zephyrin
    68
    2
Everything posted by zephyrin
  1. Hello i have recently changed the screen off my MB9090 , I choose a EA DOGM128S-6 (FSTN Negative). I m wanted to know if I can changed by the new oled screen EA OLEDL128-6LWA ? The size os the same but I don't know if I need to set the new screen with MIOS32 and if it's work without changed anything in the framework ?
  2. Yes i don't need BLM.
  3. Hello I want to finish my mbseq V4 with the new core STM32F4 i m not sure that i need 4 midi input so i wanted to know if i could used the quad IIC midi board with the STM32F4 for have 2 input midi and 6 midi output and the BLM output (2 input and 2 output midi come from midi I/O board for STM32F4) Zephyrin
  4. I just want to know if someone make the new design for stm32F4?
  5. Hi antix i have build this rack if you want the fpd file let me known...
  6. zephyrin
    808 panel
    From the album: MB808
  7. zephyrin
    808 rack
  8. Hi i have used the seb Drumbox for have velocity control for each instrument of my tr8060. http://burnit.co.uk/sdiy/index.php?page=drumbox I have connected the accent and trigger input on the same output pulse. Trigger input work fine with a pulse between 5v and 15 v so you don't need to send a spécific +5 Volts.
  9. zephyrin
    MBSEQ V4
  10. I just want to know if someone make the new design for stm32F4?
  11. I have received my case. Just a question where are the instructions for building the case ? It's me or there are only 5 faces ?
  12. I received the shipping info too. Thanks a lot for organizing this group buy.
  13. kristal= Thank you for the correction
  14. Hi kristal, I am interested in a black Heidenreich Case. I have put name in to the wiki but i m not shure that the shipping price is correcte for switzerland !
  15. Hi Kanji velleman make all color digitast http://www.velleman.eu/products/search/?q=digitast&search=Recherche http://www.velleman.eu/products/view/?id=2753 for exemple the ref for red with red led is SP86-A2-1-1 yellow with red led is SP86-A2-2-1 With google and the ref it will be easy to found a seller .... It s also easy to change the led
  16. He thank you for your answer When i have tested my MB808 i haven't put nothing on the AC input and now i understand why i have no sound i will trying this as soon.
  17. He tank you for your answer i have a 808 like you but with the microlarge PCB My sequencer don't trim nothing but i have no connection for the input accent perhaps this is the reason that don't work ?
  18. Could you tell me how you are connected the Accent input on the 808-voice board ?
  19. Hello Christian have work for a single PCB. You can found here the eagles files boards in the download aera http://www.christian-hartig.de/TR-8060/
  20. Yes i understand that is very short how do you do to see the instrument trigger led blinking withe the full MB808 ? I m thinking that i could see the pulse with an oscilloscope no ? I wanted to check if i have the pulse could you tell me how i can do it ? Perhaps i don't understand how it's work ...
  21. I have some questions about the trigger section in the MB808 i have keep the original configuration in the the asm files with the MIDI output port value = 1 like this When i try to check the DOUT with oscilloscope i don't see anny voltage . IT is normal or i need to do something ? I also read that about the Menu Page Selection but i can't change the value of manual page?
  22. The beta testing was stopping for one year. pcbatterij said that the work will be start in a few day.
