Keeze
    60
    4
Everything posted by Keeze
  1. You could checkout the devices Deft Audio builds and sells: Teensy 3.2 MIDI Breakout board, 3in / 3out, USB from Deftaudio on Tindie. Pretty cheap and fully programmable (teensy) Nice thing is that he has example firmwares available. I used the 8 in 8 outbox from Deft audio and programmed it myself with the use of his example sketches.
  2. Bumtibump... Still available
  3. A ENC28J60 based board (about 5 euro) should do the job I think... Search this forum for this term. I have one in my SEQ4.
  4. I aim for €500 Stand alone:
  5. Wilba Front Front: 2 midi in / 2 midi uit Back: 2 midi in / 6 midi uit OSC Including build-in 230V psu Fits perfect in the desk I built (which is also for sale), but can be transformed to its original case. Why? I started playing guitar and I came to the conclusion that the guitar fits me more (played more guitar in a half year than synths in 5 years...) More info: Zolderverkoop | KC's Hobbyprojecten (vanhoekelen.nl) (Dutch) Also for sale: Mutable Instruments Ambika, Mutable Instruments Shruthi, PreenFM.
  6. Hi, When I try to export these pages as PDF, it is missing al the screenimages, alyone else has this problem? Cheers, Kees
  7. After some trial and error I had good luck with the Roland UM-ONE mk2 (YMMV). Cheers
  8. It's already on midibox_tia [MIDIbox]? Cheers
  9. Calculate 3 digit capacitor: 330 (kiloohm.info) 22 and 470nF it is.
  10. And another TIA cartrige bites the tones :) Tnx @Antichambrefor this project and your patient support :)
  11. Hey @TK., Nice, clean look, thanks for upgrading the forum, but, this was the perfect moment to implement SSL? Cheers, Kees
  12. Thanks Thomas, but I already found that page. As @antichambre stated, I only want to use interrnal characters. There must be a simple way to achieve this I hoped (without having to us 2 character postions like ->). Cheers Kees
  13. Hi all, my first NG-project is alive ;) I build a switchable USB to 4 DIN midi port router. Al from parts I have laying around. After a evening digging this forum and trying, it just works. Now I can control my Volca's with a single USB midi keyboard (hurray). I don't get one thing: How do I get special characters on the display?? For example in the next line I like to have a arrow instead off the >-sign (or the solid >) EVENT_SENDER id=1 if_equal=Button:1:1 fwd_to_lcd=1 type=NoteOn chn=1 key=any lcd_pos=1:32:1 label="> %e" ports=00001000000000000000 [17:36] Is this possible with NG? Cheers, Kees
  14. Hi all, I noticed that this forum has no encrypted connection https (anymore)… Has this always been so, or is this new. Since we all login over here, I think this is a bit of a security issue, since our passwords are transmitted in plain text. So especialy for those who use passwords on multiple sites (never a good idea) beware.. Cheers, Kees
  15. Tnx, tried it without the \ seqregex = re.compile("MIDIbox SEQ V4\+:MIDIbox SEQ V4\+ MIDI ([1-4]) [0-9]") works! Cheers, Kees
  16. So, finaly took the time and a PI3 I had laying around and installed the software.... The problem is that pyBLM can't find the Seq4: pi@pyblm:~ $ ./pyblm/pyBLM.py pyBLM launched. pyBLM init ERROR: Couldn't find the seq When checking for available midi-ports I get: pi@pyblm:~ $ amidi -l Dir Device Name IO hw:0,0,0 Launchpad Mini MIDI 1 IO hw:1,0,0 MIDIbox SEQ V4+ MIDI 1 IO hw:1,0,1 MIDIbox SEQ V4+ MIDI 2 IO hw:1,0,2 MIDIbox SEQ V4+ MIDI 3 IO hw:1,0,3 MIDIbox SEQ V4+ MIDI 4 IO hw:2,0,0 Launchpad Mini MIDI 1 Output of mido.get_input_names() gives: MIDIbox SEQ V4+:MIDIbox SEQ V4+ MIDI 1 20:0 MIDIbox SEQ V4+:MIDIbox SEQ V4+ MIDI 2 20:1 MIDIbox SEQ V4+:MIDIbox SEQ V4+ MIDI 3 20:2 MIDIbox SEQ V4+:MIDIbox SEQ V4+ MIDI 4 20:3 Looks like the naming of the Seq4 ports has changed (I use firmware version 4.096). I tried to alter the seqregex function, but no luck .Since I don't understand a *** of regex and re.compile is used for finding the Seq4 I am a bit stuck. When I revert to an older version of the Seq4 firmware pyBLM starts to work. Can you give me a clue how to stay on the latest firmware and get the pyBLM to work as should? Thanks in advance Cheers, Kees
  17. Keeze
    KC's pictures
    Just some various images of my Midibox/Music builds
  18. Yes, mine too, although I was a couple of years older.... Great, end of summer is ok!! ~Cheers, Kees
  19. Hi Antichambre, I am also interested in a PCB and TIA chip... Still got some? Cheers, Kees
  20. A W E S O M E ! ! I tried to get a hard fault, even turned the LPK in a 32th note arp... No !! HARD FAULTS !! any more. Thank you very much TK. Cheers, Kees
  21. Hey TK., This works! So the order is correct. Now I have to find out why I get !! HARD FAULTS !! after some time (20 to 30 seconds of playing) Setup: Akai LPK25 -> via usb -> RPi B+ -> via osc -> SEQ4 -> routed to Midi out1 -> Shruthi The address location is different every time.. Cheers, Kees
  22. Hi Tk, Tnx again! When I send to SEQ4, the midi monitor on the SEQ4 recognizes sysex. I route the incoming OSC to USB1 and MIOS Studio gives me: While I send: matches found: midimessage ( 144, 60, 116 ) -> /midi1 ,m MIDI [0x00 0x90 0x3c 0x74] matches found: midimessage ( 128, 60, 127 ) -> /midi1 ,m MIDI [0x00 0x80 0x3c 0x7f] These are the last two messages. and should give: 90 3c 74 80 3c 7f Same messages sent to OSC tool (velocity changes due to real keyboard used ;)): Cheers, Kees
