Wild_Weasel
Programmer-
217 -
Everything posted by Wild_Weasel
Hi! Clearing out my stuff and therefore selling a GM5x5x5 USB to Midi adapter, populated, as is, most probably defective. Get yourself a piece of vintage Midibox stuff, most likely from around 2008. Asking price 15€. Shipping worldwide, Europe prefered. Shippment is extra. Regards, Michael Picture link: https://ibb.co/3cdhVW2
Hi! What did you pay for shipping? is what I get for shipping to Austria..!?!?!. Weird. Regards, Michael
Impressive work!!!! Eager to see it with frontpanels on. regards, WW
hello! Yes, the project is complete now although I didn't update the wiki. The Selektor was even used to play some gigs. Problem is with the appearence of Traktor 4 that I would like to have a different controller concept with incorporates the many hot cue buttons. Regards, Michael.
Thanks a lot. That did the trick. Cheers, Michael.
hallo! das muss falsches pining sein oder eine datenleitung hat keine verbindung. Hatte das auch schon mal. grüße Michael
ähm. I think so. Is there a tutorial? cheers, m.
Hi! I am trying to install the new c interface and while trying to compile the "hello world" I got this error und WindowsXP C:\MIOS\apps\templates\sdcc_skeleton>make makefile:28: /include/makefile/common.mk: No such file or directory makefile:31: /modules/app_lcd/dummy/app_lcd.mk: No such file or directory make: *** No rule to make target `/modules/app_lcd/dummy/app_lcd.mk'. Stop. can anybody give a hint. I think I got the pathes correct. Has this anythig to do with the MIOS_Path, tried that too but nothing happend? cheers, michael
c1 and c2 (common pin?) are the ground pins. all the other pins go to one input pin on the DIN module. J1 and J2 are the pins of the encoder (rotary thing in the middle) the other 4 pins belong to the shuttle ring. that's it. You need to do some programming though to make them work, f.e. with the C interface. regards, michael
hi Wilba! Me again! Which library do you use for the tact switches and the encoders. I am searching for hours... Would be great if you could share them. cheers, michael
I assume it is a stereo SID synth.
gorgeous!!!!!!!!!!!!!!!!!
Hi twin-x! have you got dxf files or anything? I am thinking about waterjetcutting 2mm carbon fibre panels. Would be nice if you could hand them out. cheers, Michael
cool project. keep us informed!!!
MB-SEQ V3/V4 Control Surface PCB and matching case
Wild_Weasel replied to Wilba's topic in MIDIbox SEQ
hi! Just wanted to know if the encoders are also connected to the matrix or do they need to have a dedicated input on a SR. I need to know that for a other project though. Regards, Michael -
hi! There was not much info on the forum. Just this picture and the question if anybody would know more. I sadly lost the link. It just looked that if this is an MB project so I thought I would ask here. Cheers, Michael
hi folks! Found that picture on the djtechforum. It is supposed to be a dedicated Traktor Pro Controller. Has anybody any infos on that one. I am thinking about pirating the design. Seems that every Deck got an dedicated PCB and another PCB fot the FX section on top. Anybody knows where to get these Switches. They look like OMRON B3W Series. Cheers, Michael
Amazin work, Sasha! PCB looks really cool. Do you plan to share the layout? Cheers Michael
I did once convert a dmx controller do midi. Worked pretty well since these controllers mostly use linear potentiometers rather than log. ones. That is the only concern you should have - getting lin. pots. regards michael
do you plan on using it in matrix mode like on MBSID or just one Led per output. I case #1 one 195 and one 595 should be sufficient. 15*4 = 60 and 8*8 = 64 so there will be 4 outs free, these ports should be available thru a pin or something for an aditional led.
I think there is everything you need on the datasheet. .700 * 25,4 = 17,78mm btw. I like the 4 ring version best. As phattline said, this one is most versatile. cheers michael
I would be in for 8. cheers michael
shame on me. Just saw this topic today. I am in for a PCB and frontpanel. Cheers, Michael -
Hi! No I didn't use them. But the datasheet of my LC Display (crystalfontz) provides the exact wavelenght of the backlight LEDs; value is nm (nanometers). It happens that RS-components also provides the wavelength of the LEDs they sell. So it's pretty easy to match them, within a range of, let's say, 3-5nm. I think this effort really pays of, since you maybe will only build one MB6582. Cheers Michael
