TK.
Administrators
    15,248
  1. Hi Gerald, by using the MIOS C skeleton it shouldn't be that difficult to realize a quantizer, simple sequencer or whatever you want. In difference to assembly programs, sharing code with other users is much easier. So, how about a MIOS user library, a collection of some interesting functions and "program-modules", maintained by users and not by myself? Best Regards, Thorsten.
  2. Hi Julien, if up to 8 buttons are enough, then you could use the j5_din application. It requires only one core module, the buttons have to be connected to port J5 - it can send any MIDI events you want (by default Note events) For more then 8 buttons (or additional LEDs), a DIN and DOUT module is required beside of the core, MIDIO128 is the recommented application for this case Best Regards, Thorsten.
  3. thank you, Marcel! This sounds easy. For a common MIOS based application this means that in USER_MIDI_NotifyTx a check for MIDI clock (F8) has to be added (if it doesn't already exist). On an incoming MIDI clock, MIOS_DOUT_Set1 has to be called with the pin number which is used as sync output. Optionally a pre-divider can be added. In USER_SR_Service_Finish this pin has to be cleared (MIOS_DOUT_Set0) - and thats all. This will generate a pulse of 1 mS, with a jitter of +/- 0.5 mS. I think that such a jitter is acceptable, because it is only 1% at 140 BPM (I will integrate this feature into the next MBSEQ release) If less jitter is required, a free IO pin has to be used (but free IOs are rare). This IO pin can be set immediately once a F8 event has been received (zero jitter!), and it can be cleared by a timer. However, this requires some more programming effort, and the code will look different depending on the application where it is integrated (because of different pin usage and timer resources) For a standalone solution I would prefer Colin's circuit, it's the cheapest Best Regards, Thorsten.
  4. TK.
    SIDplayer
    Last time I saw this source code, it didn't find any SIDstation, nor general MIDI routines - are such features available in the meantime? Best Regards, Thorsten.
  5. Hi, you could control the additional LEDs in cs_menu_leds.inc, example: CS_MENU_LED_Update clrf MIOS_PARAMETER1 ; clear LED by default movf CS_MENU, W xorlw CS_MENU_OSC skpnz setf MIOS_PARAMETER1 ; set LED if CS_MENU == CS_MENU_OSC movlw 8*(7-1) + 0 ; SR7, pin #0 call MIOS_DOUT_PinSet [/code] Best Regards, Thorsten.
  6. I could give you a small C function which allows you to control all 128 LEDs, I just need to know which MIDI events should be assigned to the LEDs? Best Regards, Thorsten.
  7. Hi Alex, do you know how to get a (free) datasheet for this chip? If you've luck, the internal functions and the SFR addresses are the same - if not, an adaption wouldn't be worth the effort Best Regards, Thorsten.
  8. Hi Davo, I made some experiemts with a self-built oscillator some time ago (based on three inverters), but the results where not so good - sometimes the oscillator didn't start after power-on. If you are still interested, I can search for the schematic (I guess that I found it on a german website) However, for the MBSID the oscillator is not required, you can also clock the SIDs with the PWM output of the PIC - more infos can be found here: http://www.ucapps.de/mbhp_sid.html Best Regards, Thorsten.
  9. Chriss added the code for the additional buttons and LEDs to the MBSID application, there are no changes in MIOS required. I guess that the question "are they really necessary?" is directed to Chriss (because I don't know anybody else who uses such an extension). If he doesn't read this posting, then just try to contact him via PM Best Regards, Thorsten.
  10. Hi, it's very simple to implement this, but last time I asked in the forum for the specs, I havn't got a reply. So, maybe this time I've more luck? What is the required pulse width for a DIN-Sync signal? Best Regards, Thorsten.
  11. Hi, I fear that it isn't possible to service the SHX8 module in parallel to all the other tasks which are running in the MBSEQ application, because the S&H outputs need to be refreshed very often. I would suggest the use of a second core which runs with the MB64 firmware and which handles the S&H stuff Best Regards, Thorsten.
  12. Hi Dave, yes, thats possible with Meta Events (you can send anything you want...). The MB64 (and MB64E) source code contains an example in mb64_meta.inc (mb64e_meta.inc), there are users who already customized this for their synths, but I guess that there is no adaption for DW-8000, yet Best Regards, Thorsten.
  13. Is there somebody who wants to create a webbased java application which calculates possible configurations? ;-) here some formulas: max number of available digital inputs: 128 max number of digital inputs which can be used to trigger button functions (e.g. MIDI events or Special Functions): 64 number of digital inputs which can be used for menu navigation: 4 number of digital inputs which are allocated for encoders: 2 * number of encoders (max. 64 encoders = 128 pins) max number of analog inputs: 64 number of 7-bit MIDI values which are stored within a bank, and which can be controlled via encoder or AINs: 128 number of 1-bit MIDI values which are stored within a bank, and which can be controlled via DINs: 64 max number of available digital outputs: 128 number of digital outputs which are controlled directly via button or via MIDI (same MIDI events like assigned to the 64 buttons): 64 max number of digital outputs which can be used for LEDrings: 32 for each group of 16 LEDrings, max: 64 LEDrings = 128 pins number of digital outputs which can be used as software-based MIDI Tx/Rx indicator: 2 pins anything missing? Best Regards, Thorsten.
  14. TK.
    MIDIbox SEQ V2.3
    Hi Matteo, it should work with MIOS v1.7, but I cannot guarantee this, since all of my own MIDIboxes are running with v1.8 in the meantime Best Regards, Thorsten. P.S.: thanks for the postcard! :-)
  15. TK.
    Max resolution?
    MBSEQ works with 96 ppqn Best Regards, Thorsten.
  16. How is the quality of the LCDs from Voti? Best Regards, Thorsten.
  17. Lower voltages cannot damage the SID, only higher voltages. But this scenario shouldn't happen so long the voltage regulator was between the power supply and the SID. Best Regards, Thorsten.
  18. This is not a feasible setup - MIDI is the main bottleneck here, because the transfer of a single MIDI event (e.g. CC) takes ca. 1 mS. This already limits the max. transfer rate for the waveform of a single LFO a lot. For a sine wave I would say that at least 16 sample points are required for adequate results (we are not talking about the Nyquist theorems here), this limits the max. frequency to 62.5 Hz. Once you've more than one LFO, the results won't be much enjoyable anymore... I think that this obsoletes the other questions... ;-) Best Regards, Thorsten.
  19. TK.
    MIDIbox FM V1.0
    No thanks, I'm not interested. To give you an impression: the definition and implementation of the MIDIbox FM software took me ca. 6 months, the statement "can really easy adapt it to OPL4" can only come from somebody who never did something like this by himself. Best Regards, Thorsten.
  20. Hallo, kleiner Tip: teste die DINs erstmal mit der MIDIO128 applikation - hier sendet jeder Pin (Button) ein MIDI Event Gruss, Thorsten.
  21. I cannot spend the effort to write such a documentation, but I'm always open for distributions from other users. Today it's possibly better to write a user manual for the C wrapper, since it's easier to use, code snippets can be easier exchanged (e.g. in seperate .c files), and people are able to realize more complex applications without much knowledge about the internals (especially about assembly language) Best Regards, Thorsten.
  22. Hi, each DAC requires a dedicated software driver, not all DACs provide the same features like the MAX525 (e.g. serial interface and chaining capabilities), not all DACs are so well documented. Nothing is impossible, but the programming effort has to be made by yourself... Best Regards, Thorsten.
  23. Yes, this can be handled by software - it means that the program has to react on each transition, and not only on a 1->0 signal change. In other words: each time the USER_DIN_NotifyToggle function is called, you know that the switch has been moved, with a latching switch you don't need to filter out 0->1 transitions Best Regards, Thorsten.
  24. Hi, testing shouldn't be so difficult: SC and RC are the same signals for each module. You could disconnect the SI pin of the DINX1 module, and connect the SI pin of the DINX4 instead to the core in order to check if there is a general problem with the DINX4 Best Regards, Thorsten.
  25. Hi Steve, it's possible to map physical inputs to the pin numbers which are used by the software, it requires a small modification within the USER_AIN_NotifyChange function. I don't remember the pot order of the old MB64 hardware, maybe just only one bit needs to be toggled - could you please tell me the order of the first 8 pots? Best Regards, Thorsten.
