169 -
2
Everything posted by dreamer
Nicely done. Respect to you, trying all those instruments. Keep up the good work. Greetz
nice, i began to wonder why it took so long. Almost was afraid i paid for something i won't receive. Thanks for the update. grtz
nu ben ik de draad kwijt. lol :D Je vertelde me dat je 22nf 1% hebt, maar deze kan je toch niet gebruiken voor de 8580 en 6582 of wel? Groetjes
Wilba, youre the greatest. 8) I did what you told me, and now it sounds beautifull without any noise and weird stuff going on. Thanks for the help. Now to continue the process to a complete mb-6582 Greetz
alleen 22 nf heb ik toch niet zo heel veel aan. Aangezien op mijn mb-6582 alleen maar 8580 of 6582 komt. Maar toch bedankt voor het aanbod.
Looks great. Hope the bulk order isn't finished before i've complete the mb-6582 :D otherwise i get very busy. Don't think my girlfriend will like that Greetz
I tried to get the pens out but that is not possible. I will try Wilba method. Is the connection for the headphone still working after that?
Ligt er een beetje aan hoeveel sid chips je er in gaat zetten, en welk type. Voor 1x 6581 heb je 2x 22nf nodig. Dus voor 8x 6581 is dus 16x 22nf. Groetjes
whoohoo i'm on the list :D
I don't have a datasheet for the jacks i use. But i have taken some pictures maybe you can see if they are the wrong ones. Greetz
yes, i checked the pcb layout and youre correct, but the layout we received is a bit different then the one on the wiki. I can't imagine that has changed. But that still doesn't explain why the sound from my sid1 is coming out this socket. Hmm strange. If i connect to the other socket i don't hear anything. :-\
Hmm, this socket plays sid 1 :P
Thought i showed the progress with the mb6582 so far. I tested it, it's making sound but alot of noise. :( uploading patches to bankstick works. Midi controller works. Uploading MIOS to pic works. I'm still missing some caps at the top, is it possible this can be the reason for the noise? I only use 2 sids cause those are completly finished. Parts are ordered. to finish the print.
Ik zit er aan te denken om tantaal condensatoren te gaan gebruiken voor het filter gedeelte aangezien deze nog nauwkeuriger zijn. Heb jij ervaring met deze?
Have you tried turning the pot meters for the lcd, cause it is possible text shows up when you turn the 2 pots.
Hey doug, i've updated the wiki, but haven't updated the total cause don't now for sure how to update the total, could you please review my addition to the wiki cause i'm not sure if you understand what i've added.
dus als je gewoon keramisch gebruikt met dezelfde waarde zou dus alleen maar beter zijn toch?
Wie kan me helpen aan twee onderdelen voor m'm MB-6582?
dreamer replied to renepela's topic in Nederlands
voor mij mag je ook afronden naar boven maak er maar 100 van. :D -
Dat is dus het probleem, ik heb zitten zoeken maar kon niets vinden ook omdat mijn duits niet zo heel goed is. Hoopte dat iemand mij hier aan zou kunnen helpen :o Groetjes -
Hee is het nog mogelijk om nog wat extra te bestellen. Ben eigenlijk nog opzoek naar flatcable's met aan een kant een connector zowiezo voor aansluiten van lcd dus dat is 16 polig, en om control unit pcb aan te sluiten op base pcb. Volgens mij 8 polig en dat 8x. Mijn duits is nog al slecht dus kon deze niet vinden. Groetjes -
Dat is inderdaad fantastisch. Ik heb alleen nog iets meer nodig aangezien ik deze onderdelen nog niet heb gevonden, moet ik wel toegeven dat ik nog niet bij farnell heb gekeken. Maar als het toch mogelijk is om bij reihelt te bestellen kunnen deze onderdelen misschien ook meteen overgenomen worden: - 96 x Taster 3301D - 8 x PS6-LOG-100K - 2 x D-SUB BU 25US - 4x 6N 138 - 8x MABP 5S Ik ga ondertussen de bestel nummers opzoeken van de rest van de onderdeeltjes. Deze zal ik in de loop van de avond toevoegen aan deze post. [edit] dit zijn alle onderdelen die ik eventueel bij reichelt extra zou willen bestellen. Groetjes -
helaas heb ik net een order de deur uit gedaan voor 2 lcd displays bij crystalfonts anders hadden we inderdaad wat kunnen besparen. Ik zelf ben ook nog opzoek naar dezelfde onderdelen als renepela. - 96x tact switches. - 8x dual gang 500k pots. dus als er hier een group buy van komt doe ik zeker mee, misschien dat ik nog wat onderdelen over het hoofd zie maar totzover alleen deze parts. groetjes
Volgens mij zijn deze parts niet zo zeer noodzakelijk voor een werkende mb-6582 zijn natuurlijk wel leuke opties om er toch in te bouwen maar doordat ze niet noodzakelijk zijn hebben ze ook niet de grootste spoed. Maar het is inderdaad wel makkelijk om alles bij dezelfde shop te kopen vanwege verzendkosten. Ik ben ook nog even aan het rondkijken. Groetjes -
Ik heb de foto's van wiba bekeken en ik zie ze inderdaad, ik ben ze nog niet tegen gekomen omdat ze niet op de pcb staan, dus die moet ik inderdaad ook nog hebben. De verzendkosten zijn zeker belachelijk duur, maar goed ik heb het er wel voor over, ik wil de kosten wel delen met je doe maar mail sturen hoe je dit wil gaan regelen, organicdreams25@hotmail.com Ook moet ik die pt-10 behuizing nog hebben, is die ergens te krijgen in nederland? Groetjes Groetjes -
Hoi, ook ik heb dit probleem met de tact switches, ik heb het dubbele aantal nodig dan wat jij moet hebben. Als we samen bestellen zijn we er dan nog niet voor rapid electronics? Deze begrijp ik niet helemaal de 4 pots die uitsteken zijn toch gewoon 6.5 stereo jacks de pot 500k kan ik nergens terug vinden, kan zijn dat ik iets heb gemist. In het Conrad boek van 2009 staat een geschikte pic programmer, ik zelf heb de pics laten programeren bij smash, dus ik kan je hier niet mee helpen, wel kun je eventueel zelf de pic burner op ucapps zelf maken. Groetjes
