audiocommander
Frequent Writer-
1,358 -
http://www.thomann.de is a musicshop with very fair prices, the largest shop in germany (gigantic house and even more gigantic depot), but selling also to other countries. And very kind people working there :)
I like your Avatar, but am surely going to ad-block this gigantic signature :o hehe... ;D
how to put unmuxed ains with the scan matrix..
audiocommander replied to Wisefire's topic in MIOS programming (Assembler)
Hi Wisefire, it's most likely I don't tell you nothing new: you can use any cc number by using an array, eg: [TT]unsigned char pin_cc[5] = { 20, 21, 12, 7, 127 } [/TT] - or if you just want other CCs than from 0 to 7 it might be easiest to choose CC's 20 to 27, by sending instead: [TT]MIOS_MIDI_TxBufferPut( 20 + pin ); // send CC-number [/TT] Cheers, Michael -
Speakjet - A PIC ready sound chip?
audiocommander replied to herr_prof's topic in MIDIbox User Projects
Hi everybody, just wanted to drop in a note, that I'm still here and that I've suspended my source-code release a bit. I currently want to finish my sensorizer first and the speakjet application is still a bit buggy – but because I want to connect the speakjet to the sensorizer, it is sure, that I'm resuming to work on this ...I think 2 months will be realistic, if anyone needs sources desperately, PM me! Cheers, Michael @Justin: is your SJ working again? -
You can also attach a simple switch which triggers on movement ("Rüttelschalter" in German... a switch with a light feather that triggers if you shake it) to the tambourine or a ("Neigungssensor") if you wish to trigger different sounds (as AIN). I know there are also some switches with a metal ball in a tube; this could also be assembled manually (say the ball is connected to ground and the both sides to a DIN-pin). This way it would be very easy to write a custom application that sends NOTE_ON's on each contact-(DIN-)event. Best Regards ;) Michael
super, das wars :) danke! (hätte ich doch noch die dritte Möglichkeit durchprobieren sollen :-[ ) Liebe Grüße, Michael
Only the pots are jittering, not the faders ??
audiocommander replied to SLP's topic in Testing/Troubleshooting
This is a typical reaction of ungrounded AIN-pins. If you leave let's say all 8 inputs ungrounded and put a signal on one of them, all eight show an input signal. You have to check again all your connections, there has to be a soldering error or wiring fault somewhere! Can you check your connections with a Multimeter? I bet the pins are not grounded and there's a signal coming in on one of them... -
bei Pollin steht 16 Raster. habe nur noch nicht rausgefunden, wie man bei langsamen Drehen je einmal schalten kann, der Encoder scheint jeden zweiten Turn auszulassen. Wenn ich den ENC_SPEED_MODE erhöhe, dann geht das Auslassen auch nur schneller :) Hab's mit ENC_SPEED_FAST, 0 bis 7 durchprobiert... Hat da vielleicht jemand einen Tipp ??? Michael
Ich habe mal einen Eintrag mit Pin-Belegung in die encoder-specs vorgenommen: http://www.midibox.org/dokuwiki/doku.php?id=encoder_specifications ;) Michael
...I added an entry to the encoder-specs page http://www.midibox.org/dokuwiki/doku.php?id=encoder_specifications ;) Michael
Hallo ansolas, im Wiki findest du ziemlich viele deiner Fragen beantwortet, schau dich einfach ein wenig um und lies insbesondere die Einführung: http://www.midibox.org/dokuwiki/doku.php?id=introduction_to_ucapps.de ;) Grüße, Michael
Hey AndAway and ToS, I don't have no touchPad, but a few of these touchPots (so I may be totally wrong) - but I don't really understand the problem. You have to write your own app anyway, so if the pot snaps back to 0, you just have to ignore 0! I am reading a 10bit value (while sending a 7bit value!), so just ignore the values 0..24 => then 25 is the 7-bit value '0' ... see? No difficult circuits, no additional foils or stuff... ...although I think Wilba's circuit seems very promising if you want to build a MB-Pro 8) Cheers, ;) Michael
Hi Bill, as I understood, the main trick is to wire the LEDs correctly (I think a sample can be found with the LED-Rings wiring PDF). Then you need kind of a matrix array for each figure you want to display... this matrix is then switched line-by-line... sorry if I'm so unconcrete... I'm very short in time these days, I'll watch this thread, maybe I can contribute more details when I get my LED-meters working :) Cheers, Michael @jdelgoulet: thanks for your kind words :) although this is a bit off-topic, just for the record, my site has never been down: http://www.audiocommander.de/blog/?p=48 and Ben (http://www.1710.co.uk/picosx/) had only temporary troubles 'cause the server got struck by a lightning :o
jo, wäre auch mit 2 Stück dabei + Aufwandspauschale für dich ;D Michael
You know... sometimes I got the feeling my application code has the power to desolder a cable when I don't look and connect it to some totally strange other position where it makes me a lot of headaches until I notice it :P ;D ;D great to hear it worked for you docbrown, keep it up! Michael
;D Yeah, I tried the easiest way first... ...I'll post a schematic if I got it ;)
I ordered some of them, because I need encoders with a push button. Although the caps are not changeable and noticeable force is required to turn them, they seem to be quite okay... Has anyone a wiring schematic to connect to a DIN at hand? I tried to wire them like the ones from Voti.nl but didn't succeed so far... (btw: there is already a thread about these somewhere here in the forum, but it might be in German, don't remember right now... ) Cheers, ;) Michael
There is the 1st level bootloader that is burnt onto the pic. Then there is another 2nd level bootloader coming with MIOS; this one is active for about 2 seconds after rebooting. If you have a corrupt application that is blocking the incoming SysEx events, try sending your application immediatly after rebooting (in that 2 second range of the 2nd level bootloader). Let us know if this helps. Cheers, Michael
Can you give us some more information, like a relevant section from the CrashReporter (see -> Console -> CrashReporter) ...and maybe one more hint: I know that although the latest Java Release will be installed on your Mac, you might have to enable it as default runtime, else OS X is using the old ("stable") version. That might be related to your issue. Please search this forum, I had this issue and am sure I posted it somewhere... maybe in the sticky MIOSStudio for Mac-Users Thread? Cheers, Michael
Hola, ...sorry, can't speak español, but there are indeed some of us using Macs. I don't know what you want to do with it, if you want to code your own applications, see here: http://www.midibox.org/dokuwiki/doku.php?id=how_to_use_xcode2_as_ide_on_a_mac For a normal Midibox (eg MB64E) the OS makes no difference, as everything is done by MIDI (you need a MIDI-extension box or card, of course). You just need a pre-burned pic that contains the first level bootloader, because afaik there is no bootloader burn-software available for the mac. But SmashTV or Mike also sell preburned PICs! (hope this helps ;) Cheers, Michael
Hi, I wrote a similar program for Mac users, it's freeware and called Midimouse: http://www.audiocommander.de/blog/?p=10 Best, Michael
hey, that's a nice work, stryd_one :) ...but maybe we should put that on an extra page to avoid confusion for beginners. I think this is quite a special topic and not really relevant for the oversight intro-page to app-coding with MIOS? what do you think? Cheers, Michael
MIOS can't find Audio interface on OSX 1.4.7
audiocommander replied to marcus77's topic in MIDIbox Tools & MIOS Studio
:) Nice to hear! Best, Michael -
have you installed the plumstone midi driver? http://www.midibox.org/forum/index.php?topic=5230 MIOS itself has nothing to with MIOSStudio btw, it's the name of the operating software of the chip itself ;) Cheers, Michael -
Hi Stryd_one, thanks for all your help regarding this issue! I can't access my mbhp hardware the next days, but I really hope, this can be fixed by the wrapper... if it's SDCC indeed, I'll have to implement an ASM routine, 'cause I don't think I'm going to break my working SDCC setup on the Mac (however, will try on the PC the next weeks to identify the problem, nevertheless)... and no: the Socceroos did some great games, they were just unlucky this time... it's always sad when a game ends like this with a wrong decision :( They would have deserved the next round... Cheers to Australia! ;) Michael
