BUTTON:326 0 set_active (id)BUTTON:327 0 set_active (id)BUTTON:328 0 set_active (id)BUTTON:329 0 set_active (id)BUTTON:330 0 set_active (id)BUTTON:331 0 set_active (id)BUTTON:332 0 #FADERS set_active (id)AINSER:337 0 set_active (id)AINSER:338 0 set_active (id)AINSER:339 0 set_active (id)AINSER:340 0 #SWICTH MIXER set_active (id)BUTTON:353 0 set_active (id)BUTTON:354 0 set_active (id)BUTTON:355 0 set_active (id)BUTTON:356 0 #POTARDS set_active (id)AINSER:365 0 set_active (id)AINSER:366 0 set_active (id)AINSER:367 0 set_active (id)AINSER:368 0 set_active (id)AINSER:369 0 set_active (id)AINSER:370 0 set_active (id)AINSER:371 0 set_active (id)AINSER:372 0 #ENC set_active (id)ENC:409 1 set_active (id)ENC:410 1 set_active (id)ENC:411 1 set_active (id)ENC:412 1 set_active (id)ENC:413 1 set_active (id)ENC:414 1 set_active (id)ENC:415 1 set_active (id)ENC:416 1 # BP ENC set_active (id)BUTTON:425 1 set_active (id)BUTTON:426 1 set_active (id)BUTTON:427 1 set_active (id)BUTTON:428 1 set_active (id)BUTTON:429 1 set_active (id)BUTTON:430 1 set_active (id)BUTTON:431 1 set_active (id)BUTTON:432 1 #FADERS set_active (id)AINSER:437 1 set_active (id)AINSER:438 1 set_active (id)AINSER:439 1 set_active (id)AINSER:440 1 #SWICTH MIXER set_active (id)BUTTON:453 1 set_active (id)BUTTON:454 1 set_active (id)BUTTON:455 1 set_active (id)BUTTON:456 1 #POTARDS set_active (id)AINSER:465 1 set_active (id)AINSER:466 1 set_active (id)AINSER:467 1 set_active (id)AINSER:468 1 set_active (id)AINSER:469 1 set_active (id)AINSER:470 1 set_active (id)AINSER:471 1 set_active (id)AINSER:472 1 exit endif
  5. Last week
  6. Good morning SetBankOfHwId only works on encoders? I tried on fader and Switch without result
  7. Earlier
  8. Hi Kazik, 1) FAST button control with Bookmarks: this can only work if you disable the "ENC_AUTO_FAST" feature in your MBSEQ_HW.V4 file, which overrules interactive FAST button changes Background: with ENC_AUTO_FAST, FAST mode will be auto-selected depending on the selected parameter layer, and can be temporary (!) overruled by pressing the FAST button. Without this feature, FAST button has full control over the encoder behaviour 2) HUMANIZER changing CC values: works at my side, would need more input to give you guidance, please use the appr. thread to discuss at the right place Best Regards, Thorsten.
  9. Thanks for the feedback! It was a nice challenge to nail down this issue, because it only appears in conjunction with the TPD, which explains why many other MBSEQ users didn't notice this so far! :) Please try this version: http://www.ucapps.de/mios32/midibox_seq_v4_098_pre3.zip Best Regards, Thorsten. P.S.: background -> https://github.com/midibox/mios32/commit/66fa4df5960d51c93ee90c065062c5ba28fdde69
  10. Hi, I have built the Midiphy version of the SEQ4+ and I stumbled upon some weird behaviour. I tried to use the Section Control tool, but it crashes from the moment I press the E key and above on my external keyboard. Then the screen shows “TODO page”. It still plays the partial sequence though, but When I press EDIT It sometimes returns back to the edit page but mostly it crashes and reads “!! HARD FAULT !! at PC=0Xffff0201” This happens in every octave. I've tried several different keyboards. The first three keys C, C# (from an external keyboard) work as intentioned, but from D on it shows errated LED flashing and from E it goes to a TODO page… weird This whole behaviour renders the Section Control function useless of course. Anyone experienced this before? Any ideas? I'm on the latest firmware.
  11. This is working with the buttons now for me!
  12. Hi, I just discovered the MegaCommand Live project and the alternative firmwares that comes with it for Machinedrum and Monomachine. It seems pretty cool to my eyes, but I'm not sure I need the extra hardware. The module is based around an Arduino Mega, so the code needs some translation/porting. Is anyone already working on this ? Could it be integrated in the Seq v4 project without loosing functionnality ? Just another bottle in the sea ;) Re_
  13. Now it's my turn to face some challenges in this process. I'm feeling quite newbies at the moment. I've assembled my mb6582 and currently only have access to the master core. Testing the control surface navigation and listening to the default patch sound, everything seems to be ok. However, when attempting to select other SIDs, I encounter an error message: "SID(x) not available (CAN disabled)". It think I need to clone other PICs from the master. I attempted this by pressing "Menu" + power on the unit, but unfortunately, the cloning process failed at the end. I also tried the previous steps suggested by @dwestbury, but upon starting the mb6582, I encountered another error: "CS not enabled". I purchased preprogrammed PICs from dwestbury, so I assume all the PICs should have the bootloader and the correct ID. I'm not sure of what I might have missed or what my next steps should be.
  14. hello T ok so i am on http://www.ucapps.de/mios32/midibox_seq_v4_098_pre2.zip fresh new project 1.make GLOBAL BOOKMARK #1 for DIVIDER with FAST ON, 2.FAST is ON and CLOCK GP #2 scrolls fast, 3.switch to EDIT page ,FAST is automatically turned off, 4.recall GLOBAL BOOKMARK #1 ,FAST is ON BUT not working,CLOCK GP #2 scrolls normal 5.switch to EDIT page,turn on FAST,recall BOOKMARK #1 now FAST is ON and working in SEQ_UI.C it says and to restore i think there might be a bug somewhere,something missing it seems seq_ui_button_state.FAST_ENCODERS = 1 is turning FAST button LED on but not the FAST function when recalled from BOOKMARKS i also tried to use seq_ui_button_state.FAST_ENCODERS = 1 for example when switching to MIXER page so my encoders work fast in MIXER page,but same effect p.s. while i have your attention , in HUMANIZER there is 2nd option VEL/CC ,should that humanize VELOCITY and MIDI CC messages from PARAMETER LAYERS of the track? cause when i set track with one CC param HUMANIZER does not humanize that CC layer thank you for your time best regards Kazik
  15. How could I reproduce this issue? Could you please give step-by-step instructions? Best Regards, Thorsten.
  16. It might be possible to hack this into the firmware, do you have a compiler setup ready? Best Regards, Thorsten.
  17. Does it work at your side? I noticed that the change wasn't working with the "selection row" of the MIDIphy front panel, now fixed here: -> http://www.ucapps.de/mios32/midibox_seq_v4_098_pre2.zip Best Regards, Thorsten.
  18. new price 750€ i combined and wrote the 32bit Code so it now can comunicate with a SEQV4+, and off course with the SEQV4 standard, here is the sourcecode + firmware: BLM_V01.7z see also this short video (german):
  19. when restoring seq_ui_button_state.FAST_ENCODERS from recalled BM lights the led ,but FAST does not work, i tried also to seq_ui_button_state.FAST_ENCODERS = 1; when switching to MIXER page, and FAST led comes up but no effect can some one confirm? any ideas? best regards
  20. Hi all,I hope to find some Midibox Sid users to give me some insight about the SID behaviour in a MIDIBox SID.So I designed my own Midibox loosely based on the Sammich with a minimal Control Surface on a LCD screen. So far everything seems to work as it should, but I get kind of a strange noise floor at the audio output right after startup.I used it with an Armsid, Swinsid and original 8580 SID and get different results without touching a button or a note on my keyboard:Armsid: a high pitch sound - 9 Mhz sinewave on my oscilloscopeSwinsid: a pulsing sound and crackles on the higher volumes - 250khz squarewave on my oscilloscope8580: same sound like the Swinsid but with a bit of white noise in the backgroundI tried different variants on the power supply input (filtering, linear regulators etc.) but it makes absolutly no difference. I even checked that no datalines or powerlines are anywhere near the audio output traces on my pcb.The last thing I can think of is that the "startup" patch somehow sends an signal to the SID to produce the sounds or it's simply the "normal" noise floor of a SID which even gets emulated by the Armsid and Swinsid.All youtube videos I found don't seem to have the problem as far as I can hear. But on the other hand, all start directly with an melody, so there's now way to hear any sounds in "standby".If anyone could share their experiences with me it would be greatly appreciated! Thx Kevin
  21. Hi All, I would like to have a LED indicating the midi clock as global indicator of the connections. Is this feasible? I tried searching the forum for sync/pulse/clock but I did not find any clue yet. Any help is appreciated! Thanks, ron
  22. Wow cool! I was just playing with putting 32 Skips in a 128 step track to make it six measures long but that creates a massive delay... I will test this asap! Andrew
  23. Interesting timing of this posting: recently I noticed a very similar problem and hacked a quick change into the firmware to move forward. Let's make it official :-) -> http://www.ucapps.de/mios32/midibox_seq_v4_098_pre1.zip From the ChangeLog: MIDIboxSEQ V4.098 ~~~~~~~~~~~~~~~~~ o Phrase Mode: if Option 3/33 "Pattern Change Synchronization" is activated, patterns will start from step 1 after song position change. This is especially useful if phrases contain tracks with different lengths. Option 5/33 "Restart all Tracks on Pattern Change" should be disabled in this case because it won't lead to the intended results. Best Regards, Thorsten. P.S.: I removed your first posting because it seems to be a duplicate
  24. Browsing through the posts, I've seen several people who have run into the same problem I'm trying to solve. I use Song/Phrase mode with patterns set up for "Intro", "Verse 1&2", "Chorus", "Solo", "Verse 3", etc for live performance. It works great for things like the Solo section where you can just let it loop as long as you want before going back to another Verse. In the last measure of each section I choose a new Phrase if I want to go to another Section. The problem I have is when the different sections are not the same length. Say the Chorus is 5 measures long and all the other Sections (Intro, Verses, etc) are all 4 measures long. During the 5th measure of the Chorus I press the Phrase button to go to the Verse and it goes to the 2nd measure of the Verse instead of the 1st measure. I set all 16 of the tracks to the same length, same divider. I've played with various combination of the Options (#1-3 & 5) and still can't figure out a way to make it work. Option 1 = 16 steps, Option 2 = 16 steps, Option 3 enabled, Option 5 disabled (this works if all the tracks/patterns are the same length) Should this be possible? Or do I need a different sequencer for this band?
  25. little a side question,but how can i make humanizer/robotizer work on CC's ,i have NOTE track with CC layer,and when turnin VEL/CC in hum/rob i does nothing,wha i do wrong?
  1. Load more activity
