Dimduj
26 -
Everything posted by Dimduj
Subscribing ;) Amazing project ! Keep going and thx for sharing !
The HAARP, a Hardware Advanced Arpeggiator.
Dimduj replied to Antichambre's topic in MIDIbox User Projects
Hi Bruno, Any updates about the haarp project ? Regards, DImitri -
Yep, thx for the explanation I thought the trimpot was a kind of offset not a coefficient. my mistake was trying to set up the trimpot while I’ve values already defined for step 1v, 2v ,... once I setup all the value to zero again calibration was easy and now I got acceptable value for every channel. is got a precision with 15-20 cent variation between octaves of a channel. Do you achieve more precise values on your side ? thx for the support
- 135 replies
- line driver
- cv/gate
(and 2 more)
Tagged with:
Hi everybody, I’ve finished my aout and everything seems to work as expected until I do calibration procedure: i begin with the 5v step at 0v using the trimpot . after that I do 1v, 2v, 3v, 4v steps and when I go back to the 5v step ( with zero calibration correction) the voltage isn’t a 0v anymore.... no matter how many I try to reproduce thoses step. I cannot have a précise calibration and my vcos aren’t tracking properly. ( I use bipolar calibration) any help will be appreciated :)
- 135 replies
- line driver
- cv/gate
(and 2 more)
Tagged with:
Before touching your probably well calibrated module : Moog uses middle C = 0V while other Euro modules assign 0V to the lowest MIDI note or the lowest note on a 61 key keyboard. regards
LRE 4x1 breakable RGB LED-Ring/Rotary-Encoder PCB bulk order
Dimduj replied to weasel's topic in Bulk Orders
I’m also interested !!!! -
Thx for the answer TK ! I already use the PRESET ad a default SESSION for the initial setup and it works easily . What puzzle me is he fact that I have to reselect the PRESET each time I go to a new pattern. If I change my mind about some instrument config (the channel for example) I've to edit each pattern to reflect that change Is this the expected behaviour or am i missing something ? I would expect that if I choose an instrument (PRESET) for a track It will be use for every new pattern unless I choose another instrument (PRESET) for a specific pattern? Are PRESET defined per track or per pattern ? Maybe the 'Save & Take over' feature could be a workaround for my first issue. Sorry for the late reply but i try to avoid asking super dumb newbie question and it took me times to explore the features and make a correlation between user manual with Wilba workflow and the new Midipy workflow;) Thx again for the support and congrats for this amazing piece of hardware I really enjoy it !!! Take care
I hope so !!! I’m so happy with the midi box seq v4+ amazing piece of software, hardware... and case ;)
Mmhh i’m not in the confidence so it is just a guess but I hope they will release a blm soon
Can’t wait to order the midiphy BLM ;)
Hi I’ve a midibox seq v4+ and one thing I struggle with is that each time I switch to a new pattern I have to reconfigure all the tracks setup (midi port, midi channel, track length). i probably miss something but is there a way to define the track setup globally or even better, per session ? i try to search on the wiki, and on the forum but didn’t have any luck i don’t mind editing some files directly on the SD card if it is the way to go but all I’ve tried do not works:/ thx for any suggestions dimitri
Hi ! Speaking of drum tracks, would it be possible to define one midi channel per instrument/drum and ( maybe with sort her track length?) a note parameter ? I also search in the forum but I think no one has ever ask it so I take the risk ;) would it be possible in the future to have more than 16 active tracks ... I now I probably ask for too much :p
Hi ! i’ m exploring the features of the midi box seq v4+ and I got some questions. Sorry because it is probably noob’s questions but I didn’t find informations on the docs... hope it is the good thread ;) What is the purpose of the MEC “Shift” button of the seq v4+ ? Is their a way to just copy a specific trigger/param. What if I just copy/paste the accent trigger but not the gate trigger between tracks ? How can activate the step forwarding when I do not record ? When playing with live mode activate the seq do not jump to steps over 16. Is this the normal behaviour? when in recording with live mode activated, the seq will. It jump to next steps ( 17-32) only once.is their a way to activate the forwarding not only the first time. Cheers
Didn’t remember the exact temp but I think it was specified on Hawkeye video tutorial. Good build!!!
@lukas412 i also use a hot air for all the smd parts and I do not regret my choice but choose the iron for the flux . It seems easier to control the temp and do not fry the superlux.
Hi ! May i assume i’ll get the number #16 ? https://ibb.co/qySpHYL
Hi Guys, I've finished my midibox seq V4+ few weeks ago but didn't time to post until now ;) Thx to latigid on for his awesome support and TK for the amazing software. I’ve almost scratched the surface but it is above my expectations on every aspect !! I really enjoy the build !!! and here is some feedback about my build: About the video build form Hawkeye: * Super awseome work, i cannot imagine the time it took. It is enough detailed, Hawkeye's voice is pleasant and enjoyed and that's great :p. I learned some tricks during the video so :+1: * I admit I'm not a video guy and prefer to read. So maybe take this with a pinch of salt. I always tend to skip some minutes on video tutorial and you can miss some precious informations (5mm nuts/ 3mm nuts) * It will be a great to have high res pictures of boards on important steps like checkpoints contro, MIOS tests, etc ... * I would prefer smaller video and a playlist: this is easier to find a precise step of the build (granluarity of video head isn't easy on a 2hours long video) About documentation: It could be great to have a documentation of common pittfals: Do not solder encoder before led matrix, Do not mout header that wrap 745 to soon 5mm 3mm nuts when connecting the board (they are in the same and If Pay attention to Do not solder sd card header without attaching the USB board first to be sure get enough clearance. A screenshot of all the ribbon cable to do with length and pin count and precise header orientation would be really usefull. I wish I had paint sides of mathias with black to avoid light beed on sides. Now my mathias do not pop out and I'm stuck with light bleed. especially when you are not exactly in front of your midibox (I've made a video bellow eight first I put tape no bleeding button 8 to 16 no tape => bleeding). This is espacially true with cusom key caps (Thx Antichambre I love them ) I will upload pictures of my awesome SEQ a little later but had to resize them first.... Cheers Dimitri
Mmmhhh cannot help further sorry :/ One last advice, Before soldering mathias switch take time to recover them with electrical tape or paint sides with a marker to avoid light bleed between them. i was really annoying with light bleed between steps. Caps are hard ( impossible ? ) to remove once placed and it took me lot of time to place tape to isolate light with caps installed. Cheers
Hi all, @knochenfabrik just my two cents: Did you check the last/first encoder pins are not touching the pins of the ribbon header . You can check that looking at the side of your build?
Thx Latigid on, I will document that in my review once my build is done . i progress and have a small issue :https://youtu.be/JU_dDLcqE1g the fourth last led of the right panel do not light up during fluxtest. when I test each superflux individually using a battery coin they all work properly on each color. I already reflow ic2 and ic3 and they seems to be correctly soldered. any idea ?
SOLVED Had to delete midi setup in Mac Os as described in this page: http://www.ucapps.de/midibox_seq_manual_in.html I've an issue uploading the midibox seq app to the coreboard using MIOS. Whatever I upload projet.hex of midibox_ng_v1_036 or midibox_seq_v4_095, I cannot see other midiport than the MIOS32. I rescan midi devices but no success, rebooting MIOS,... dissconnect USB ....) Is that normal ? I'm not sure I get the right files. Sorry I'm really new with the midibox seq and I've few ressource to check about seq V4+. I never know what docs about seq 4 are applicable for the V4+ version Hawkeye vidéo is great but a little blurry regarding his monitor screen ;) I run MIOS on Mac OS on High Sierra 10.13.6. After uploading midibox_ng_v1_036 I can load seq_l but the only available midi are MIOS32. I can browse the SD card and see existing file using MIOS Tools.
Thank you so much ! I’ve not finished but the rest of the build has been easier. It’s fun that I fail on a simple trough hole ressistor with smds and super flux led ;) I ve done a lots of other project such as shruthi, lxr,.. but I really enjoy the project so far because their is many new assembly technics ! See you at the next issue ;)
Hi everybody, First post :) trying to desolder r5 from the usb connector pcb, I removed the pads... no way to solder the new resistance. Where should I connect ( shortcut) the resistance ?are schematics available somewhere ? is this resistor needed to run the seq or is it just a led’s ressistor ? Congrats for this amazing project! dimitri
