1,774 -
Everything posted by cimo
hi again i went to ESI s web (no audiotrack ! same company though) and it says: now just for sake of it, try to install driver: http://download.esi-audio.com/?w=esi&p=16&g=4&l=en and see if it recognizes the interface.You could also try the RomI/O drivers. Simone
.. i find myself on the unfinished crusade for the perfect setup... ..i use 2 turntables with 2 phono preamps and Mspinky s timecoded vinyls.I route the two channels in my external soundcard and then into 2 tracks in Ableton.Therefore i take out the 2 tracks again from my soundcard (2 separate channels) and feed them in an analog mixer, from there to the amp. Now, i can t really figure out how to use return channels, since i don t use the master channel, where should i send the signal of the return channels? any idea is appreciated
hi sasha i own an older midi mate, that one with the little transparent box and the red silk screened pcb.It works ok also with sysex. NOTE: you need the driver to send sysex, normal midi will work also without the driver, this for XP. I am not sure if the chip inside is the same as yours but we could check it out if you pass me the driver, and see if it is the same as the one i ve used with my midi mate. I can t imagine the guys at audiotrack making a new device which is poorer than the previous in the same line. simone
hi generally speaking no but there is a "flip" function that will let you use the encoders to set the tracks volume (and vice versa) simone
hola de que revision estas hablando? v2? simone
http://www.ucapps.de/midimerger.html
i got some 74HC14 (no HCT) but the burner doesn t work. When i plug the lpt cable the red led lights up, is this anormal? When i plug the lpt cable without the supply connected, the red and green led light up but not so brightly as with the supply.This doesn t happen all the times ! it happens "sometime". ??? simone
ciao mario i am not (yet) a big SID expert but as far as i can see, you ve uploaded an app that expects 4 (or more) sids to be connected and pressing the menu buttons probably you try to switch the SID engine (1,2 to 3,4) about the encoder, can you tell us which kind of encoder you are using there are some issues with some specific encoders simone
fine and fair, we are here to learn mmm, we have to take into account 2 factors: the "i want 25 of each color, now" syndrome and the "i ve found a very good deal for 4mm washers, let s make a bulk order" trend as i ve said before, my main concern is avoiding bad BOs i quote myself and Jimp btw greetings to Ms ScreamingRabbit good idea, but not everybody is able/has the time/wish/capacity to setup a website, you see? i ve visited your link and i was almost there to order something, 25 of each color! ;D i would personally insist on this point.Ok let s not make any rule but let s try to keep BOs at the same standards as uCapps itself.There is a difference between money saving and a lottery. UPS UPS UPS it sounds like the new title of this thread English please! :P speak up! simone
ok bulk orders has brought big advantages ;D to the community but also big troubles >:( .I take the responsibility to talk for all the community and say "No more troubles, no more bad feelings in the community", there is nothing personal against or pro any specific user, just the wish to keep on with the bulk orders in a proper way. Now, let s forget about the past and try to figure out what we can do. Some kind of rules have to be written down and become a reference for all the BO organizer and users. Write in this thread what you think it is important for both sides. I ll give a little start: a)never ship before you have tested the items 1 by 1. b)a BO organizer takes full responsibility for the whole deal, if you don t feel comfortable with it, DON T DO IT ! no bulk order is way better than a bad bulk order c)users take full responsibility to pay promptly and properly d)BO organizers should give their telephone number to each of the BO user (is this maybe too much?) let s see what comes out and try to compile a general list of rules Mods feel free to take over this. Simone
hi well i did it ! i think this is not epoxy, i am a windsurfer and i recognize the smell of epoxy from miles away and i do know how much it itches when you work with it! The 7805 was attached to the heatsink by a screw or rivet, i won t be able to replace that so i will just put the new7805 in place and fill the gap with epoxy dot simone
spectrasymbol softpots group buy - membrane strip potentiometers
cimo replied to phineus's topic in Bulk Orders
hi phineus have you considered building a little checking circuit and testing them ? don t wanna be negative or anything... ;) simone -
hola diletante parece que de tu simples preguntas se ha desarrollado algo mas complejo que ha llevado al mismisisimo ilustrisimo excelentisimo TK a cambiar algo en: http://www.ucapps.de/mbhp/mbhp_dinx4_32buttons.pdf para que sea mas claro para todos.Es importante saber lo que piensas sobre los cambios porque estan hechos para .... los diletantes ;), esperamos saber lo que opinas. simone
..looking forward to desolder 7414s :( , i am a guru now i don t use IC sockets ::) i will let you know how it goes tomorrow i am off for some fish bbq now...
hallo i really can t get the pic burner to work. the 100R test goes right i am using 2X 9 volts batteries to supply the whole thing my compy is a 1000Mhz PIII the red led is always on i can only trig the data led from within the application i am using cheap 7414 (no hc) can that be a problem? any idea? simone
cimo replied to cimo's topic in MIDIbox Documentation Project
yep, i admit, i agree with you, also the schematic is as it should be. On the other end it is nice to know that uCapps may be a place where people without the ability to understand (or to learn to understand) can improve their knwoledge and their ability (and wish, of course) to learn.Ok now i am going slightly off topic but regarding i am sure that there are quite a few persons out there that came to mother uCapps without really fully understanding how to read that schematic and now they are happily toggling their knobs :P in that case people should stay away from main voltages and especially from asking 1000000 questions before even trying by themselves and reading reading reading Seppo, Wilba, etc etc i am not questioning (EDIT: only) you! I am mainly questioning myself, i ve been down at the Spanish forum in these last months trying to do my best when needed, it s not always so easy to understand how far you can go "trying" to help people simone -
yes, sure, but this is not the point.My point is that for a completely newbie even on electronics things that for you seem to be obvious they can be unclear to him/her, leading to: http://www.midibox.org/forum/index.php?topic=10374.0 anyway, nevermind it is just a little detail uh! 500! simone -
the connection to ground is not indicated... a guy in the spanish forum couldn t find out how to connect the buttons.. simone -
..that was a good one thanks!!..
hola bienvenido ..efectivamente en el pdf de ejemplo para conectar 32 botones no se ve donde conectarlas las soldas todas a GND o sea al pad numero 5 de cada conector del DIN, las puedes soldar toda juntas y conectarte al din con un cable solo esto si pero que esta bien documentado http://www.ucapps.de/mbhp/mbhp_ainx4_64pots.pdf no te olvides! http://www.ucapps.de/mbhp/auaimbctg.pdf suerte
ah ok thanks S1, it makes absolutely sense.. simone
thanks but i just wanted to specify that all i ve done is to write this post, Alogic has written the entire code. cheers
