1,774 -
Everything posted by cimo
	i ve just noticed the last entry on the poll, i think we should guarantee external packages aside from the distro for people who is already using Linux and want to add just the packages, that would go in Ubuntu as: -add an entry in synaptics with the repositories of our packages -update -install the MIDIBox (or whatever called) packages ..sounds immensely cool to me
	it s free, and i like to use what it s "default" on Ubuntu to be a compatible help for friends, cause since i started fighting for the cause i get help requests daily, err good idea, wasn it ? ;) I installed it and used an image of Windows i ve accidentally found on the net (without burning a cd) and it worked outtabox
	what about MBemo then?
	I ve sent a link to this thread to PlanetCCRMA - UbuntuStudio - Linux Audio Users mailing lists i would add VirtualBox so one can install a virtual Windows if needed
	it s ILLEGAL !
				Anybody want Brand New Cybikos? First batch all gone
cimo replied to TheAncientOne's topic in Fleamarket
hi my house mate got them yesterday, i had to fax her a damn nameization so she could pick them up at the post office; i told her she can play with them until they get in my hands ...... muawmuawmuaw -
	I don t understand what you are saying
	dunno, preparing a cutting edge audio linux distro ... you see the guys at UbuntuStudio .. CCRMA is a rock solid community (university) with years of experience.. so my opinion is, we deliver an "intro" audio linux distro where the audio is just secondary but enough to give the user the chance to try something out, then and if he ll like he can choose his own audio distro (read: CCRMA, sorry Cory) or then we talk FC8/9 with CCRMA and our MIDIBox packages, that s an option, why don t we ask Fernando if he would like to add a MIDIBox package to the list? that sounds reasonable.. we mantain of course.. Simone EDIT: http://fedoraproject.org/wiki/FedoraLiveCD/USBHowTo
	this is unfortunately untrue, there is a thread on the UbuntuStudio mailing list about this "issue", it s not a real issue though, anyway, we don t realy want a cutting edge distro, we should aim at the MIDIBox tools for the moment right?
	afaik it s illegal, you are not allowed to make a windows distro Stryd it s great news!!! Of course you can count with me if this stuff will get started, i would start with MIDIBox stuff then let the other community join the idea, and add their packages. If we are going to add some music stuff then it is worth to use the UbuntuStudio distro that come with the Real Time kernel already compiled in
	Crystalfontz brand owner:
	en setup_mb64.asm (dentro de la carpeta de la aplicacion MB64E) tambien mismo parametros en setup_mb16e
	-what are those vias at J0 doing? -are you going to get this board done? --there is some weirdness on those "Jx" texts
	you are, diameter is 20.32mm ;D don t worry sometime happens
	..pues te has liado un poco, ya no me quedan dudas, cargale la aplicacion que te he linkeado antes.Alli tendras una aplicacion funcionado pero tnedremos que adaptarla a tu proyecto. EDIT: alli va el palicazo que necesitas leer: http://www.midibox.org/forum/index.php/topic,11882.msg96460.html#msg96460 como sabes codigar (eh acabo de inventarmelo) en C en los PICs te aconsejo de cargarte el C skeleton y trabajar con las funciones en C.No lo hagas ante de haber preparado la toolchain necesaria para trabajar en tu ordenador. Simone
	que sea porque...tienes el CORE echando MIDI aleatoria sin freno? vale pero tienes cargada probablemente una aplicacion que activa tods y 64 los AINs: mira a J5 , tu tienes conectados solo 4 pins pero 64 pots requieren 8 pins (cada pin a un 4051 -->8x8=64) asi que si tienes cargada la aplicacion MB64 tienes los 4 ultimos pins de J5 flotando; tu PIC saca MIDI a rueda libre y el led del monitor out se queda prendido, mas que prendido esta parpadeando a alta velocidad. (Por si no te has enterado no soy de habla hispana, a veces se me hace dificil esplicar las cosas)
	hay unos archivos de texto en la carpeta del MISO que te esplican porque te sale aquello,leelos. Por lo de la aplicacion: no intente liarte mas de lo necesario, me parece que tienes MIOS bien cargado y funcional Repito otra vez (porque es importante) has conectado los AINs que no utilizas a GND? si no lo haces se quedan "floating" y vuelven loco al PIC y a MIOSStudio o MIDIOX etc es posible que antes tuvieras todo bien cargado pero MIOSStudio no puede leer todos aquellos datos y se bloquea. que led?
	eheh lo tenemos estas cargando algo que no tiene nada que ver! tienes que cargar http://ucapps.de/mios/midibox64e_v2_2b.zip EDIT: tengo unas dudas pero, puedes darme una link a la aplicacion que estabas intentando cargar? ;D ;D ;D
	hola todavia no he probado a compilar aplicaciones con la nueva plataforma asi que no se que decirte, dame unos dias a ver si le echo un vistazo. porque no cargas simplemente la aplicaciopn como viene, osea con 64 potes y conectas a GND los AINs que no utilizas?
	thanks for all the comments, so far i ve changed the footprints for the caps using 3 pads footprints (not possible for C8), fixed C5 to 200mil pitch, made some space for the GND zone to reach all the way inside the PIC footprint, so i had no need to add any other zone, repositioned R2 and i ve laid down (ehmmm) R11 and used larger clearance for the zone.
	hola tienes que acostumbrarte a darnos informaciones mas detalladas, que hiciste, paso por paso de otra forma me resulta dificil ayudarte Simone
				SOS : i dont think i killed my pic, but something is wrong
cimo replied to un.diletante's topic in Testing/Troubleshooting
.. things are changed in these very last days though, now there is a setup_mb64 file that includes main.asm which has been moved in a source folder, new structure, i ve written to un.diletante in the spanish forum, better getting used to the new system.
