1,285 -
72
Everything posted by Phatline
From the album: TekkStar (Tama Techstar Midification)
Hot Clue do the job -
the TOM4 Board was way to silent - I replaced the R1 or should that meen RI? (next to Rm) with an 10K Trimpot. Now I Have a Main-Gain - to Level the Voice togehter - to my whises finally i de-soldered the Rm - since i dont want stereo... i noticed when i go mono, i reduce some humm-sound... this because i removed the MIX-Board... i think on the mix board, when you connect only one channel, the other was switched to ground... i guess... and of course, the 10K Trimpot do the job excellent... -
Phatline posted a gallery image in Members Gallery
The TOM4 Board was to silent, i dont no why, maybe one of this broken Traces... I decidet to overdrive IC7 by paralell soldering a 4K7 resistor to R56 --- if you do other Mods aswell then better take a 5K6, the 4K7 can crackle the IC7 KRRRRR Finallyi used a 6K8, since after much other mods it was to loud... -
the broken TOM4 Board... the wires, are the "Repair of that Broken Board. The 100K Resistor well --- that is the BOOOOOOOOOOOOOOOOOOOMMMMM Mod! The Amp Decay gets longer! Finally i used a switch and the 100K, to switch between the extremes... the 100K make the VCA open all the time if the Decay Pot is on max!(only if it was triggered before...) -
Well almost all here: lcd for debugging 4Velocity Kill switches --- kill4 Velocity ranges, the red leds below are the toggle leds, the 4 greens indicates in which velocity ranges are most active (you can better choose the kill buttons then!( 2 Buttons under: One: for POWER - ROLL: just take any input notes and trigger it, no matter of Note-Number (momentary) TWo: Invert the Velocity Stages --- so what was loud is now not so loud, what not so loud now loud -
in the program stage --- we have 2 fader 1. Random Kill 2. Velcotiy-Offset >+-64 -
on th right is also place for a display and menu - when you shorten the powersupply-mount-screw a bit -
We see under the Powersupply we have 14x36cm Place for UI -
Zugentlastung mit Heiskleberpistole --- weil diese Litzen so leicht brechen -besonders beim Prototyping. A Chord grip done with Hot-Clue >>> Nessesery because of Prototyping-Testing Action >>> this will save some ours of Error Research! -
core on the backpanel - nice! -
mount the Core - already labbeled with the Program its a 18F452 IP .... 8 years old... the board old also... -
Shield the Core-Module against the Trafo -
a file do the fine -
I replace the orginal Powerchord against a "Kaltgerätestecker" > Power Connector a hand drill to the big hole -
cooled controlled 5V -
the 2 Bridges and the 7805 at top -
7805 alread soldered in -
Hole for the 7805, the Pin-Head, the 2 Bridges for +- input -
Find a Place for the 7805 -
the 7805 and his brothers.... in total we have here: -15V +15V +6V and soon +5V -
The Powersupply - where I add a 5V 7805 to supply the Core! -
Well the mixing board is away, and a small Breakout/Adapter and much more place is here -
By wasting the mix board, i have to build an Adapter, because on the mixing board acts also as REWIRING/ROUTING.... I thougt it where a good idea, to make also Connections for later mods (we have here + -15V what is great) -
Well I dont need the Mixing Board, it just Mixes a line in, and give you a headphone what I more need is PLACE!!!! -
Trigger Board connect to the Voices
