136 -
3
Everything posted by k2z3k0
	hello i have a problem with switching patterns via remote midi cc 112-115 and time clock. Mbseq and Octatrack (via TM-1 ,is Elektron made usb to midi interface for faster(10x) midi transmission ,Tubo mode is ON) are connected to my computer via usb. in my computer i am sending Mbseq midi clock and notes on channel 1 to play samples in Octatrack on channel 1,Ocatrack sample player is set to time stretch mode so dependent of midi clock Mbseq patterns are controlled via launchpad via MIDI in 1 ,i made it so that via top row buttons i can switch all four patterns ,sort of groups so under each of eight buttons i have set of four Mbseq patterns ,so e.g button 1 mbseq patt 1,1,1,1 ,button 2 mbseq patt 2,2,2,2 etc.. i also can recall individual patterns with launchpad mbseq is set to -track sync steps per measure 32 -patt change sync each 8 steps -pattern change sync on, -restart all tracks on, ok so i have simple pattern with break sample in time stretch mode , when i am starting press constantly on my launchpad only pattern 1 button on my launchpad ,pattern is being recalled every 8th step as expected sample is playback as it should but,when i press my launchpad group button to recall all four patterns on mbseq ,what happends is pattern is being recalled,but just when recall happends midi clock slows down , and then comes back to normal when i stop pressing and because sample that is played by OT is in time stretch mode,so dependent on midi clock this is why i can hear that, also if i recall independently two patterns i can hear that but little less then when all four are recalled i also checked with monitor and i am sending clear cc 112 ,113 ,114 ,115 so no extra garbage is getting there this situation does not occur when i turn off Turbo MIdi Tm-1,or when i recall only one pattern,or when i recall pattern from MIDIBOX it self via panel, or when sample is not in time stretch mode. i am attaching two example recordings, so you can hear what happends for your self, one is just wav from octa,other is from ableton -in octa example in the middle of first part i am starting to recall all four patterns constanly with Turbo Midi off,and sample is playing correctly in the middle of second part i doing same thing but with Turbo Midi on,and clearly you can hear sample speeds down for a moment -in ableton example once im starting to recall all four patterns you can see that bpm counter is going from 154 to 147,and you can hear same playback speed is dropping so in conclusion 1.i think is possible that midibox gets little wierd when more patterns are recalled and midi clock is getting bit flaky during switching ,however internal Midibox Info does not shows any drops ,CPU Load goes 10% higher 2.maybe this is somehow regulated by 31250 midi bus speed and is not audible when using din 5 ,but becomes a problem when going over usb and bus speed is higher . thank you bests midiboxseq switching patterns via midi remote .wav Screen Recording 2025-05-02 at 15.53.13.mov
	hello there i just experienced loss of my patterns data after i did SAVE and changed pattern via midi cc# 112-115 i am controling patterns with external controller,so i pressed SAVE "Complete Session stored" ,and right after i changed one of the patterns via external controller, then mbseq hangs,and after reboot patterns where gone. maybe mbseq does not protects save operation and allows to execute program change via midi cc's ,thus leading to data loss ? i had backups so it was ok for me but i can imagine when one does not have bests
	thank you
	hi everyone can anyone tell me if i can use this board to run mbseq v4 on it https://www.st.com/en/evaluation-tools/nucleo-h723zg.html i want to use it cause it has faster cpu then stm32f4 ,so i am hoping for more precision in midi data thank you in advance bests k
				restoring seq_ui_button_state.FAST_ENCODERS from BM flag does not work
k2z3k0 replied to k2z3k0's topic in MIDIbox SEQ
thank you TK bests Kazik -
hello T ok so i am on http://www.ucapps.de/mios32/midibox_seq_v4_098_pre2.zip fresh new project 1.make GLOBAL BOOKMARK #1 for DIVIDER with FAST ON, 2.FAST is ON and CLOCK GP #2 scrolls fast, 3.switch to EDIT page ,FAST is automatically turned off, 4.recall GLOBAL BOOKMARK #1 ,FAST is ON BUT not working,CLOCK GP #2 scrolls normal 5.switch to EDIT page,turn on FAST,recall BOOKMARK #1 now FAST is ON and working in SEQ_UI.C it says and to restore i think there might be a bug somewhere,something missing it seems seq_ui_button_state.FAST_ENCODERS = 1 is turning FAST button LED on but not the FAST function when recalled from BOOKMARKS i also tried to use seq_ui_button_state.FAST_ENCODERS = 1 for example when switching to MIXER page so my encoders work fast in MIXER page,but same effect p.s. while i have your attention , in HUMANIZER there is 2nd option VEL/CC ,should that humanize VELOCITY and MIDI CC messages from PARAMETER LAYERS of the track? cause when i set track with one CC param HUMANIZER does not humanize that CC layer thank you for your time best regards Kazik -
	little a side question,but how can i make humanizer/robotizer work on CC's ,i have NOTE track with CC layer,and when turnin VEL/CC in hum/rob i does nothing,wha i do wrong?
	hello did anyone tried HUMANIZER to CC values? i have NOTE track with one layer of CC ,but when i turn VEL/CC on in HUMANIZER it doesnt do anything bests
	hello did anyone tried HUMANIZER fo CC values? i have NOTE track with one layer of CC ,but when i turn VEL/CC in HUMANIZER it doesnt do anything bests
	hi did anyone tried that ? i can make it work with 0..15 but not 127 for currently selected track o CC#99 (0x63 - NRPN MSB) Selects the Track which should be modified via NRPN Allowed values: 0..15 for Track 1-16, 127 to modify the current selected track seq_midi_in.c says case 0x63: // NRPN MSB (selects track, if >= SEQ_CORE_NUM_TRACKS, take the currently visible track) nrpn_msb = value; break;
	hello there do anyone know some one i could send broken AOUT NG module for fixing? something happend to mine,and i have no idea how to repair it there is nothing coming out of it bests K
	hi everyone is possible to generate random values only for steps with trig?
	u8 base, range; seq_par_layer_type_t layer_type = SEQ_PAR_AssignmentGet(visible_track, layer); if( layer_type == SEQ_PAR_Type_Length ) { base = 16; range = ((par_layer_range[layer] >> 2) - 1); // -> +/- 16 if( !range || range > 128 ) // (on underrun...) range = 1; } else { base = 0x40; <- WILL THIS DO THE TRICK? range = par_layer_range[layer]; }
	hello everybody I noticed that when randomizing clean empty track LayA(notes) with value 1,(TrgAll),it makes -1 / +1 deviations from 64 which is E-3. Now initial note for track is 60 (C-3) and this makes a bit strange situation ,that randomizer starts from other point then initial note value(60) Also i want to ask if there is a way to set default initial value(now 64,C-3) of notes,there is initial value for CC(option 24/33),maybe would be great to have one, also for notes. And maybe would be great if randomizer deviate starting from that default init value thank you in advance best regards Kazik
	yes it is! result is amazing! thank you TK kind regards
	yes i suppose is just minor thing to straight out in code if you go to Menu -> Midi ->Transpose and Arp ,there yes you can set CHANNEL to AUTO BUT if you go to Utility -> Jam -> MIDI ,there you CAN'T set Midi channel to AUTO,instead is showing Channel #18 but as i said i suppose is little thing to straight out we just need to wait and give careful and precise feedback and as always THANK YOU TK for your time i feel if this works out correctly it will be huge upgrade for live perfomance capabilities of MBSEQ v4. thanks for your time Kazik
	Auto channel works! only thing is when i send on Midi channel #5 is switching to Track #1 seems it do not switch to the next group Morph works good so far! Kind Regards
	that was quick... amazing! running tests! THANK YOU TK!
	Exactly! thank you for such quick response best regards Kazik
	hello everyone While working with MORPHING(mbseqv4),i thought would be great to be able , to have option that when called(puch button) leaves currently Morphed values and sets Morph back to zero This way you could quickly build patterns just from using Morph thank you for your time Kazik
