42 -
4
Everything posted by modus0perandi
No, i haven't. i will look into that feature later tonight i hope. Thanks for the tip!
Ok cool, i hope that also means that i would be able to apply fx on incoming data, mute etc even without recording, which was mostly what i was after, like how that box works which i linked earlier, but with added sequencer possiblilty of the midibox. :) Best regards!
I would think it would just work as a filter, anything routed to a track should be considered track data/information. As in: if i mute this track i think its natural to expect anything routed to this track would be filtered out (muted) along with any sequenced data on this track. If it works as you say, its not really routed to a track as i see it, but just using any midi out settings from that track which is something else. But in this case; i would humbly ask for this as a future feature request since i think it would add alot of value to the v4+ as a sequencer / midi device. The possibilty to add more extra/interesting midi effects would be icing on the cake.
I have a question regarding the midi router. Im trying to route midi from an external sequencer / keyboard / etc to selected tracks on the midibox but I dont understand how its supposed to work, so let me explain what im trying to do and what i expect since its supposed to route data. 1. I have an external sequencing source (that also acts as a master) that I put into the midibox seq on ex, port 1. 2. Using the midirouter I set up a node to receive on midi channel 6 -> route this to track 6 (on the sequencer). 3. Since im routing this to a track, im expecting (as the most simple use case) to for example be able to mute this track (and the incoming data) using mutes on the midibox, but this doesnt work at all. If i mute it, the notes from the external source still keep playing on the synth thats attached to the midiout of track 6. Also, i would expect to for example press record, and have the midibox record the routed data on the target track, this doesnt work either, so im totally perplexed as what the supposed function of routing to a track really is good for. I was also expecting, or atleast hoping, that it would also be possible to use the midibox, not only as an "insert" sequencer between this source sequencer and the final destination, but also as a midi effect unit and use the existing midi effects on the midibox on the incoming data (i saw this and got inspired; blokas.io - midihub). Adding this as feature toolset for the midibox would be really awesome, and also possible to expand the usage of the sequencer as a midi effect unit. Am i misunderstanding the concept of the midi routing on the midibox or is there something i have set up wrong here?
Something of a feature request if its not already possible (havent found a way atleast), with the v4+ i understand there are more resources to use, so this might actually be doable i hope! A "performance page" for lack of a better name where the knobs and buttons turn into "programmable" controllers which send output to where they are assigned. ex, knob 1 = midi output 1, chn 2, cc 60, knob 2 = USB 1, chn 5, cc 45 knob 3 = midi output 2, chn 2, cc 61 etc.... also the buttons could have triggers on them, assignable in the same kinda way, send on/off's, program changes or just control mutes (custom groups or similar), turn on/off fx and other features on the sequencer. The bottom row could select between different pages even, perhaps have page one to control synth x, page 2 could control synth y, page 3 could a mix of different things such as internal sequencer features and multiple external controls and so on.... i guess the sky is the limit regarding things to customize on such a page. I just think it would be nice to have a page that is really customizable for these kinda things since jumping around in menues to mute, change tracks or whatever is doable, but i think it could be made easier with this.
another bug i found is in the duplicate fx (v0.96): when using alternate channels: first channel is ignored, instead it only acknowledge additional channels but in a broken way. This is the way it works and how channels alternate: example, with first channel set 3 Additional channel 1: source channel (chn 1) -> channel 2 Additional channel 2: source channel (chn 1) -> channel 3 -> channel 4 Additional channel 3: source channel (chn 1) -> channel 4 -> channel 5 -> channel 6 Additional channel 4: source channel (chn 1) -> channel 5 -> channel 6 -> channel 7 -> channel 8 ...and so on It never care about the first channel setting which you can put to whatever you want and still get the behavior above. It seems to always start from channel 2 regardless of source channel as well. if i put the effect on channel 4, and put first channel 6, it would still start to alternate from channel 2 as in the explaination above. What should be according to the manual and common sense is: example, with first channel set 3 Additional channel 1: source channel (chn 1) -> channel 3 Additional channel 2: source channel (chn 1) -> channel 3 -> channel 4 Additional channel 3: source channel (chn 1) -> channel 3 -> channel 4 -> channel 5 ...and so on...
This is for a seq v4+, dunno if it affects the normal v4, but anyhow (v.0.96): Dunno if this is a bug or intended, i think its a bug or just weird behavior. If i'm in phrase mode and have "restart all tracks on pattern change" enabled, as soon as i press a keycap on the bottom row, to change from ex, A1 -> B1, tracks restart just when i press the button (i also have pattern change synchronization enabled), even tho i see it "queueing" up a pattern change to synchronize, then when the synchronized pattern change occur, the tracks do not restart. Shouldnt it be that the tracks actually restart when the synchronized pattern change occurs rather than when i trigger/queue a pattern change? To me this feature is useless like this, and i cant understand who would want to use it like this at all tbh?
Will these be merged to Master or will this just be a diverged branch / fork? I'd really like to be able to switch between track and layer muting, feels essential for drums.
Here is another Midibox in the wild. Lacking both time and skills to really build one myself, i had one of the trusted builder to handle that part for me. This one was built by @Menzman (Michael Menze) here on the forum. Very nice chap and highly recommended if anyone else wanna take this route to get your hands on this wonderful piece of hardware. You can find him via the trusted builders list @ midiphy) edit: if a moderator can move this to the correct thread in the forum (v4+) it would be great, i just saw i accidently put it in the wrong one :) sorry! @Hawkeye ?
yes, ill vote this up too. would be awesome and a nice magnet for more users i bet.
btw, the FAST button will also make "mute" happen immediately even if its set to mute on measure. :)
yea, i agree. overload of BLM shortcuts are not ideal, but i was more thinking of an option in the seq itself that would make it possible to set it to unmute all mutes when a pattern change (global or just for the group), i remember that the cirklon had that (when changing scene) and it was pretty handy.
also, is there a way to make midibox unmute all mutes when changing pattern (or atleast have this as a setting)? would make jamming using the BML alot nicer, esp since BLM doesnt respect mute/unmute to measure (pattern change on measure does however, so thats nice). I just think the BLM deserve to be expanded alot, since its an amazing feature of this sequencer. really make things more fun and more hands on, so im hoping it gets the attention it deserves! huge thanks for this, TK.
Im trying out BLM (both lemur version and 2x launchpads). Is there any way to select parameter layer from the BLM itself? using some alt-combo or such? Also, is there any way to change the track length, start / stop positions somehow? like holding the start position and pressing the end or so.
Finally! Gonna watch it this weekend. Thanks a million for the effort, hawkeye and the rest of the crew!
Looking forward to order kits asap. Just need to remember to check in frequently from now on. :)
absolutely amazing. Thanks for the effort, guys!
this is definatly something i will build. Will there be complete kits etc available? also, will the buttons be cherry mx switches or compatibles (sorry if this is already stated somewhere, but i missed it if so)?
Is there some way to simulate scenes with the midibox? perhaps that from the pattern page (or somewhere else) press a single key to maybe launch the "next" scene, which would be something along the lines of switching the pattern of all groups from (ex) B1 -> B2 at the same time and have them all start/restart from the beginning. perhaps even line up a change in advance by (when on B2) selecting B5 and then when a button is pressed, the next selected measure all groups / patterns get launched. maybe a new "scene" page could be nice to add for this. more thoughts; perhaps some extra settings on the page such as "keep tracks mutes", which if ON wouldn't unmute tracks on next-scene launch and unmute all tracks if set to OFF
if i could play accurately i wouldn't use quantize. :D
Hey, been playing around a bit with the sequencer lately and have some questions (requests if its not possible to do atm): first, when using quantize during live recording, is it possible to have it quantize when the pattern actually restarts rather than when the note is actually played. i found it pretty darn annoying to have notes getting cut off when triggered coz of the note just played being moved ahead in time so to speak. so a setting @ quantize where you can choose to quantize at the restart of the pattern (preferably only the notes that were played that "round"). another thing id like to see an improved humanize fx where also the note triggering get randomly shifted in time from the current position (where you set maximum ticks or whatever). maybe its possible to poll the coming notes to be able to shift it to trigger ahead of actual position. if any of this is possible already, let me know how plz :)
i had the same problem, but realized i tried to log in using my registered email instead of my username. try that.
still looking.
yea, i rather skip that entire circus and try to get hold of one from inside the union instead. thanks for the offer tho, Jaytee. much appreciated!
