cimo
Programmer
    1,774
Everything posted by cimo
  1. hi a pal of mine (member of Tupperwear is going to perform in east Europe with his solo/noise/ambient project: Afg-an more info at www2. o2bar. cz http://strangercafe. com http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=141795362&MyToken=f113411a-a7d8-47d4-a625-9df41db29cc0 don t miss it if you re around and bring your earplugs
  2. i hope that i ve made myself clear ;)
  3. i understand english but i can t write it properly etcetc 2 questions: a)why is it implementing it (the function) all the time? b)i also don t understand why it implements it always at the end and with that syntax i ll keep on searcing and i ll try to eliminate it since the compiler outputs it as an error te contesto yo: no pasa nada correcto, por ejemplo yo utilizo unos minijacks estereofonicos para conectar AINs externos, cuando los desenchufo el pin se conecta automaticamente a GND Simone Gracias Edu
  4. ...there is actually a solution if you are going to use a computer: you can use Midiox/MidiPipe/Qmidirouter to translate a couple of note events in CC increment/decrement
  5. again, you are right there: it s the software that translates the buttons/encoders to MIDI events, the point is: MIOS and its apps are ready to be modified, but how will you deal with a proprietary code embedded in a commercial machine?
  6. start with: http://en.wikipedia.org/wiki/CV/Gate
  7. right, now how are you going to hack an inbuilt firmware of a commercial keyboard?
  8. . nope you can get an instaler for windows as well and osx support will come soon, atm you need to compile yourself if you have a Mac.
  9. yes do it Eagle is an amazing program (cimo is politically correct ;) ) but you may want to give a try to kicad as well cause it doesn t have the size limitation that Eagle has.
  10. hi yep basically there is a little issue with Ubuntu and probably other distros related to sh/bash/dash.There is a workaround as you ve found out, but probably something should be changed in the source code of the application, i know Stryd _one is working on it, if you want to join the bandwagon and some some ideas feel free to drop by the chat sometime. Simone eheh ok TK was faster not only on answering but getting the source fixed, thanks Ubuntu users are very happy for that! ;)
  11. ok hai raggiunto il livello: "la domanda che fai e cosi ovvia che si capisce che non hai letto bene ucapps.de e la wiki" ;) e una lunga tradizione del forum incoraggiare gli utenti alla ricerca personale ;D ;D (anche in termini filosofici se ti fa piacere) fammi sapere Simone EDIT: il modulo AIN e quello che connette fader/pots al CORE
  12. per la sezione switch dovrai usare dei "bottoni" che invieranno midi e dei realys che controllano gli audio INs/OUTs
  13. errr potenziometri/faders ?
  14. non vedo nessun problema con MB64
  15. considera la possibilita del soft-overtake: se richiami un preset la posizione attuale di un potenziometro non viene letta finche il valore attuale non corrisponde al valore letto nel preset: MB64 ha questa funzione Chiaramente dei potenziometri motorizzati sono una soluzione piu elegante. Simone
  16. http://www.midibox.org/forum/index.php/topic,11849.msg95954.html#msg95954
  17. there is plenty but Ubuntu is just the way to go for hardware compatibility, support, repos etc. Let s don t get "down" for this little problem, as Stryd pointed out the live CD was a great option but probably not really so fundamental for our purposes: we have a great distro to work with and great developers support, let s go ahead with what we ve got.
  18. ciao e benvenuto capiti bene perche ci sono vari utenti che stanno lavorandoa progetti simili, prima di tutto facci sapere come te la cavi con l inglese. Ti assicuro che quello che vuoi fare e possibile, un po complesso pero con il tuo background non ci saranno problemi: preparati ad imparare un bel po di cose nuove. C e un altro italiano che sta lavorando ad un progetto simile: guarda nel forum Italiano e cerca "Dimitree" Simone
  19. hi i d like to know more about preheating roller bypass and other tricks could you explain that better?
  20. same as nils, the "glue" doesn t actually glue so it s quite easy to remove it if the cables have away out.
  21. disclaimer: following nILS advices could lead to master boot record erasure
  22. cimo
    Totally lost
    what a bout CS lines?
  23. The message body was left empty.
  24. yeah but that is the Law of Tilted which, as everybody knows, twirls the cables anticlockwise
  25. impossible, the Law of Simone says that it is impossible to bring the right cables and that if you bring the right cables then one will fail 5 minutes before the show.
