FantomXR
    1,035
    22
Everything posted by FantomXR
  1. Hey! I'm interested in which case it is necessary to program an encoder like this. Could you please give an example?
  2. Same here! I have exactly the same problem! When I did upload the bootloader app and restart the core, the display shows "Bootloader © T.Klose" but after that it goes black. In NG it's also not working.
  3. I checked all connections and it seemed, that there was a mistake. Anyway: Now I have another problem. I connected a pot to the AINSER. When turning it from 0 to 100% the values need two or three seconds to "follow" the pot. So it seems, that something slows the scan rate down. Any suggestions?
  4. Hey, I ran into a little problem. I use an AINSER8-module. I want to scan four switches (f.e. sustain) and four expression pedals. So I have eight jacks. All of them are stereo even if I don't use the stereo-feature for switches. I wired all "tip"-pins and all "shield"-pins together. Tip is 5V, shield is GND. For the switches I first connect the analog input and than connect the switch via a 1k resistor to GND. This works flawlessly. For the expression pedals I thought I could use the "ring"-pins which is the wiper of a typical expression pedal. So I connected the analog inputs of the AINSER to the "ring"-pins. So for expression: T - 5V R - A0-A3 S - GND As I'm using switched-jacks I set up the connection like if nothing is connected to the jack, the analog input goes to ground to not create random values. The problem is that I get a lot of jitter especially in the lower range. Not of the input I connected the potentiometer to, but from all the other jacks. Also of the sustain-jacks. I than tried to connect the potentiometer to one of the sustain-jacks. It's working here but it doesn't go down to 0 and it doesn't go up to 127. Also it seems that the scale does not go linear. I use a pot with a center-detent. In the first half nearly nothing happens. But I have to say, that I didn't try to set a pinrange for the jacks yet. Could you please tell me where my mistake is? I have no idea.... Thank you very much, Chris
  5. Hi TK, okay! No problem ;) Thanks, Chris
  6. I have another question regarding Sysex: Is midibox able to "learn" SysEx commands via "MIDI"-learn or do I have to put in the sysex-strings by myself?
  7. Hey TK, okay! I'm looking forward to it. Can't wait to test it ;) Thanks for your support. Best regards, Chris
  8. Hey TK, I think this will be fine. Do you already have the NGR-code for that? :) Thanks, Chris
  9. Hi! Thanks for getting back to me. Hm, seems complicated. TK, is there maybe an easier solution on the softwareside? (Fire note-on with the break) If not... I didn't get exactly what you meant by using a 8PDT switch. Would you draw just a little schematic on how do you think it should work?
  10. I attached a schematic as example. Is this correct?
  11. So, sadly this project was canceled for several reasons. But I have another question regarding RGB LEDs. As far as I know NG is able to drive LEDs with common cathode. How about common anode leds? Is it also possible in conjunction with ULN? Thanks, Chris
  12. Yeah, I remember... but I was not complaining! I just mentioned it :) I will try it soon! :) Thanks again!
  13. Hey TK! Thanks for all that! I at first need to understand the code in the NGR. That takes a bit of time :) The new features you added... could you do an example for what this could be useful? I don't know, what you meant by the SRIO. Where do I have to put this parameter into? It would be great to scan it faster :) I'm out of DIO-modules... so I can not test it at the moment...
  14. Hey Thorsten! Great! I figured out how to send a CC which contains the bank select and after that the program change. It works great! So, what I could do is, adding two buttons. Those two buttons change between bank select 1 and 2. But I think this is a complicated solution. Here is an idea: Is it possible, that NG generates the correct program change (including bank select) automatically? So, for example: I enter number 128 and NG sends Program Change 1 on Channel 1 on Bank 2 because it's the first program change in the new bank. What do you think? A friend of mine uses Mainstage and he has a very large setup running, which contains up to 200 songs. Mainstage (meanwhile) supports bank select. So this would be a great feature. This feature is already awesome anyways :)
  15. TK!!! You are my hero! That's awesome and it works perfectly! It is possible to add bank select support (or MSB / LSB)? Or even a support for the midi channel on which the prg.chg. is sent? This would be a great feature. Thank you again! :)
  16. Hey! I want to create my own pcb because I need to put the LCDs in another order. Is there a schematic, that shows the connections? Thanks Chris
  17. Hey people! I'm in designing a breakout board for the STM. So J15A will be splitted into eight 2x5 pin header at which the OLED displays will be connected directly with a standard ribbon cable. For that I need the schematic, that shows, how to connect 9-16 displays to the core. I can't find any schematic for this and it's hard to see from the schematic of the pcb novski created. I know that I need to add a 74HC595 shift register but I'm not sure, how it has to be connected to the core. Could you please point me in the right direction? Thanks, Chris
  18. Okay! :) Thank you very much.
  19. Thanks TK. @novski: keypad = numpad. Well, if I think about it...It doesn't have to be a numpad. How about using buttons connected to a DIN or organized in a matrix? Is there a way?
  20. Hey people, I wonder if somebody managed to send a program change command with a simple keypad. May I overlooked something but I didn't find something which is related to midibox. I wish to type in a number and after pressing an "enter"-button it sends the program change number. Is there something out there? :) Thanks, Chris
  21. Okay, I see your point! I tested with a multimeter. My assumption is correct. Both sides share T0-T7. So the only solution is what you already suggested. Good to know :-) I will go into it in the upcoming week. Thanks for your help! BTW: Here is a build recently finished!
  22. FantomXR
    Rhodes-Style MIDIKeyboard
    - TP40/76 - MIDI I/O - USB - Sustain - Internal power supply
