456 -
Everything posted by Phattline
Anyone interested in Alps "N" type motor faders?
Phattline replied to Doug Wellington's topic in Bulk Orders
I am still waiting for my Motorfaders/and some feedback from doug While i´m waiting a question: I rebuilt the motorfader in Autocad, and then make a Eagle library of it, I am not sure about the pinning of Thing --- is the magenta Signal path right in following picture?: Here is the Orginal Datasheet: DATASHEET And here are the CAD Files: DWG DXF Now I want to import that, and make a library in Eagle... but before I want to go sure, that the pinning is correct - is it? It it is then this should be the Eagle Library LBR -
you could make 2Boards... the buttom board - with the encoder on it and its Shiftregisters and resistors... and a top board with the Leds on it and its Shiftregisters and Resistors...---and then drill a hole in the LED boards, for the Encoder shaft... this make the DIY Board-design (if single sided is the only way...) and so on much easier... The BCRs are SMD LEDs with some transparent Plastik-shafts on it... plastic waste... when you use 1mm standard LEDs and drill holes for that in your Front-Panel - Then this looks the same way...
des is jetzt wieda a zuastaund sound. DOWNLOAD Techno like from good old days: claps, rides, snares, real open hihats, closed shaking hihats, toms, distortet kicks, straight bassline, horrorsphäre, drivin lead, 145BPM, straight, hard, no intro to come quick in the drive (because of arranging it live...) Setup: NordrackIII, JP8080, Korg ER1MKII, RME MultifaceII, APC40, 2xLP, M4L, Ableton, Quadcore PC, synths are all hardware, drums are onshots played in Ableton (no fu...in Loops!) short in austrian german: sotechnoauslängstvergangenentagen: 145BPM der rest is selbsterklärend: klatsch bummm itsch itsch tz tz dazu offbeat bass delay auf itsch itsch dazu ne ephylead für den optimalen zuastaund! faust in die höh -satelitenstampf uuund paaast scho.
Hi search such 6-corner Pushbuttons, any Idea? My link thankz for tips - phat
our comunity DOWNLOAD Kategorie: Your Tracks Artist: Phatline 48KHZ 320KBS MP3 @ 135BPM 2min intro 4-5min kick 3min outro rest is melodic break sample is from a friend...
ok sounds easy :)
:D you may need a tiny tiny tiny magnet... because, you have to put many of this tiny tiny magnets on a tiny tiny disc...and because you need a better resolution then, one step by one turn :P or you could take a magnet disc, and the take magnetic shielding stuff (What ever this is) that is easy to drill with a cnc, and then drill isolation areas in the stuff........ it then may look like a disc from a optical encoder.... then you put the shield-disc on the magnet-disc, and so on......... oh man too komplex...
the mainly question is where to get the magnet for that... and whats the priceing for that....5$ are a bit to much for peace of silicium :o , if this would be cheaper then a mechanical encoder ;) - i would start to thinking of cnc designes for axis, shafts and so on... but with 5$ i dont start to think about that...
? what did I done?
phat bleibt seinen prinzipien treu ;-) aber! - GOT TO HAVE SOUL! Jo für die jenigen die grad horchen... -jo ih gibs zua, i woar zua! ---aba woast wos - man lebt nur amoi "also stell dich den duel mit dem träumenden rebell" zum Track 135BPM, ne mischung aus House, Techno, Trance, auf jedenfall mit sooul, jo meiner meinung hoit das ganze live garniert arrangiert und mit einer Flasche Rotwein zelebriert... ergibt so viel jam-spass wie schon lange nicht mehr. holy moly! synths: Clacie Nordrack III Drumsequencer: Korg Electribe ER Drumsampler: Ableton Live Simpler Samples: ihrgendwos ausn internet melodie: up up and down fede basslines & acid basslines, trance flächen, distortete leads... vü spass & guade nocht - phat ENGLISH: short- I HAD FUN! :)
I am from austria, and I want some... but bevore- to be sure the facts?: one square: 1,58cm x 1,58cm 8x8 buttons: 16,82cm x 19,5cm 19" frontplate space is 43cm 43/16,82= 2,55 - too bad only 16 steps... ---So I only have to etch my PCB, and this buttons work on the blank cu (copper, kupfer) PCB? Or do I need some "lamination"--- One Problem maybe you see here: http://lividshop.com/catalog/product/gallery/id/45/image/90/ The Contact space is a closed circle, that meens, you have to make a double sided board...on the upper side is then the BUTTON contact routing, on the lower the LED circuit.... that meens, it will be harder to do that DIY ???
no problem, they are free for decks >>> free for partys - - also free for home use - burn to cd for private use, free to put it on mp3 players.... and so on
They have all much synth and melody in it... however they are made to go trippy or go dance or all together, or just simple to drive car and use the subwoofer... I have used free one shot samples for drums, as drumsequencer and frickelbeat maker -> korg electribe rythm, bass, lead, pad -> clavia nord rack III (best liveplayable va ever!!!), päds jp8080, sequnecer ableton live, midicontrollers -> bcr2000, computer-> quadcore hardcore They are all live perforemed and arrangend, (tweeking knobs, playing synths, sampler and drummachines.... looping midiloops... ableton....) this weekend: dreamy/trippy (135BPM): http://www.phatline.at/Phatline-optischedelayspuren.mp3 90ties driven techno stuff (135BPM) http://www.phatline.at/phatline-latenight.mp3 this week Tech-Trance/maybe acid-nightmare/maybe acid heaven (140BPM) http://www.phatline.at/phatline-chilltest.mp3 past weekend BAD BAD BAD HARD DEEP DARK VS 90ties heaven pads...(140BPM) http://www.phatline.at/Phatline-zuastandsound.mp3 Technorock/experimental distortion http://www.phatline.at/Phatline-alles%20is%20innen.mp3
arrived thankz ;)
phatline is waiting for:
same here
:D knobs knobs knobs- hell yeah!
ajo das ETH Interface - könnt ja auch als Midi interface heralten? Welche Latenzen gibts bei "midi over lan"?
ok ob die Treiber bei Vista funken is erstmal egal - ich werds drauf an kommen lassen :) Das es als midiinterface wirken kann, hab ich auch schon rausgefunden ;) nur ne Frage - Gibts erfahrungen mit Latenzzeiten in Millisekunden & Jitter? - - ich will jetzt nix bauen und am schluss hab ich schlechtere zeiten als über usb oder firewire :o
the problem is: the people have already payed ;) !!!
thx, arrived :)
Hallo, hab eben ein 64bit OS installiert, jetzt gibts für ein paar Midi-Controller hersteller keine USB-Treiber (schande), Ich benutz ableton live, dazu aber auch hardwaresequencer,, die beiden zu verheiraten war mit usb wegen jitter und latenzen ein horror, über die serielle solls weniger jitter und latenzen als über usb geben. (es kann ja fast nur besser werden >:( ) Nun gut was brauch ich: 1x Midi in 1x Midiout - so das ich meine Controller -total recall -betreiben kann, auf midiin kommen CCs der Midibox und aufn midiout will ich eine midiclock, Noten und CCs (von ableton) schicken. Nun jetzt gibts das LTC Modul in verbindung mit an Core modul (weil ohne PIC geht nicht?). Nun die Frage: Nehm ich da vom Core den Midinput (weil aufn LTC gibts ja nur out und thru)? Welche Software muss ich aufn Pic spielen damit das ganze als Midiinterface fungiert? (oder geht das mit jeder und ich muss es nur in der jeweiligen Aplikation aktivieren - mdifilter app z.B.?) Wie schauts mit den Latenzen aus, weil wie ich das seh, werden ihrgendwie die baudraten durch den max232 verändert und in den pic gejagt, - gibts vermutlich oarge latenzn? (milliskeunden? = zuviel bei zusammenspiel von DAWsequencer und externen equipment...) Werden die Latenzen (oder schlimmer Jitter) kleiner wenn mans am STM32 board anhängt- ist das möglich? oder ist ETH so und so die gscheidere Lösung wenns ums Jitter und Latenzen geht, ich mein das RS232 protokoll is ja sehr brauchbar was das angeht, nur die Wandlung im PIC? ganz ehrlich ich kenn mich programmiertechnisch allzu aus, -ja ok ich kann eine SID app aufmachen und das so konfigurieren - das zu der Hardware passt- is ja gottseidank deppensicher gemacht :) -- deshalb Frage ich mal in die Runde, im Netz gibts ja einige RS232-Midi Adapter, nur halt mit fehlenden Treibern für Audioanwendungen, und wenns so Converter gibt dann oft viel zu teuer und aufwendig (damits z.B. aus so yamaha standart treibern funkt) Help.
Thankz oh thankz :D LOL
Artist: Phatline Title: elektrochemische impulse 9mai2009 Link: http://www.megaupload.com/?d=XN9UPJ5L GERMAN: (English info below ;)) eine neu auflage, meines Tracks diesmal mit neuen setup: (hardware meets software) NORD RACK 3 ROLAND JP8080 2xWALDORF PULSE im Poly betrieb NI-BATTERY KORG ELECTRIBE ER1 MKII Abgemischt und gesequenzt über Ableton live, Presonus firepod als soundkarte, und 2xBCR2000 zur controlle über Ableton und Battery. Das ganze live arrangiert. ich find das es eine "schöne" numer worden is. ajo viel spass und good vibrations- phat ENGLISH: the 2009 version off my 2008 made track "electrochemic impulses" live performed with my new setup: (hardware meets software) NORD RACK 3 ROLAND JP8080 2xWALDORF PULSE in Poly mode NI-BATTERY KORG ELECTRIBE ER1 MKII Mixed and sequenced with Ableton live, Presonus firepod as soundcard, and 2xBCR2000 too controll Ableton and Battery. ---it has space darkness and much synths--- Feel it!- phat
Oben ist ne Rolle Unten ist ne Rolle Dazwischen ist der Gummi gespannt. Mann muss den Gummi sowieso ihrgendwie nachstellen können, also auf der unterseite zwischen Oberer und Unterer Rolle, eine Kleine achse mit kleinen Zahnrad dazwischen gespannt, so wie beim Fahrad der Kettenspanner... Je kleiner das Zahnrad, desto mehr umdreheungn hat die Achse....auf diese Achse dieses optische Rad drauf- und fertisch. ;)
