2,305 -
37
Okay, thanks for that piece of code - I wouldn't have found it, as I have no MBSEQ :P Now, I don't know much about Assembler, what does the code do? What is the range of the values that are created? How can I use it in my C code? In my app generating the random values is not a real-time issue, so is there any other piece of [tt]C[/tt] code that might be easier to understand for me and which does the same? Sorry for my ignorance, I'm still learning... ::) Thanks a lot, ilmenator
Hi all, I need to create random values in the range 1-10 or so in my application. Is there an easy way to achieve this within the PIC? Thanks, ilmenator
This is sooo cool 8) ! Within virtually zero time I had the buttons, the faders (almost) and the LEDs doing what I wanted them to do. Now I still need to see for the fader value scaling and the customization of the LCD info displayed during the tests... Thanks! Best regards, ilmenator
Thanks for encouraging me to go the C way :D I have already peeked around the C Interface pages, and I will download the compiler suite tonight. I am not a C guru (but then, I am not an assembler guru either...), but I will give it a shot. It's a pity I will not be able to toggle LEDs in the upcoming tests, but I will manage without them - and (hopefully) have a box which does what I need in the near future (and of which I know how it works, which might be more important than instantaneous success - hey, let's get philosophical here ;) ). I was shortly thinking about writing my own [tt]USER_MPROC_NotifyFoundEvent[/tt] routine for toggling the LEDs, but it might be a better idea to do it from scratch in C. Of course I would love to see a motorfader handling example in C - and I can imagine that I am not alone. The learning curve will be steep enough even with such an example provided... With the touch sensitivity set to 3, touching the faders actually triggers the DINs. Thanks a lot, ilmenator
Thanks Thorsten, at least your answer shows me that there doesn't seem to be any trivial solution which I am too dumb to see... ;) Why I stick to the version that I have? Well, I use the Midibox for doing so-called "audio-visual subjective assessments" - the box serves as an input device for test subjects to enter their ratings when judging the quality of audio-visual (MPEG-4) scenes. That means that I need to show some messages on the display during these tests, and the functionality to do this is already implemented in the version that I have. I figured it would be easier to make my version toggle the LEDs than to make the official, latest and greatest version deal correctly with the sysex strings I transmit containing these messages. Another point is that my version needs to modify the fader values, so the range is not 0-127 but 0-100. This is due to the fact that I need to offer such a scale for the rating - it is rather hard for test subjects to give exact ratings on a scale from 0-127... On the other hand, of course I want to use the whole fader track, so the upmost position is equal to 100. Again, I thought it was easier to make my version toggle the LEDs than implementing this functionality in the latest one. The design of the Midibox as I have it now was a student's project work, that's why I am not completely familiar with the details. The code he modified is rather poorly documented, that is why I cannot easily adapt his changes to the newer version of Midibox64e. This is an image of the box that I use for the assessments. Here it is configured for a so-called ''Multi-Stimulus Test'', hence test subjects have four faders to rate and compare four test items. I guess I will need some more time to decide which way to go now. Thanks for your support. Best regards, ilmenator PS: I tried the ain64_din128_dout128_v2_0 application, and everything works as it is supposed to - I am just not sure whether the touch controls of the motorfaders actually are supposed to trigger the DINs. The Display does not say so. But even when touching the SR pins directly, the display does not show any action. Is this correct? They are connected like shown here: http://www.ucapps.de/mbhp/mbhp_din_touchsensors.pdf
I still get this strange LCD behaviour. Strange enough, the display is okay for the first few seconds. To be more specific, the display cursor is blinking exactly 16 times, then the display starts to show 16 blocks in the upper row and 16 circles in the lower row. From that moment on the display starts to blink very fast... There are 4 DIN modules connected to the core. On the first, SR#1 is used for the touch sensors of the faders. The third and the fourth DIN module are planned for encoders, which are currently not connected. I tried to set the number of encoders to zero by using the #define DEFAULT_NUMBER_ENCS 0 statement in setup_midibox_mf.asm. But whenever the number is smaller than one the application does not start - I only get the sysex message [tt]F0 00 00 7E 40 00 01 F7[/tt] from the core, nothing else happens. How am I supposed to set the number of encoders present to zero? ************************************************* And I was not able to solve the other problem (toggling LEDs with MIDI note on/off messages), which is rather more important to me now - I don't think they are related. To sum it up: toggling works in your [tt]midibox64e_v2_2[/tt] application, but not in mine. The #define DEFAULT_DIN_SR_PIN_x as well as #define DEFAULT_DOUT_SR_PIN_ statements in [tt]setup_midibox_mf.asm[/tt] and [tt]main.asm[/tt] respectively are the same. The [tt]mb64e_leds.inc[/tt] files are identical for both. [tt]mb64e_presets.inc[/tt] is almost identical, except for a portion at the end of my file, which does not exist in yours: org 0x07400 ; enc strings MB64E_Presets_FLASH_Upper MB64E_Presets_OffsetLabels #define ENC_LABEL_MODE_HEX 0x40 #define ENC_LABEL_MODE_PM_HEX 0x41 #define ENC_LABEL_MODE_DEC 0x42 #define ENC_LABEL_MODE_PM_DEC 0x43 #define ENC_LABEL_MODE_HEX_B 0x60 #define ENC_LABEL_MODE_PM_HEX_B 0x61 #define ENC_LABEL_MODE_DEC_B 0x62 #define ENC_LABEL_MODE_PM_DEC_B 0x63 ;; <---------------> mode ENC_LABEL_ENTRY "Volume # 1 ", ENC_LABEL_MODE_DEC_B ENC_LABEL_ENTRY "Volume # 2 ", ENC_LABEL_MODE_DEC_B ENC_LABEL_ENTRY "Volume # 3 ", ENC_LABEL_MODE_DEC_B ENC_LABEL_ENTRY "Volume # 4 ", ENC_LABEL_MODE_DEC_B ENC_LABEL_ENTRY "Volume # 5 ", ENC_LABEL_MODE_DEC_B ENC_LABEL_ENTRY "Volume # 6 ", ENC_LABEL_MODE_DEC_B ENC_LABEL_ENTRY "Volume # 7 ", ENC_LABEL_MODE_DEC_B ENC_LABEL_ENTRY "Volume # 8 ", ENC_LABEL_MODE_DEC_B ENC_LABEL_ENTRY "Volume # 9 ", ENC_LABEL_MODE_DEC_B ENC_LABEL_ENTRY "Volume #10 ", ENC_LABEL_MODE_DEC_B ENC_LABEL_ENTRY "Volume #11 ", ENC_LABEL_MODE_DEC_B ENC_LABEL_ENTRY "Volume #12 ", ENC_LABEL_MODE_DEC_B ENC_LABEL_ENTRY "Volume #13 ", ENC_LABEL_MODE_DEC_B ENC_LABEL_ENTRY "Volume #14 ", ENC_LABEL_MODE_DEC_B ENC_LABEL_ENTRY "Volume #15 ", ENC_LABEL_MODE_DEC_B ENC_LABEL_ENTRY "Volume #16 ", ENC_LABEL_MODE_DEC_B ... I don't think this actually matters, or does it? [tt]mb64e_midi.inc[/tt] is the second last file that has differences: while in the original application the [tt]MB64E_MIDI_NotifyReceivedEvent[/tt] looks like MB64E_MIDI_NotifyReceivedEvent ;; branch to MIDI learn handler if enabled IFSET MB_STAT, MB_STAT_LEARN_MODE, goto CS_M_LEARN_NotifyReceivedEvent ;; if RECEIVE_PC_FOR_BCHNGE flag is set, check if channel matches and switch bank in this case SET_BSR MB64E_BASE BIFCLR MB64E_CFG1, MB64E_CFG1_RECEIVE_PC_FOR_BCHNGE, BANKED, rgoto MB64E_MIDI_NotifyReceivedEventNP MB64E_MIDI_NotifyReceivedEventPC ;; compare with expected program change for bank changes movlw 0xc0 | ((DEFAULT_BANK_PRG_CHNG_CHANNEL-1) & 0xf) xorwf MIOS_PARAMETER1, W bnz MB64E_MIDI_NotifyReceivedEventNB ;; change bank movf MIOS_PARAMETER2, W call MB64E_BANK_Change MB64E_MIDI_NotifyReceivedEventNB ;; compare with expected program change for patch changes movlw 0xc0 | ((DEFAULT_PATCH_PRG_CHNG_CHANNEL-1) & 0xf) xorwf MIOS_PARAMETER1, W bnz MB64E_MIDI_NotifyReceivedEventNP ;; change patch movf MIOS_PARAMETER2, W call MB64E_PATCH_Change MB64E_MIDI_NotifyReceivedEventNP MB64E_MIDI_NotifyReceivedEvntNPC ;; branch to MIDI event scanner rgoto MB64E_MIDI_Scan in my application it is modified like this: ;; branch to MIDI learn handler if enabled IFSET MB_STAT, MB_STAT_LEARN_MODE, goto CS_M_LEARN_NotifyReceivedEvent ;; if RECEIVE_PC_FOR_BCHNGE flag is set, check if channel matches and switch bank in this case SET_BSR MB64E_BASE BIFCLR MB64E_CFG1, MB64E_CFG1_RECEIVE_PC_FOR_BCHNGE, BANKED, rgoto MB64E_MIDI_NotifyReceivedEventNP MB64E_MIDI_NotifyReceivedEventPC ;; compare with expected program change movlw 0xc0 | ((DEFAULT_PROGRAM_CHNG_CHANNEL-1) & 0xf) xorwf MIOS_PARAMETER1, W bnz MB64E_MIDI_NotifyReceivedEventNP ;; change bank movf MIOS_PARAMETER2, W call MB64E_BANK_Change MB64E_MIDI_NotifyReceivedEventNP ;; branch to MIDI event scanner rgoto MB64E_MIDI_Scan I wouldn't suspect this change to be of any importance to the toggling LED problem either... The only other file with apparent differences is [tt]mios_tables.inc[/tt]. Mine looks like this: MIOS_MPROC_EVENT_TABLE ;; entry 0x00-0x0f MT_ENTRY 0xb0, 0x15 ;; Fader 1 MT_ENTRY 0xb0, 0x16 MT_ENTRY 0xb0, 0x17 MT_ENTRY 0xb0, 0x18 MT_ENTRY 0xb0, 0x19 MT_ENTRY 0xb0, 0x1a MT_ENTRY 0xb0, 0x1b MT_ENTRY 0xb0, 0x1c ;; Fader 8 MT_ENTRY 0x90, 0x3c MT_ENTRY 0x90, 0x3d MT_ENTRY 0x90, 0x3e MT_ENTRY 0x90, 0x3f ;; Button8 MT_ENTRY 0x90, 0x40 ;; Button 1 MT_ENTRY 0x90, 0x41 MT_ENTRY 0x90, 0x42 MT_ENTRY 0x90, 0x43 ;; entry 0x10-0x1f MT_ENTRY 0x90, 0x44 ;; Button 9 MT_ENTRY 0x90, 0x45 MT_ENTRY 0x90, 0x46 MT_ENTRY 0x90, 0x47 ;; Button 12 MT_EOT ;; the last two buttons dont have LEDs! MT_EOT MT_EOT MT_EOT MT_EOT MT_EOT MT_EOT MT_EOT MT_EOT MT_EOT MT_EOT MT_EOT ... Also here I think there is nothing wrong!?? Actually, I am really out of clues... I compared the include files a number of times using a file compare tool, so I am rather sure that there are no differences. Is there anything else I should check? Any other functions which are involved in the process of toggling LEDs via MIDI note on/off messages? ??? Thanks, ilmenator
Hi there, thank you for your input, actually the LEDs are controllable now, for the standard midibox64e_v2_2 app with the setup_midibox_mf my hardware receives the commands correctly. Now I only need to find the differences in the software that I have to deal with ;D ! The AUAIMBCTC rule (btw, what does THAT mean ???) is taken into account, yes. Of the eight possible faders, only four are connected (directly to J5), and the last 4 pins are grounded. Anything else I could check?? Thanks a LOT for your help! Regards, ilmenator
Thanks, I'm getting closer. This time I only changed the setup_midibox_mf.asm. The result is, that the LCD behaviour is still as described, but the LEDs are not permanently on, but only when the button is pressed down. On release the LED goes off again. As always, I used MIOS Studio, it is a very nice tool! During MIDI upload, the LCD is ''normal'' again. I will dive again into this tomorrow - have to get up early :-\. Thanks a lot, ilmenator
Okay, now I understand. Actually, I am afraid the error is somewhere else. I have changed main.asm like this: #define DEFAULT_DOUT_SR_PIN_01_08 1 #define DEFAULT_DOUT_SR_PIN_09_16 2 #define DEFAULT_DOUT_SR_PIN_17_24 0 #define DEFAULT_DOUT_SR_PIN_25_32 0 ... and this #define LEDRINGS_SR_ENC1_16_CATHODES_1 0 ; first shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC1_16_CATHODES_2 0 ; second shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC1_16_ANODES_1 0 ; first shift register with anodes of the first 16 LED rings #define LEDRINGS_SR_ENC1_16_ANODES_2 0 ; second shift register with anodes of the first 16 LED rings ... and I still get no LEDs on. Is this a hardware fault? I don't think so, because with another application all LEDs work. Now, I compiled the setup_midibox_mf.asm example from the midibox64e_v2_2 application, and I have some strange behaviour even after changing the main parameters in .asm and .inc: I get the screen like i am supposed to after startup, but after 16x cursor blinking, the display gets kind of mad and in the upper line I see blocks which vary according to the fader position, in the lower line I see 0 or * depending on the state of the button. But the display is "blinking" very fast. All LEDs are on permanently... so they do work. I am kind of lost here. I'm afraid that there is some portion of the code missing that should be there - which of the .inc files are relevant for toggling the LEDs in the way I would like to? Regards, ilmenator
Thanks, actually I'm a bit lost with this information. The mb64e_leds.inc files are identical in the original version and in mine. In mb64e_presets.inc, there are some minor differences which are attributed to the fact that I have motorfaders MB64E_Presets_OffsetEncsRge4 ENCODER_ENTRY 0xb0, 0x15, 0x00, 0x64 ; motorfader 1 ENCODER_ENTRY 0xb0, 0x16, 0x00, 0x64 ; motorfader 2 ENCODER_ENTRY 0xb0, 0x17, 0x00, 0x64 ; motorfader 3 ENCODER_ENTRY 0xb0, 0x18, 0x00, 0x64 ; motorfader 4 ENCODER_ENTRY 0xb0, 0x19, 0x00, 0x64 ; motorfader 5 ENCODER_ENTRY 0xb0, 0x1a, 0x00, 0x64 ; motorfader 6 ENCODER_ENTRY 0xb0, 0x1b, 0x00, 0x64 ; motorfader 7 ENCODER_ENTRY 0xb0, 0x1c, 0x00, 0x64 ; motorfader 8 ENCODER_ENTRY 0xb8, 0x5e, 0x00, 0x7f ... and that I want to send different notes, but all on the same MIDI channel: MB64E_Presets_OffsetButtons ;; DIN/DOUT group 0 BUTTON_ENTRY 0x90, 0x3c, 0x7f, 0x00 BUTTON_ENTRY 0x90, 0x3d, 0x7f, 0x00 BUTTON_ENTRY 0x90, 0x3e, 0x7f, 0x00 BUTTON_ENTRY 0x90, 0x3f, 0x7f, 0x00 BUTTON_ENTRY 0x90, 0x40, 0x7f, 0x00 BUTTON_ENTRY 0x90, 0x41, 0x7f, 0x00 BUTTON_ENTRY 0x90, 0x42, 0x7f, 0x00 BUTTON_ENTRY 0x90, 0x43, 0x7f, 0x00 ;; DIN/DOUT group 1 BUTTON_ENTRY 0x90, 0x44, 0x7f, 0x00 BUTTON_ENTRY 0x90, 0x45, 0x7f, 0x00 BUTTON_ENTRY 0x90, 0x46, 0x7f, 0x00 BUTTON_ENTRY 0x90, 0x47, 0x7f, 0x00 BUTTON_ENTRY 0x90, 0x48, 0x7f, 0x00 BUTTON_ENTRY 0x90, 0x49, 0x7f, 0x00 BUTTON_ENTRY 0x90, 0x4a, 0x7f, 0x00 BUTTON_ENTRY 0x90, 0x4b, 0x7f, 0x00 I guess that MB64E_Presets_LED_MAP is organized like MB64E_Presets_OffsetButtonValues: MB64E_Presets_OffsetButtonValues ;; button: ;; 6543 3210 db b'00001111', b'00001111' ; 1st SR db b'00001111', b'00001111' ; 2nd SR db b'00001111', b'00001111' ; 3rd SR db b'00001111', b'00001111' ; 4th SR db b'00001111', b'00001111' ; 5th SR db b'00001111', b'00001111' ; 6th SR db b'00001111', b'00001111' ; 7th SR db b'00001111', b'00001111' ; 8th SR ... MB64E_Presets_LED_MAP db 0x00, 0x00 db 0x00, 0x00 db 0x00, 0x00 db 0x00, 0x00 db 0x00, 0x00 db 0x00, 0x00 db 0x00, 0x00 db 0x00, 0x00 But what does it actually do? When a note on message comes in, say for example [tt]0x90, 0x3c, 0x7f[/tt], what happens in MB64E_Presets_LED_MAP? How would I have to tweak it so that the first LED in SR#1 lights up? Thanks, ilmenator
Thanks Thorsten, at the moment it looks like this thread is going to be more appropriate for "Troubleshooting" than "Design Concepts"... I'm afraid I need to tell a little more about the issues I am having here. I have to modify a Midibox which was built by someone else in his student's project. The box is based on a Midibox64e, it has four motorfaders (touch sensors connected to SR1 of DINX4-1), 14 buttons (connected to SR2 and SR3 of DINX4-1), 12 LEDs (connected to SR1 and SR2 of DOUTX4-1) and two LCDs (2x40 and 2x20, only the first one is actually working - the second one will have to be made working by me someday...). No rotary encoders in the box. The buttons are configured to send MIDI note on messages when pressed and MIDI note off when released. The Faders send MIDI CC and move accordingly when these controllers are received. Now, I tried to re-configure the system using Serge's Midibox64e tool (''vmidibox64e''), but actually setting the SR #1 and #2 to ''MIDI Status rec. for Entry #0-7'' (and ''..#8-15'', resp.) in the DOUT Shiftregister Map dialogue like suggested in the posting above does not have any effect. In mios_tables.inc, there were only 8 entries in the MIOS_MPROC_EVENT_TABLE, so I suspected this would be the problem. I changed the table to MIOS_MPROC_EVENT_TABLE ;; entry 0x00-0x0f MT_ENTRY 0xb0, 0x15 MT_ENTRY 0xb0, 0x16 MT_ENTRY 0xb0, 0x17 MT_ENTRY 0xb0, 0x18 MT_ENTRY 0xb0, 0x19 MT_ENTRY 0xb0, 0x1a MT_ENTRY 0xb0, 0x1b MT_ENTRY 0xb0, 0x1c MT_ENTRY 0x90, 0x40 MT_ENTRY 0x90, 0x41 MT_ENTRY 0x90, 0x42 MT_ENTRY 0x90, 0x43 MT_ENTRY 0x90, 0x3c MT_ENTRY 0x90, 0x3d MT_ENTRY 0x90, 0x3e MT_ENTRY 0x90, 0x3f ;; entry 0x10-0x1f MT_ENTRY 0x90, 0x44 MT_ENTRY 0x90, 0x45 MT_ENTRY 0x90, 0x46 MT_ENTRY 0x90, 0x47 MT_EOT MT_EOT ..... ...but this did not render any different results. Then I compared the main.asm file of that project with the one contained in the midibox64e_v2_2 application for the original midibox64e. There are a number of differences, which I do not fully understand. I think it would be a bit rude to post them here, so I try to ask the question in a different way: what is the order in which the functions are called when there is a MIDI note on message at the MIDI in of the box (because this should be what triggers the LEDs ultimately, right?)? By knowing this, I could check if some relevant function or setting has been deleted/modified in comparison to the original Midibox64e application. Thanks so much for your help, ilmenator
Hi all, I would like to control the on/off state of the 12 LEDs on my MIDIbox64e via MIDI messages. These LEDs don't have anything to do with the buttons (as you would normally expect), but they are there to signal the state of external MIDI machines or software. So the question is: what message do I need to send to my MIDIbox64e to toggle these LEDs, and what do I need to change in the mk_syx (if there is anything)? Thanks a lot in advance, ilmenator
DIN trouble on MIOS / PIC18F452-I/P
ilmenator replied to ilmenator's topic in Testing/Troubleshooting
Hi everybody, after a few years off I am catching up again ;D, re-activated all my old boards and so on. As I am currently having a number of problems with a GLCD I double checked all information on this website, including my old postings, again. When I compare Thorsten's statement in this thread with the instructions in the PDF about the core module, I detect a little difference: in the PDF it says that J4 SC should be connected to pin #28 on 18F cores, only to #22 on 16F cores. Above, T said to connect it to #22 also on 18F cores. So: has there been any hardware change in the meantime that I did not notice? Thanks, ilmenator -
Hi BpM, was kostet das Stück denn, bzw. bestellst du direkt bei denen (dann kann ich die Kosten selber ausrechnen, frage mich aber, wozu dann die Sammelbestellung, wenn 3-49 Stück in der selben Staffel liegen)? Oder sind die Versandkosten so extrem hoch? Danke, ilmenator
Hi Dan, it looks like I am running into the same problem here. I try using an LPH7366 type display (9 pin connected via metallic/foam thingy) from a Nokia 5110. It does not have the two resistors you talk about. Where exactly are they located on the cellulars that can be ripped? I wonder though, if pin 8 (Vout, "LCD output voltage") should actually be generated inside the display, or whether it has to be applied there...? According to http://serdisplib.sourceforge.net/ser/doc/goldentek.pdf it should measure 7.6 Volts. With me, it does not show any voltage at all. If I open up the display I cannot detect any ciruitry that could possibly do the DC/DC conversion, so the display might actually expect 7.6 Volts to be applied at pin 8 ?? Do the cellulars' "mainboards" look any different (apart from the two resistors) between working and non-working display types? I mean, any hint on what else could be different?? Best, ilmenator
Moin Poeloq, ich will dir ja nicht die Laune verderben, aber die PICs gibt's bei Microchip als "Sample Order" umsonst. Da fallen nicht mal Portokosten an... Grüße, ilmenator
Hi Justin, shaft and switch is one piece, they cannot be separated. Reichelt and others offer these switches with different shaft lengths. Best regards, ilmenator
Hi, look at the MIDI filter application. One of the examples is doing just what you want. Regards, ilmenator
Unfortunately Analog states that the item is "obsolete", so it might not be a very secure investment of time if you rely on stocks left in some dark warehouse... Best regards, ilmenator
Yeah, let's get back to tiny buttons, small displays and horrible menu structures. All these faders and encoders really disturb the clean look of a nicely polished MIDIbox surface. ??? Regards, ilmenator
Easy. I asked customer support via email about samples, stating that there was no way to add the device to the sample cart. Right, they said, currently there is no automated way of getting samples, but: I should contact the local AD representative, they could arrange for samples. That's what I did, about two weeks later I got both samples. Regards, ilmenator
Hi all, any news on this interesting project?? I asked AD for some samples of the 75019 and was told to also try the AD8113JST, which is a newer product. Best regards, ilmenator
Hi KJH, you may try using a different PSU with lower output voltage, like 9Volts. If that's not an option you could place another regulator in row, like 7809 --> 7805. But there is not really much space on the core board, so you might use a separate vector board with all the components of the power regulating part of the core. Thinking about it again, it might actually be far more elegant plain using a different PSU... :-/ Regards, ilmenator
I'd like to jump in here... They are not the same - I once tried to use the 6mm caps with a 1/4" shaft. Not a chance... But you might be able to fix them using some kind of glue - though that might be a decision for life ;) Regards, ilmenator
As far as I get it, it should not be okay. One line is 5V, the other is 9V. You could surely damage the PIC when applying 9V directly to it - unless you have a 7805 voltage regulator on each core coard. Regards, ilmenator
