cimo
Programmer
    1,774
Everything posted by cimo
  1. hi and welcome it mainly means that you haven t been reading enough ucapps.de and the forum, everything you need to know to get started is there, have read the wiki pages? The CORE module hosts the PIC chip, you can get it at avishowtech.com with or without it: you want it so order it.About the "thing you have to do" it s choosing the pic header: as long as we don t know what s your plan for your MIDIBox we can t help, but, generally, you are going to be ok with the default option. Hope it helps but get some extra reading before posting again, good luck ! Simone EDIT: I see from your other post that you are going to build a MBSID: for the latest firmware to work you need a PIC 18f4685
  2. si parece que despues del ultimo update de Ubuntu para FF se haya jodido el Flash Player, a ver si lo arreglan, ahora le echo un vistazo con el mac
  3. no puedo ver el video aarrgh solo hay que esperar o que? quiero ver!
  4. MIDI ? no non serve un DIN per far comunicare i 2 COREs io comunque aggiungerei un DINx1 per poter utilizzare eventuali funzioni menu/non si sa mai,magari in futuro vuoi fare delle modificazioni va bene nel lato componenti mettili piu vicino agli IC possibile
  5. http://www.chilidevices.com/site/index.html bah buh boh mpft nnn maybe eeeww possible gnnn if I .. errr EDIT: all in all price and package are not really friendly..
  6. FALSE!
  7. Twin-x hip hip hurra! hip hip hurra!
  8. non era chiaro... effettivamente sarebbe normale utilizzare un DOUTx4 e non 2 DOUTx2 pero mi riferivo al fatto di mettere i leds in parallelo con i relays e usare solo 16 DOUTs
  9. forse questi due si possono combinare assieme? si
  10. ... so is there any IRC channel we can use? (same old question)
  11. If we can split to job in several part and distribute it among all interested it could be doable with less effort, i am in!
  12. si, ammesso che ci sia lo stesso setup caricato o che si attivi una funzione che "scanna" (ehe) gli outputs se vieni nella chat adesso ci sono
  13. Non ti preoccupare era solo un dettaglio, i relays latching non cambiano il loro stato se togli l alimentazione.
  14. cioe se la userai in concerti o no... Per C si parte dallo Skeleton http://ucapps.de/mios/skeleton_v1_9a.zip e ci si aggiungono funzioni http://ucapps.de/cmios_fun.html
  15. EDITED: corretto DIN/DOUT no 5 relay sono un pò pochi..almeno 8 me ne servirebbero.. Da quello che ho capito 1 modulo di DOUT permette proprio 8 uscite digitali vero? Attenzione con i nomi! 1 modulo DOUNx4 contiene 4 chips, ogni chip ha 8 uscite digitali o DINs il modulo DOUTx4 e l unico che puoi comprare nei "negozi ufficiali" esistono pero anche le PCB per moduli DOUTx1/x2/x3 con 8, 16, 24 DOUTs ognuno rispettivamente.Se sai fare dell PCB o hai chi te le fa per 8 relays ---> DOUTx1 vedo una risposta troppo lunga, dovrai scoprirlo con il tempo, comunque non ti preoccupare, la tua e una applicazione abbastanza semplice.. NO! puoi inserire ASM dentro C ne farai uso "onstage" ? ti consiglio relays "latching", per se ti si sconnette l alimentatore
  16. ok buona scelta direi dai un occhiata al modulo DOUT http://ucapps.de/mbhp_dout.html che e quello che connetterai ai relays se vuoi max 5 relays li potresti connettere direttamente al CORE hai letto la wiki? http://wiki.midibox.org/
  17. .. i forgot to link you http://www.midibox.org/forum/index.php/topic,11849.0.html
  18. allora un relay e un meccanismo attivato da un magnete elettrico (penso si chiami cosi), un matrix switcher e basato su componenti elettronici (non si muove niente, non e meccanico) matrix=matrice ...mm immagina la battaglia navale e le coordinate, scegli una coordinata e connetti un input con un output, chiaro no? l oro si usa perche non si ossida con il tempo ed assicura un miglior contatto elettrico Simone
  19. let s move italian talking (with hands waving and all) to italian forum..
  20. they never came to life...
  21. mine will destroy yours, his and respective families 3 generation back altogether with whoever he will find on the way home
  22. Good reading http://www.midibox.org/forum/index.php/topic,11262.msg95260.html#msg95260
  23. amando, no amando, amando,no amando... mira yo llevo dos anos sin swindox, estoy mas feliz que el carajo, la primera horneada de 8.04 tenia algun problemilla, yo como por milagro desde que he instalado por segunda vez, funciona todo como deberia.. hasta va en hibernacion cuando cierro el laptop y vuelve a resuscitar sin problemas, pulse audio jode un poco todavia pero es funcional asi. "entre comillas, yo no he utilizado nunca vista..." asi que, lo que te aconsejo es, reinstala todo actualiza y a ver si tienes suerte como yo..
  24. la seconda ch' hai detto ;) yep EDIT: audio and MIDI data can t and won t ever be mixed up, they re just 2 diffrent beasts, worries about a matrix switcher could come from the solid state/not solid state relays "clicks".
  25. aja! tu tambien luchando contra a pulseaudio? a ver si lo arreglan de una vez si tienes un reproductor abierto cerralo, y tendrias que poder sacar sonido de ff, quizas necesites reiniciarlo (ff) Simone
