TK.
Administrators
    15,248
  1. Hi Ole, yes, it's unfortunately required (see also the FAQ: http://www.midibox.org/dokuwiki/doku.php?id=mios_pic18f4620) Is the 5V voltage stable over the whole time, or does is sink slowly? The PIC will reset automatically, once it is sunk below 4.6V (so far I remember) Best Regards, Thorsten.
  2. So, the monitor always receives a 0xff and never another MIDI byte? Which tests of the MIDI troubleshooting guide did you try, and what are the results? They are enumerated now, so it's easy to write down - for example: TEST OUT1: LED flickers TEST OUT2: using a xxx PSU (replace xxx by the one you are using...) ...etc... Best Regards, Thorsten.
  3. ;) Have fun! :) Best Regards, Thorsten.
  4. Hi Xavier, if you would have quoted the paragraph below this one, you would find the answer Yes, this can happen when MIDI events are received from a sequencer and CC data is sent out at the same time... Best Regards, Thorsten.
  5. Hi Intellihel, asking questions this way implicates, that you would "only buy the sequencer" if all these features are implemented. Please note that this a DIY design, features are implemented as I find them useful, and as I find the time (currently I don't have that much sparetime) However, to answer your questions: It's already distributed via email to people who have built a MBSEQ V2 I don't know, what this exactly means, could you please elaborate this feature request in more detail? Maybe it's already implemented under another name? no see answer to 2 As described in the wishlist: no Could you please describe a usage example in detail? How should this be used? Maybe it's better when you first build the sequencer in order to get familar with the user interface, thereafter you can give more explicit hints. Sometimes the most difficult thing is not the coding, but to find a way how the user can activate functions without clicking through 100tes of menues... already possible - and not only shuffle, but whole grooves (delay/length/velocity mod) for 16 steps (32 steps: 2*16 steps duplicated) already implemented already implemented I don't like requests like "it must be working like this or that device" - it's working how I find it useful. Of course, inspirations are welcome, but the implemerntation of certain features are sometimes not possible since they conflict with other things (e.g. implementation of the sequencer core engine, or available buttons on the existing user interface). Best Regards, Thorsten.
  6. Hi Jussi, in addition to MIOS, you need to upload the MIDIO128 application, which can be found at the MIOS download page. Thereafter you will be able to upload the configuration file :) (nice to know, that this is the only problem!) Best Regards, Thorsten.
  7. The questions are repeating, I've answered them several times... therefore I've started a FAQ: http://www.midibox.org/dokuwiki/doku.php?id=mios_pic18f4620 Best Regards, Thorsten.
  8. Habe sie nun erhalten. Manchmal bleiben Mails im GMX Spamfilter haengen, mit etwas Glueck finde ich sie dann auch Tage spaeter, doch meistens werden sie ungesehen geloescht - brave new world :-/ Gruss, Thorsten.
  9. Your answers are a little bit confusing, I don't know if we are talking about the same things... First you wrote: Now you write: So, what is the voltage between ground and the input pin of the 7809, which is stuffed on the SID module? And which test passes when 15V are connected to J1 - do you hear a sound? Or do you mean any other test? Please also answer Mike's questions Best Regards, Thorsten.
  10. Here a quick demonstration of the Button/Duo-LED matrix extension: -> it isn't built into a case yet, therefore I had to push the buttons very carefully due to the loose caps. The frontpanel will be ordered today (it's sponsored from the donations! :) Best Regards, Thorsten.
  11. The voltage before the 7809 must be higher than 9V, the voltage after the 7809 must be 9V Best Regards, Thorsten.
  12. Hallo, mit dem V3 PCB ist der zweite 10k Widerstand obsolet - ich habe ihn nun aus der Bauteilliste entfernt Gruss, Thorsten.
  13. This is a MIDIbox SID with CS, built into a Floppy Drive by Clemens :) He wrote:
  14. Hi, If you don't hear any sound (even no digital background noise from the SID), then it's very likely that either the transistor is not connected correctly (compare it with the pictures), that there is a short at the audio out stage, or that the voltage at pin #28 is not 9V Best Regards, Thorsten.
  15. Hi Ole, does it also happen when the LCD backlights are not connected? Then it's definitely a thermal issue, caused by the too high voltage before the 7805 (7..8V would be better) Note: a core module can be supplied even with 12 or 15V at J1, but only if the power consumption is low enough, so that the 7805 doesn't get too hot. The two BLs, and also the LEDs, consume so much power, that a better fitting PSU is required. Best Regards, Thorsten. P.S.: before you buy a new PIC (I don't think that this is a problem!), consider to buy a PIC18F4620 and PIC16F88 (for MIDI out), so that you can use the new MBSEQ V3 firmware :)
  16. fixed.
  17. It's the MIDIbox of Klingen (he informed me about the upcoming article some weeks ago) -> http://www.midibox.org/forum/index.php?topic=4902.0 Best Regards, Thorsten.
  18. Hi, It's a B4 (due to a bug in the application the wrong letter will be displayed) And here the bad news: I also got a B4 from Microchip some weeks ago, it turned out that the EUSART bug still exists. Microchip has released an incomplete errata sheet! I reported this mistake and only got this "typical" answer from the support guys: My hope was, that they update the errata sheet quickly, so that I can take it as a reference - but nothing happened yet! However, I haven't found the time to update all the relevant webpages at ucapps.de and in the wiki again - but the consequence is, that the MBHP_IIC_MIDI workaround will be required for the next years! Best Regards, Thorsten.
  19. -> www.edrum.info Best Regards, Thorsten.
  20. The core sends an upload request, but doesn't receive any SysEx block, therefore doesn't respond with an acknowledge. It's very likely, that the MIDI In port is not working -> the MIDI troubleshooting guide will help http://www.ucapps.de/howto_debug_midi.html Best Regards, Thorsten.
  21. thats correct. In theory you could use optocouplers for the Rx/Tx line of the MAX232 in order to decouble the PC from the core module, but I cannot give you a schematic for this, this would have to be worked out by yourself. Thats interesting, this might explain why the driver hangs up? Maybe because an incomplete event which was received due the "shortened" Rx line (sidenote: it's not completely shorted, because the optocoupler output is open drain - but the signal level at the Rx input of the PIC will be lowered). So - does it work more stable without the optocoupler, then you found a solution. If not, the RS232 link just doesn't work quite well with your PC, and either the LTC circuit has to be enhanced, or a common MIDI connection has to be used. Best Regards, Thorsten.
  22. TK.
    SEQ v3 Fragen
    ja ich weiss nicht so ganz, wie ich die Frage verstehen soll. Nein, der MIDI Out vom Core arbeitet beim PIC18F4620 unzuverlaessig, und sollte deshalb nicht verwendet werden. Der Optokoppler ist fuer MIDI In - das Ausgangssignal des Optokoppler kann nicht direkt auf einen MIDI Out gelegt werden... Gruss, Thorsten.
  23. Hi Ryan, sounds like a windows driver issue - a friend had a similar problem with his MIDI interface, it also locked up when heavy MIDI traffic was sent (or received). Fortunately there are two other RS232 drivers available (Roland and Kawai) - did you try them also? Jittering pot values are a general problem when the circuit is not galvanically decoubled from the PC, therefore for MIDI an optocoupler is normaly prefered. Does anybody know some measures, how to reduce the additional noise? I'm not an analog expert... (please write this into the Wiki) Best Regards, Thorsten.
  24. See http://www.midibox.org/forum/index.php?topic=5860.0 Best Regards, Thorsten.
  25. It could be somehow possible to realize a mixed C/ASM simulation, but why do you want to simulate the 2 second startup of bootloader/MIOS (which takes some minutes), just to execute this tiny routine? So far I remember, I copy&pasted the assembly routine into a dummy .asm file, and simulated it directly Best Regards, Thorsten.
