136 -
3
Everything posted by k2z3k0
https://soundcloud.com/k2z3k0/sferical-substance-omega
https://soundcloud.com/mazikandmazik/slowshow
hi Peter so first 8 tracks from mbseq is sampler (Z8) but in order to gain more timing accuracy first 4 from out1 second 4 from out2 then track 9 moog,10 sh101 AOUT,channel ,11 ms20 AOUT,12 microq midi input one is midi cotroller to control Z8 params:filter,reso,pitch and MBseq param:transpose and track length thats basicaly it bests
- 10 replies
- 1
- break
- distorstion
(and 1 more)
Tagged with:
nice to meet you Jerome something over 10 years to collect and tune to achieve this mbseq was what i was looking for over past years
- 10 replies
- break
- distorstion
(and 1 more)
Tagged with:
And of course beloved mbseq4 with aout:ng bests
- 10 replies
- break
- distorstion
(and 1 more)
Tagged with:
i had a wave of aphex mania lets say ,nevertheless still like some of his music setup is mackie,akai z8 with 8 outs,korg ms 20,moog slim phaty,waldorf micro q,and few other actualy on this track i tried V MACHINE from SM PRO,and predatohm vst - sounds interesting after few try outs ;)
- 10 replies
- 1
- break
- distorstion
(and 1 more)
Tagged with:
sure do ;) seq4 RULEZ!!!
- 10 replies
- break
- distorstion
(and 1 more)
Tagged with:
https://soundcloud.com/mazikandmazik/mush-plus-knob-equals
- 10 replies
- break
- distorstion
(and 1 more)
Tagged with:
hi midi maniacs i have proposition for seq 4 to add PITCH to LFO destinations and to add extra features to SELECT TRACK maybe together with ALL button,something like MUTE + ALL it could contain:all,grp1,grp2,grp3,grp4 and so on kind regards k
hi TK thanks a lot kind regards
dear all i running midibox seqv4 stm 32 v4_091_pre8.zip i noticed now when i press SAVE ALL (F4) and change ALL patterns for example from A1 to A2 and back to A1 GROUP 4 patterns and settings are saved to GROUP 4 and GROUP 2 BUT when i use MENU + SAVE and i save GROUP 2 to A1 and recall ALL patterns for example A1 to A2 and then back to A1 GROUP 2 patterns and settings are saved to GROUP 2 and GROUP 4 if i do the same with GROUP 4 it saves ist to GROUP 4 and GROUP 2 does anyone meet this situation???? or im making mistake somewhere? PLEASE HELP this is pretty anoing thanks k
hi everyone i think im on the track of a bug here so im running mb seqv4 MBHP_CORE_STM32F4 v4_091_pre8 while slowly filling new session with sequences and parameters,in one moment SAVE ALL is saving GROUP 1 and 3 corectly, but GROUP 4 is saving to GROUP 4 but also into GROUP 2 but not other way around GROUP 2 into 4 While MENU + SAVE for GROUP 2 save it to GROUP 2 and 4 after saving all looks ok,but when i switch for example PATTERN from A1 to A2 and then back to A1,then i can see it happend i cant tell after what condition this situations starts to take place but i have feeling its somewhere after filing up the memory hope my description will help to trace this problem kind regards K K
hello TK looks like mbseq v4+ will be very nice thing to work with-can't wait! thank you for your time kind regards Kazik
dear Midi Freaks while working a lot lately with seq4 i have two ideas 1. could be Jam Recording Single and Multi channel ? SINGLE CHANNEL MODE:incoming data is recorded to Selected Active track MULTI CHANNEL MODE:incoming data is recorded on same channel that is coming from if not-would be possible to make Selection of Active track remotely controlled by midi and sensitive to current midi channel of incoming data? 2. idea for midi BPM to PITCH converter I notice if loop is on 170 bpm and pitch bend range of that loop is 12(up&down), and seq is also 170 bpm then if i have track layer PItch bend set to 32,64 or 96 its gonna slow or speed up loop exactly double so i thougt maybe there could be a function included in each track that if on checks bpm and accordingly to ,calculate and change Pitch bend value so loop is always on exact pitch(speed) to match bpm of seq bests Kazik
thanks jjonas i forgot to mention that it was Layer A
hello everyone short question could SELECT+CLEAR also cleared NOTES layer? kind regards p.s.testing v4.91 pre8 ,all runs smooth
hi everyone i noticed that while on CC (NOTE and CHORD works ok) type track while being in the Live rec mode, Rec is on after executing UTILITY->CLR ,sequencer do not record CC data anymore on the selected track but is stil reading incoming data (in Edit page ,step number changes when CC data incoming) is just not inserting it in to the Layer steps also Random Generated values are not inserted after UTILITY->CLR to be able to record again i have to INITIALIZE the track also situation CC or NOTE or CHORD track in Live rec mode ,Rec is on when i execute Select + Clear Rec is sudenly Off but after turning it On in Jam page,sequencer is back to recording incoming CC data to layer steps so would be possible to have Recording going ON after UTILITY->CLR (maybe little check why data is not recorded)and Recording stay ON after SELECT+CLEAR ? or is this how its intended? p.s. also one moment had idea that different Timing DIVIDE'rs for each layer could be great. sincerely Kazik
hi TK i noticed that while on CC (NOTE and CHORD works ok) type track while being in the Live rec mode, Rec is on after executing UTILITY->CLR ,sequencer do not record CC data anymore on the selected track but is stil reading incoming data (in Edit page ,step number changes when CC data incoming) is just not inserting it in to the Layer steps also Random Generated values are not inserted after UTILITY->CLR to be able to record again i have to INITIALIZE the track also situation CC or NOTE or CHORD track in Live rec mode ,Rec is on when i execute Select + Clear Rec is sudenly Off but after turning it On in Jam page,sequencer is back to recording incoming CC data to layer steps so would be possible to have Recording going ON after UTILITY->CLR (maybe little check why data is not recorded)and Recording stay ON after SELECT+CLEAR ? or is this how its intended? p.s. also one moment had idea that different Timing DIVIDE'rs for each layer could be great. sincerely Kazik
hi there I have proposition for additional Lfo destinations Pitch Control,Prob,Delay,Roll,Roll2 and Clock division also would it be possible to have more than 1 Lfo generator per channel? bests
thank you Thorsten like always quick and consistent bests
hi Thorsten i have midibox seq v4 also now i realised when my track is in CC MODE and if i press and hold Parameter Layer key C (and i have more than 4 layers mode track) in order to choose layer for edit above each layer there is only "CC" also in Note MODE there is only "CC" maybe could be possible to put there for example "Lay(letter of layer)" and/or "C(cc controler number)" best regards Kazik
hello there short question would it be possible to switch center of range of Random generator from 64 to 0 or 127 for example Holding SELECT key and rotating encoder of desired parameter so then the range of parameter will define how far from that center it will go? happy new year to all Kazik
each track remember what Layer is Edditing
k2z3k0 replied to k2z3k0's topic in MIDIbox Tools & MIOS Studio
thank you Thorsten it works as a charm! all the best in new year! Kazik p.s. where i can find whishlist?
