chriss
140 -
Everything posted by chriss
Ok thanks Thorsten, just didn`t use the comand shell (terminal window) in osx. (unix virgin) but after 30min it worked. I think i wait till they release it. Thats exactly my opinion. It works great. Thanks again. chriss
Hello, just trying to open jsynth on my new g4 i have noticed some troubles with the SID driver. It does not show up in the synthlist and i can not open any SIDpatches from the library. Is it possible? And i am not able to get a comunication with my usb module, although it is working with other applications w/o problems. But that seems to be a problem of Jsynth i guess. Does anybody made the same experiences? chriss
sorry d2k, i already got 2 at ebay. chriss
www.mec.dk Farnell and schuricht has them. Search for "multimec" chriss
Hi all, I am still searching for a good laptop/soundcard combination. Most preferred is a powerbook G4 and RME multiface. I once read the laptop test on their homepage and it seemed to be that the computer and its interna play an important role when measuring performance (I/O latency). But this test is some kind of ancient, so if someone has a mac or a RME please tell me your experiences and your thoughts on this topic. Especially if someone is using a laptop(pc/mac). And Thorsten can you tell me what kind of computer your are using and how low you can go with the latency when using the RME? thanks a lot chriss
hThanks Thorsten, for the answers. 1.2.3.4. cool, good to know 5. i don´t send a lot of CCdata. but sending note on/off on one channel to all 4 sids. maybe thats the reason. i will just play a little bit more and report you. 6. that makes sense. i will try that today. chriss
Hello all, thanks Thorsten again for that wonderfull musikinstrument. It works great and is very very powerfull synth. A few answers, which came up during testing. 1. In the WT menu, my slaves (pic18F) behave not like the core. For example: in postion 0 i set the WT to "ply", then moving to to postion 1, then moving back to position 0 and the Playmode is -- again. ?? 2. When making changes in the WT menu (slaves) they crash and i have to select the patch again? 3. The polymode is not avaible anymore? When opening the polypatches it appears on the lcd but when changing the mode it is away? 4. How does the sync with midiclock work? i mean how does the code translate incoming midiclock data? I would like to know, how your setup looks like when syncing a WTpatch to midiclock. And is the speedrate of the WT in anyway translateable in Bpm? 5. Sending data from Logic and having Link enabled, i got stucking notes (every minute or so). But only on the slaves. Is this a problem coming from Logic? 6. Are the ledrings still going to be supported? (it would be the first time i build them, so i am a little bit anxious to see how this works). And i etched a pcb allready based on the MB16E pinout. And one little offtopic: How can i tell Logic not to send incoming midi data to the output. I can delete the connection from the inport to the sequencer, to avoid midifeedback. But then i can not record any midibox data. Any idea? Thanks for all hints and answers. chriss
Hi, It makes no difference, to upload them twice. All the seq patches, except the seq#67, are missing. On every patch the MB sid sends a string back, but on the SeqPatches it sends nothing, then sending on #67, and then all the newpatches. And in the end of the upload Jsynth hangs itself up. (could not play back banks only patches, it says and i have to close Jsynth.) But in the meantime i plugged the USB module into a friends powerbook G4 running under OSX, and midi i/o is working. Didn´t had the chance to test sysex upload though. Great module! chriss
Hi Thorsten, I am planning some kind of robotdevice, and need to read 14 (or16) bit, from standard encoders, and send them to the computer. (5 encoders total) I did try this with the enc_speed example and it works nice. (but only sending to the LCD): what do i have to change in the code to get these values into the computer? And what is the best kind of stream (pitchbend, NRPNs or SysEx)? And just that i have some kind of idea how fast i can move the encoder, how many ticks per second can the pic handle? Thats because i must know the position of my little encoders (robotaxis) very precisly. Is this all possible with MIOS? Thanks chriss
What about the the Jsynth? This works for me ( 2048 ), but what about the Patch upload with Jsynth? Since V1.5b, I can´t get some patches on the Bankstick (P#60-70 or so). Is it possible to load them with midiox? (And these SeqPatches are so damm rocking, i really miss them) chriss
Hi all, after putting win XP on my laptop (before Win98se) my USB module is working very nicely. One thing i recogniced is, that after moving few times, my Usb port stops scanning( not the USb module though). After sending something from the port to the USb module its fine again. and so on. Any idea? Etching was easy but i was just wondering why you did this MidiIn1;MidiIn2;MidiOut2;MidiOut1, frontpanel arrangment? BTW: did you made a tiny PCB already? chriss
Hi midimeter, die Pics bekommst du von Microchip persönlich und dazu noch Gratis. Als Sampleorder. Einfach auf die Homepage gehen und unter "samples" ein paar Fragen beantworten. (unbedingt den 24LC256-I/P mitordern für die Banksticks) Für die Encoder musst Du einen lokales Elektonikgeschäft suchen, welche Dir die Bauteile bestellen kann. Ansonsten www.rs-components.de, wo sie aber ein bißche teurer sind. chriss
Hi All, nice that you like it. That wasn´t the main work, aktually that was the funny part, always dealing with this dip devices its very amusing putting these little bugs on a selfmade layout. And by the way it looks so cool, like a real PC mainboard. And don`t forget about the drilling, although i had to drill more then i wanted (doublesided). Yes, most of them under the Display and the ledmatrix. Sure you can have the eagle file. just send me your email. The PCB is handmade by myself. Me too. This i never dreamed of, till Thorsten came and encouraged us to start building midiboxes and helps us on every step. Thanks Thorsten. chriss
took me half a year to come so far and i am still need to build the frontpanel and the case. (and of course the ledrings which are sitting on an extra pcb) I had following goals: 1. to minimize the wirering (that means i had to do a lot of of planning, using double sided pcb and etching A4) 2. to get as flat as possible (that means i had to use smt) 3. to use an internal powersupply To the Powersupply: After having everthing assembled, i noticed huge noise at the output. First digital noise then 50Hz hume. So, with the help of Thorsten i came to a better solution: i split the +5V supply for the core/slaves and the Sid modules (i could do that because i use 2x6Volt transformer). Clean sound know. BTW: I measured 300mA for the core/slaves with all leds on and 140mA for the 4Sid`s 12Volt. Didn´t measure the +5V for the 4Sid´s but i looks like 200-300mA. Question are welcome. chriss
Hello Thorsten, thanks a lot, it works beautiful. Hope this mod makes sense! chriss
Hello Thorsten, cool, i am so anxious to try that out, but i can´t find the MIOS file under Concepts->MIOS->Download. chriss
Hello Thorsten, so half of this little mod works so far, the button does what it should do. But not the leds though. i changed in cs_menu_leds.inc the file from ;; TMP5[4..0]: LFO waveform call CS_MENU_MS_GetSIDBase call CS_MENU_Hlp_AddLFOOffset swapf INDF0, W andlw 0x07 call MIOS_HLP_GetBitORMask IFCLR INDF0, 0, movlw 0x00 movwf TMP5 to ;; TMP5[6..0]: LFO waveform call CS_MENU_MS_GetSIDBase call CS_MENU_Hlp_AddLFOOffset swapf INDF0, W andlw 0x07 call MIOS_HLP_GetBitORMask IFCLR INDF0, 0, movlw 0x00 movwf TMP5 is that all? and in the cs_menu_io_tables.inc DOUT_ENTRY TMP5, 0, 5, 1 ; LFO Sine LED DOUT_ENTRY TMP5, 1, 5, 0 ; LFO Triangle LED DOUT_ENTRY TMP5, 2, 4, 7 ; LFO Saw LED DOUT_ENTRY TMP5, 3, 4, 6 ; LFO Pulse LED DOUT_ENTRY TMP5, 4, 4, 5 ; LFO Random LED DOUT_ENTRY TMP5, 5, 4, 4 ; LFO Sync Asn DOUT_ENTRY TMP5, 6, 4, 3 ; LFO Sync All thanks chriss BTW: Is "Lfo Random" not supported? in the menu the Lcd tells me "off"and the led does not light.
mios1.2 and midi sid stepB troubles and questions
chriss replied to chriss's topic in Testing/Troubleshooting
Hello Thorsten, finally we can close this thread, i found the mistake. Now everthing works fine. Since i build only one core for the 18F hardwired to the to_com interface, i had to put all the slavespics into that core. But the 16F877 needs a 20MHZ crystal!!! ok stupid me and sorry for the wasted time. But without you i will still search. thanks chriss -
Hello Thorsten, thanks a lot, i will try it later this day. chriss
Hello all, i build the stepC of the Mbsid (90% finished) and everthing is working. (i will do the report later in an other topic). Now i want add a button to control the sync of the Mbsid lfo, just like the lfo waveformbutton. One button and two leds (off,asn,allnote). How can i do that? thanks chriss
hello, all that sounds so nice, my next two years are planned. Hope that Thorsten is slowing down so we can catch up a littlebit. Unbelievable. chriss
Hi Thorsten, thanks for the circumstances, at the moment i have some trouble with my JDM programmer, but i definetly downloaded the last version. Hope to check evererthing out before i have my midi interface. chriss -
hi pay_c, the point with these encoders is that alps has made different versions of them, i guess depending where you live. i got mine from schuricht in germany and they don´t have a nipple underneath the schaft. But the pinout compared to the official datasheet from there site is different though. thats why thorsten always has the little extra drawing for the alps stecB on his din_in pdf´s. The datasheet posted above is absolutly correct. chriss
Hello Thorsten, just the same. sorry. What i didn´t say the last time: Your whole sidproject is really awsome. Never dreamed of doing something like that. thanks chriss -
Hi Thorsten, thanks alot so far. Yeah you answer the questions with the steb B documentation. Stec11B: it works nicely after changing the main.asm and the mios_tables to detented. Unfortunatly the sidv1.4_to_com is not talking to my pc. no ping, no changing device. (just plugged one core with the sid v1.4 to my pc). The LCD prints >sid v1.4< and from time to time >Midi time out whats up< and it does not react on note on/off. thanks chriss
