FantomXR
1,035 -
22
Everything posted by FantomXR
	Hi TK, I took a look into the code cause I have no parts for a test setup. So, is there a reason, why you did define already meta-events to the encoders? If I get you explanations right in the ngc this should work: Press button:2002 (start MIDI Learn) Send CC#8 from MIOSStudio to NG Move ENC:3 Press button:2002 again (stop MIDI Learn) Set ENC:3 to 50% Press button:2000 Move ENC:3 to 100% Press button:2000 again (could this work in momentary-mode?) If I now adjust the ENC:1 it should "simulate" ENC:3 but only in range 64:127. Is this correct? :smile: Man... I really need to have a little setup here, where I can test those things faster....
	This looks already great. I'm looking forward to the Learn-Function. Thanks, TK!
	Hey Thorsten, you got it! Yes, this would absolutely solve it! How about saving? Let's say I have made a whole setup with several of those meta events (so we would need more than one button to assign more controllers than just the ModWheel). Now I want to save it and recall it later. Is this possible with snapshots (btw. naming the snapshots is not possible at all right?)?
	Hey TK, at first: Happy new year! I already read about the MIDI learn function, which is already implemented. But from the NGC-Manual it's not really clear to me, what it does exactly. Let's break it down: We have one encoder, one wheel and one button. The button is for MIDI learn the wheel (same like on the nord I explained above). How would I now change the value of the encoder with the wheel in conjunction with NG? //edit: okay. I read the SCS manual, which explains it in more detail. So... it seems to be what I'm looking for but I need to do some testing in the next days. Anyway: It would be absolutely awesome if it would be possible to do this for more than one events / control more values with one controller. Any chances to do so? //edit2: I just thought again about the already integrated MIDI learn function. If I get it right I set MIDI learn to "on", send a CC to the midibox for example via MIOSStudio and then touch the controller to assign it. But in my suggested case it's different because the CC which should be learned is not send by a software, but from the controller itself.
	Hey all! As I'm working as a live musician I know the instruments of NORD very well. What I like most is the learn-function. It works like this: On top of the keyboard you have three buttons which are labeled with "Wheel", "A.Touch" and "CTRLPED". Let's say that the cutoff of the synth is at 50% and the volume is at 100%. What you want now is to change the cutoff to 100% and the volume to 80% (cause the sounds get's louder if you turn up the cutoff) by moving the modulation wheel. What you do is, press the button "Wheel" and while you keep it pressed you turn the volume down and the cutoff up. By releasing the button, the parameters are assigned and you are finished. This function is very nice to have and gives the user the chance to change multiple parameters in one move. It seems not that easy to implement. But maybe you have a nice idea to do so :) Anyway: We see us next year! Thanks, Chris
	I've a minor suggestion... maybe it has a reason that it is like it is but: If I have a button with an LED and I invert the button with range=127:0 than the LED still behaves like 0:127 (turns on when button sends "off"). So... in this case I need to handle it with a runsection-command, which is maybe more complicated that it needs to be. //edit: And another thing: I work on a NGR file and something seems to be wrong here. With this code It works fine but with this code Button:8 won't be triggered. I assume it's because I'm in a flow, right?
	Okay, 10k works perfect! Thanks! Merry Christmas!
	These are 1k resistors.
	Hey folks, this is not the first time I run into this problem and I don't have a solution for that. So... I'm asking here. Here is the situation: I have an AINSER64. I want to plug three footswitches into the AINSER. I tried it like this: Well, of course I run into the problem that A1 and A2 are triggered when just A0 is pressed. It's also the case when I put jacks in every socket. So my question is, how to isolate those sockets? Any tipps? Thanks, Chris
	Die Briefe sind gepackt und werden morgen rausgeschickt. Ich wünsch euch ein frohes Weihnachtsfest!
	So, das Paket ist angekommen. Ich zerpflücke das morgen früh und verpacke die Teile. Ich schick euch dann noch eine PN mit den Porto und Mehrwertsteuerkosten.
	No need to do the work. It's already done... see here: It's tested on 88key keybeds. Works like a charm ;) But as I mentioned: The pinout of the 40pol that the thread-starter has seems totally different. So... this adapter wouldn't work.
From the album: PCBs
	Danke für die Erläuterung! Dann ist ja alles gut :)
- 85 replies
	Ich finde das R-C-Glied am Ende der Kette interessant. Thorsten, würdest du das grundsätzlich empfehlen um möglichen Fehlerquellen gleich vorzubeugen oder nur unter gewissen Umständen? Falls ersteres wäre es toll, wenn man das in den anderen Schaltplänen auch sehen würde :)
- 85 replies
	Die Bestellung bei Mouser ist raus. Es dauert 3-4 Tage, bis die Teile da sind. Ich bin die ganze Woche nicht im Lande, lasse es aber zu einer Adresse schicken, wo jemand zu Hause ist. Der Weiterversand erfolgt dann am 22.12.
	Hi! Thanks for the pic. The 40pol connector is not standard at Fatar keybeds. Normally there are 2x20pin micro match connectors. I already created an adapter for plug and play. I will share this as soon as I have time to make a documentation :-) Good luck with your project.
	Lieber Thorsten, na, ich denke, das ist nicht unbedingt nötig. 4 MIDI I/Os sollten doch eigentlich genügen, die NG von Hause aus unterstützt. Wollte nur nachgefragt haben! Ich danke!
- 85 replies
	You are the master... I will try that soon :) Thank you very much!
	Kurze Zwischenfrage: Die App muss aber Quad IIC explizit unterstützen, oder? Mit der klassischen NG-App wird das doch nix, oder fehlen mir hier auch Infos? Auf der ucapps - Seite gibt es leider keinen Eintrag zu Quad IIC.
- 85 replies
	Hey folks, TK, do you think, it will be possible to call NGC-Files from MIDI events or buttons in the future or is it not possible im implement? Thanks! Chris
	Gern! Ich werde den Schaltplan noch lesbar aufbereiten und dann hier reinstellen. Wäre gut, wenn dann jemand nochmal einen Blick rüberwerfen kann, ob ich nicht was vergessen oder einen Fehler gemacht habe. Liebe Grüße, Christian
	Ich bin in Deutschland. Ich kann aber auch in andere Länder versenden (Europa), sofern das dann noch Sinn macht in Anbetracht der Versandkosten.
	Hi, deine Antworten sind nicht unbedingt schlüssig für uns. Bitte tu folgendes: Datei herunterladen: http://ucapps.de/mios32/midibox_ng_v1_032.zip Entpacken MIOS Studio aufmachen Rechts auf "Browse" In den Ordner navigieren, in dem die entpackte project.hex liegt Auswählen und dann auf "Start" Warten, bis der Vorgang abgeschlossen ist. Erneut überprüfen, ob der Filebrower nicht funktioniert.
- 85 replies
	Lieber Peter, ja, stimmt. Da hast du natürlich recht... nun... werd ich dann auch so machen. :-) Aber dennoch: Wenn jemand was braucht, kann ich es ja mit auf die Liste setzen. Dann spart derjenige zumindest ;)
