nILS
Frequent Writer
    4,314
    4
Everything posted by nILS
  1. Prototype owners please refer to this wiki entry: http://www.midibox.org/dokuwiki/gm5x5x5_errata
  2. True, but... 250pins is simply not enough. That's even worse than eagle's 80x100mm restriction. DipTrace is neat though, and for everyone that's undecided definitely worth a shot!
  3. nILS
    Oombox
    There's no custom chars left in the sid v2 firmware. You could potentially repace one that's rarely used with "|" and just search/replace all occurances of that char in the source code. Shouldn't be too hard, a bit annoying to do but not hard.
  4. This order closes: December 7th 2008
  5. :D Thanks so much, Wilba!
  6. You're chewing on your toenails? Eww. Haven't we noticed that before? (the pin names, not the chewing) ;-)
  7. nILS
    Oombox
    Very clean looking! I like it :D
  8. nILS
    Core Modul
    Im Chat wurde mehr oder weniger das geklärt: Es ist nicht sonderlich schlau die Header wegzulassen. Besonders dann, wenn man die ohnehin schon hat. Lohnt nicht, denn früher oder später wirst Du aus irgendeinem Grund doch ein Display/... anschlißen wollen/müssen :-)
  9. midibox - we're the good guys midibox - preparing for world domination midibox - solder, upload, dominate ;D Or to pick up on TK's slogan: midibox - where MIDI Hardware Geeks gather
  10. [me=nILS Podewski]hands cimo some salty nuts[/me]
  11. nILS
    Totally lost
    Take it easy indeep. Take a chill pill. Or two. Exactly. The people who answer your question obviously do have to have a bit more knowledge than you, otherwise they couldn't help, right? No idea what you are trying to say, but noone "hides behide misinformation" in this thread. True. But it simply does not apply here. Who is doing anything like that? Noone is. Well the answer might not be as simple as the question. And it might involve reading. Maybe even a lot of it. That's why you were already linked to something regarding your question. Dude. Chill pill.
  12. J5A = 1st 1/2 of J5 J5B = 2nd 1/2 of J5 Together they are J5 :-) You can use any Vs and any Vd pin - they're all connected as there is only one Vd (+5V) and one Vs (Ground). From your post my biggest suggestion to you is to do a lot of reading on ucapps. And I do mean a lot ;-)
  13. nILS
    Core Modul
    Eigenwillige Idee. Eigentlich würde ich ja gerade die PSU Ecke mit weglassen aber die Header mit draufbauen. Und den Krams rechts neben J15 könnte man auch weglassen. Sollte man aber alles nicht machen. Wird Dir garantiert früher oder später auf die Füße fallen. Siehe: http://schickt.de/mbquote.php?id=17
  14. The moving menu thing sometimes dies on Chrome, too :o
  15. mmmmm yummy. [me=nILS Podewski]prepares for major ranting episodes[/me] edit: testing :) ;) :D >:( :( :o 8) ??? :P :-[
  16. Happy Birthday, Mr. Midibox!
  17. Welcome aboard TafterT! ;D Do your voltage regulators get really hot after a while? As for the uploading of the patches: Try to fiddle with some different block sizes and most importantly pause times after each block.
  18. crosspost bad.
  19. I want scrap piles like that too... Damn!
  20. I'm not referring to anything. I'm just showing you a pdf that shows you how the wiring should be ;-) It's basically a 1:1:1, only difference being the SO pins.
  21. Hmm, a really "fit" person gets hit by a drunk driver and needs blood. That's something that is not fully considered in "survival of the fittest" imo ;-)
  22. [me=nILS Podewski]hides under desk[/me] In case people wanna be paranoid or live on the edge - It was one of these files: All taken from the HVSC 4.~
  23. Um... http://ucapps.de/mbhp/mbhp_8xsid_c64_psu_optimized.pdf
  24. Hmm too many things replaced to find the cause... Glad that it sorta works now though ;-)
