TK.
Administrators
    15,248
  1. Hallo, willkommen im Forum! :) Ja, das MBHP_IIC_MIDI Modul kann man auch von anderen Mikrocontrollern aus ansprechen. Dazu braucht es noch nicht einmal einen IIC Port, die Kommunikation funktioniert auch per "Bit-Banging" (SCL und SDA direkt von der Software aus stimulieren). Mit einem integrierten IIC Master Peripheral ist es natuerlich bequemer. :) Gruss, Thorsten.
  2. Note that the PIC has two PWM outputs as well. However, controlling the brightness of individual LEDs is not possible with the MIOS concept, as it would load the CPU so much, that no other tasks could be executed in parallel. Problem is, that you need a PWM period of 10 kHz and more if brightness should be controlled with a resolution higher than 3bit. Thats the reason, why normaly dedicated chips (or microcontrollers with special integrated PWM peripherals) are used - they keep the load of the main CPU low. Best Regards, Thorsten.
  3. So long you are using prepared track configurations, no changes in the code are required. Such configurations could even be edited on a PC and transfered to MBSEQ via SysEx.... if an editor would be available. However, SysEx dumping is supported, so the basics are there. If you have some programming experiences, why not writing an editor from which every user could benefit? :) Best Regards, Thorsten.
  4. Razmo tried this, and it didn't work in the first place. After some emails it turned out, that there is a DC offset at the output of YAC512, which will be amplified above 5V after IC3 and IC5. This completely removes the AC part if OPAs are only supplied by +/- 5V, so that the audio output behind IC6 is silent. Workaround was to add a cap/resistor pair after each IC3/IC5 output in order to remove the DC part Note also, that using the 5V supply of the digital domain will add some noise to the analog domain. Razmo used a seperate transformer. Best Regards, Thorsten.
  5. Oha - das liest sich, als gaebe es ein Problem mit Reflexionen auf den Signalleitungen. Praktisch konnte ich damit bisher keine Erfahrungen sammeln, deshalb bin ich mir auch nicht sicher, was nun die perfekte Loesung ist. Die Theorie wird hier kurz erklaert: http://www.elektronik-kompendium.de/sites/grd/0301035.htm, und sicherlich auch irgendwo in Wikipedia. Probiere mal folgendes: schliesse die SC und RC Signale am Ende der DOUT und DIN Kette (J2:SC/J2:RC) mit jeweils 220 Ohm-Widerstaenden gegen Masse ab. Wenn das nicht weiterhilft, probiere auch mal 100 Ohm, 470 Ohm und 1k (falls vorhanden) - ich weiss hier wirklich nicht, welcher Wert besser geeignet waere. Die DI/DO Signale sind nicht so wichtig, da die Leitung zum jeweils letzten IC im Vergleich zu RC/SC sehr kurz ist. Auch fuer die Spannungsleitungen sind die Widerstaende nicht relevant. Wenn das weiterhilft, schreit es geradezu nach einer neuen Wikiseite ;) Gruss, Thorsten.
  6. The Synched Pattern Change function doesn't check for the end of a track, but synchronizes a pattern change on the 4/4 measure. It isn't so easy to determine when all 16 tracks have reached the end, especially because of all the possible variations. For example, what if one of the tracks uses different progression parameters, or is clocked at a different speed? Should the synched pattern change really wait until (let's say) all 1024 steps have been processed? It would make the synch function useless! The other sequencer hardware you mentioned, which one do you mean exactly? What is the usemodel, and what are the possible variations? E.g., a common groovebox doesn't allow you to control the track direction, to skip steps, to play them multiple times, to jump randomly and/or to play steps at different speed. For a simple sequencer determining the end of a track is very easy... but not for a more advanced sequencer like MIDIbox SEQ. What I would find more useful (as usemodel), is the possibility to optionally synch pattern changes to two or four measures (=32 or 64 16th notes). I guess that this is the function for which you are asking, right? Best Regards, Thorsten.
  7. Probiere mal folgendes aus: - die 74HC165 des dritten DIN Moduls nacheinander entfernen - tritt das Problem auf, wenn keine ICs mehr in den Sockeln stecken? Oder tritt es auf, wenn mindestens einer im Sockel steckt. Welcher Sockel macht Probleme? - MIDIO128 aufladen und an den Encodern/Buttons herumspielen, die am dritten DIN Modul angeschlossen sind. Jeder Encoder sollte zwei Noten senden, jeder Button eine Note. Sie sollten niemals den gleichen Notenwert senden. - das Kabel zum J1:SI Ausgang des dritten DIN Moduls entfernen - die Encoder/Buttons haben nun keine Funktion mehr, doch tritt das Problem an den DOUT Modulen immer noch auf? Falls ja: SI wieder anschliessen, stattdessen J1:SC abklemmen und testen. Das gleiche auch nochmal mit J1:RC ausprobieren. Die Ergebnisse sollten uns genuegend Input geben, um das Problem besser eingrenzen zu koennen. Gruss, Thorsten.
  8. Yes, it's obscure why you can upload an application correctly, but not a MBFM patch. You can check the reliability of your MIDI interface the following way: create an external feedback loop (MIDI Out->MIDI In) on your PC interface, open the SysEx tool of MIDI-Ox, load the patches into the command window, press Command->Send/Receive SysEx, and thereafter compare the dumps with the SysEx->Compare function. If MIDI-Ox finds errors, you know that the MIDI interface is the reason. Another point is, that you could have overlooked a programming error during application upload. So, just to ensure that MBFM is complete, upload the application again, and doublecheck that all code blocks have been acknowledged without an error message. Best Regards, Thorsten.
  9. Hi Alex, currently there isn't an application available which fits exactly your needs. But I guess that it could be easily programmed with the SDCC wrapper. Or maybe somebody has already implemented a similar floorboard application, which could be easily adapted? Best Regards, Thorsten.
  10. TK.
    Current draw
    The power consumption mainly depends on the LCDs, LEDs and SID chips you are using. I cannot give you the exact values for each seperate module, but the overall current draw of my completely stuffed MBSID: ca. 1A in the 5V branch, and ca. 0.2A in the 9/12V branch. The consumption of the AOUT_LC module can be ignored (I guess about 10 mA) Best Regards, Thorsten.
  11. this will work Best Regards, Thorsten.
  12. I think that the last encoder assignments won't work this way: ;; encoders 33-48 ENC_ENTRY 13, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 33 ENC_ENTRY 13, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 34 ENC_ENTRY 13, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 35 ENC_ENTRY 13, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 36 ENC_ENTRY 13, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 37 ENC_ENTRY 13, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 38 [/code] It isn't explicitely mentioned, but double-assignments are not allowed. Instead, you have to assign the last two encoders to individual pin groups, e.g. 14,0 (for SR14, pin 0 and 1) and 14,2 (for SR14, pin 2 and 3) Best Regards, Thorsten.
  13. Memo: bei PIC Problemen aller Art, einfach mal dem Onkel Doc-tor zuschicken (er nimmt auch keine Praxisgebuehren ;-) Paya: schreib' bitte Mike eine Mail, dass der Bootloader nicht programmiert war Gruss, Thorsten.
  14. Da die analogen Eingaenge an J5 wahrscheinlich nicht auf Masse liegen, waere die MIDIO128 zum Testen besser geeignet. Ich habe von diesem Phaenomen schonmal von einem anderen Anwender gelesen, damals war es glaube ich aber nur eine einzige LED, die flackerte. Aufgeklaert wurde es nie (zumindest habe ich keinen Feedback erhalten). Deshalb waere es sehr interessant zu wissen, ob das Problem nur mit der MBSEQ Applikation auftritt. Gruss, Thorsten.
  15. Vielleicht ist der 5A Regulator etwas ueberdimensioniert, und die Spannung steigt zu langsam auf 5V an. Was passiert, wenn Du mal kurzzeitig einen Reset an MCLR# (PIC Pin #1) ausloest? Dazu braucht es keinen Taster, Du koenntest das mit einem Kabel nach Masse ausprobieren. Gruss, Thorsten.
  16. Ja, das funktioniert wie auf der MBHP_IIC_MIDI Seite beschrieben: Gruss, Thorsten.
  17. Do you also get 4.4V when the 74HC595 chips are not stuffed in the sockets? Best Regards, Thorsten.
  18. Error code 01 means "less bytes received than expected". So, it looks like a problem with your MIDI interface. Are you using the latest drivers? Do you have access to another MIDI interface? Best Regards, Thorsten.
  19. TK.
    3372 VCF
    From the MBSID V2 changelog: o 8 external switches can now be connected to - DOUT shift register (-> DEFAULT_EXT_SWITCH_DOUT != 0) - port J5 of the core mode (-> DEFAULT_J5_FUNCTION == 3) The switch states are stored in the patch structure, and can be accessed via Control Surface (EXT menu) or via Parameter Change (NRPNs/Knobs/Wavetables) [/code] Note: if you want to sweep over different filter modes, just write the switch selections into a wavetable, and control the position from the modulation matrix. In difference to the CV solution this has the advantage, that you can easily select the interesting combinations, and change the order. Best Regards, Thorsten.
  20. Ok, in this video I used a MicroQ at the beginning. So far I remember, it was a simple saw sound with some filtering and reverb Fx. I just added some additional infos to the video (e.g. what synth is playing at which time) Best Regards, Thorsten.
  21. Time to publish a picture of the BankStick connections. Best Regards, Thorsten.
  22. Hi, crosstalk between analog inputs shouldn't be a problem so long each individual cable connected to an analog input (CORE:J5) is shielded to ground. Best Regards, Thorsten.
  23. Hi, for 36 encoders, you probably have to set the DEFAULT_ENCODER_GROUP_WIDTH setting to 64, as this is the next 2^n value after 32 Best Regards, Thorsten.
  24. Are you able to send the patches with MIDI-Ox? Note, that the "delay after F7" has to be set to about 750 mS Does MBFM return an acknowledge message whenever a patch has been received? Best Regards, Thorsten.
  25. Hi, currently only notes can be recorded, recording CCs is planned for one of the next releases. I guess that not more than 10..20 people have built a MBSEQ yet Best Regards, Thorsten.
